1. No Audio Input/Output from POD Farm 2.5 Standalone using a Line 6 Audio Interface
This was a problem with POD Farm 2.50 that was fixed in 2.51.
Windows
Completely uninstall POD Farm 2.50, then, download and install POD Farm 2.55 from the Line 6 downloads page.
[*]Mac
Completely uninstall POD Farm 2.50 following the removal instructions below in problem 2.
Then, download and install POD Farm 2.55 from the Line 6 downloads page.
2. If you are experiencing the following symptoms on a Mac computer:
POD Farm 2.5x standalone and/or plug-in not authorized on Mac.
POD Farm 2.5x crashes in standalone mode when Changing presets.
Pro Tools crash when instantiating POD Farm 2.5x plug-in to a track or changing presets in plug-in.
POD Farm 2.5x plug-in settings are not retained in Pro Tools project after saving, closing, then, re-opening project.
Please try the following:
Close all open programs out, go to the Mac HD/Users/username/Library/Application Support/Line 6 folder.
If you are on Mac OS X Lion 10.7.x and 10.8.x, the Library folder is hidden. To 'unhide' this folder, you must first run the terminal program located in the Applications/Utilities folder. Once Terminal is running, at the command prompt, type the following:
chflags nohidden /Users/Username/Library
*The username is the username of your computer which has the house icon under Places
[*]Hit enter. There will be no indication that anything happend except for a new command prompt if it worked.
[*]With the Library folder now visible, go to: Mac HD/Users/username/Library/Application Support/Line 6 folder
[*]CTRL+Click on that Line 6 folder in that location folder and select GET INFO. Check the permissions at the bottom of GET INFO, and check to see if they are set to READ ONLY. If so, manually change the permissions to Read & Write.
[*]Then, run License Manager and just sign in with your Line 6 username.
[*]After signing in, the Line 6 folder in the above location should be populated with new items such as a Guitarport and License Manager folders, and a L6system file.
[*]Then, close out License Manager and test POD Farm 2.55 standalone or plug-in within your DAW once again.
3. Amp Models no longer available in POD Farm 2.0 or older after installing POD Farm 2.5x
Windows:
Completely uninstall both POD Farm 1 and POD Farm 2 using the Line 6 Uninstaller within Programs/Line 6/Tools folder.
Download and re-install POD Farm 2.55 from the Line 6 website.
If you must also have POD Farm 1 on that computer as well, make sure to install POD Farm 1.12 BEFORE installing POD Farm 2.55 on your system.
[*]Mac:
Throw away all versions of POD Farm 1 or 2 applications to the trash from the Applications/Line6 folder.
Manually search in the following locations and delete any of the files found from within each of these folders:
Library/Audio/Plugin-Ins/Components
Library/Audio/Plugin-Ins/VST
Library/Audio/MIDI Drivers
Library/Frameworks
(look for L6WXTG and L6WXTY.framework and delete them)
Library/Application Support/Digidesign/Plug-Ins
(Username)/Library/Application Support/Line 6
Applications/Line 6
User/Documents/Line 6
User/Library/Preferences
(Line6 preferences, should be something like com.line6.xxxxx, etc. Delete.)
Empty the Trash.
Next, go into Applications/Utilities and launch the Terminal application and type the following commands at the prompt:
cd // (then press the enter key)
cd /private/var/db/receipts (then press the enter key)
sudo rm -i com.line6* (then press the enter key)
Enter your Mac OSX account password. Note: you will NOT see the cursor acknowledge any characters being input; you will need to type your system password correctly and hit "Enter"!
Type Yes to every option/question to remove Line 6 software components (there will be a good number of confirmations, FYI).
Download and install POD Farm 2.55 from the Line 6 website.
4. RTAS Plug-ins Not Loading after POD Farm 2.5 Instantiation
An error message pops up at startup with the following: Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged. It also lists the POD Farm 2 and POD Farm Elements plug-ins below the message.
This is a Windows-based problem and seems to be an issue if Microsoft Visual C++ Redistributable is not updated or installed properly on the computer system. Using Windows Update to install/update Microsoft Visual C++ Redistributable so that POD Farm 2.5 can have access to the libraries it needs to run correctly usually fixes the problem.
5. Incorrect Graphics/GUI in POD Farm 2.5x plug-in
If you are using a Custom Plug-in folder location for your DAW, make sure to delete the old POD Farm 2 and POD Farm Elements plug-in files from that location, and move the new POD Farm 2.55 plug-in files to that same location.
On Windows XP, these new files are located in: C:\Program Files\Line6\POD Farm 2\VST\Line 6
On Windows Vista/7, they are located in: C:\Program Files(x86)\Line6\POD Farm 2\VST\Line 6
On Mac OS X, AU files are located in: Mac HD\Library\Audio\Plug-Ins\Components
On Mac OS X, VST files are located in: Mac HD\Library\Audio\Plug-Ins\VST\Line 6
POD Farm 2.5: Fehlerbehebung:
1. Die POD Farm 2.5 Standalone Software bekommt kein Eingangs-/Ausgangssignal wenn mit Line6 Audio Interface verbunden.
Dies war ein bekanntes Problem mit der POD Farm Version 2.50 und wurde mit 2.51 behoben.
Windows: Deinstallieren Sie POD Farm 2.50, laden Sie sich dann die neuste Version des POD Farm 2.5x herunter und installieren Sie diese.
Mac: Deisntallieren Sie POD Farm 2.50 anhand der Anleitung im Folgenden Problem. Laden Sie sich dann die neuste Verion des POD Farm 2.5x herunter und installieren Sie es.
2. Sollten Sie die folgenden Probleme unter einem Mac Computer haben:
POD Farm 2.5x Standalone wird nicht auf Mac autorisiert.
POD Farm 2.5x stürzt im Standalone Modus ab wenn Sie Presets verändern.
Pro Tools stürzt ab wenn POD Farm 2.5x einer Spur zugeordnet wird oder ein Preset in POD Farm geändert wird.
POD Farm 2.5x Plug-In Einstellungen werden nicht vom Pro Tools Projekt abgespeichert nachdem ich es abspeichere, schlieÃe und neustarte.
Bitte versuchen Sie Folgendes:
SchlieÃen Sie alle offenen Programme. Gehen Sie in den Ordner HD/Benutzer/(Benutzername)/Library/Application Support/Line 6.
Achtung, falls Sie Mac OSX Lion 10.7.x und 10.8.x benutzen ist der Ordner Library versteckt. Um diesen Ordner wieder anzeigen zu lassen müssen Sie die Terminal Konsole im Programme/ Dienstprogramme Ordner Ihres Macs starten. Sobald Terminal geöffnet ist geben Sie in die Konsole Folgendes ein:
chflags nohidden ~/Library
Drücken Sie Enter. Es wird Ihnen dann jedoch nicht angezeigt ob es funktioniert hat bis auf ein neues Terminal Fenster.
Nun, da Ihr Library Ordner sichtbar ist gehen Sie zum Mac HD/Users/(username)/Library/Application Support/Line 6 Ordner.
[*]CTRL + Klick auf den Line 6 Ordner und klicken Sie dann auf Informationen. Ãberprüfen Sie die Freigaben und Zugriffsrechte unten im Fenster und sehen Sie nach ob diese auf "Nur Lesen" stehen. Wenn dem so ist können Sie diese Einstellung hier auf Lesen & Schreiben umstellen.
[*]Starten Sie den License Manager und loggen Sie sich ein.
[*]Nachdem Sie eingeloggt sind, sollten im oben genannten Line 6 Ordner nun die neuen Menüpunkte wie Guitarport, der License Manager und eine L6system Datei angezeigt werden.
[*]SchlieÃen Sie den License Manager und überprüfen Sie Ihr POD Farm 2.5x standalone innerhalb Ihrer DAW nocheinmal.
3. Die Verstärkermodelle sind auf POD Farm 2.0 oder älter nicht mehr verfügbar nachdem 2.5x installiert wurde:
Dies war ein Problem mit der Version 2.50 und wurde mit 2.51 behoben.
Windows:
Deinstallieren Sie POD Farm 1 und POD Farm 2 vollständig anhand des Line 6 Uninstallers im Alle Programme/Line 6/Tools Ordner.
Laden Sie sich die neuste Version von POD Farm 2.5x von unserer Line 6 Webseite herunter.
Wenn Sie POD Farm 1 ebenfalls auf dem Computer haben müssen, müssen Sie POD Farm 1.12 installieren BEVOR Sie POD Farm 2.5x installieren.
[*]Mac:
Werfen Sie alle Versionen der POD Farm 1 oder 2 in den Papierkorb aus dem Programme/Line 6 Ordner.
Suchen Sie manuell in den folgenden Ordner und löschen Sie alle Dateien, die in diesen Ordnern sind:
Library/Audio/Plug-Ins/Components
Library/Audio/Plug-Ins/VST
Library/Frameworks (suchen Sie hier nach L6WXTG und L6WXTY und löschen Sie diese)
Programme/Line 6
Benutzer/Dokumente/Line 6
Benutzer/Library/Preferences (Line 6 Dateien sollten hier so aussehen: com.line6.xxxx, etc. Löschen.)
[*]Leeren Sie dann den Papierkorb.
[*]Dann gehen Sie zu Programme/Dienstprogramme und starten Terminal, geben Sie folgendes in die Konsole ein:
Cd // (Enter drücken)
Cd /Private/var/db/receipts (Enter)
Sudo rm âi com.line6 (Enter)
Geben Sie nun Ihr Benutzerpasswort des Macs ein. Achtung: Ihr Kursor wird nicht anzeigen, dass Zeichen eingegeben werden. Geben Sie Ihr Passwort korrekt ein und drücken sie Enter.
Drücken Sie bei allen Optionen/Fragen Ja um restliche Line 6 Software Komponenten zu entfernen. (Sie werden hier relativ oft bestätigen müssen.)
[*]Laden Sie POD Farm 2.5x von unserer Webseite herunter und installieren Sie dieses.
4. RTAS Plug-Ins starten nicht nachdem ich POD Farm 2.5 gestartet habe.
Eine Fehlermeldung erscheint beim Start: "Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged." AuÃerdem listet es die POD Farm 2 und POD Farm Elements Plug-Ins unterhalb der Nachricht auf.
Das ist ein Windows Problem und scheint in Verbindung zu stehen mit veraltetem oder nicht korrekt installiertem Microsoft Visual C++ Redistributable. Dieses Problem kann meist anhand des Windows Updates gelöst werden, da es Visual C++ auch aktualisiert und POD Farm 2.5 nur so Zugriff auf benötgte Bibliotheken erhält.
5. POD Farm 2.5x Plug-Ins zeigen falsche Grafiken oder Benutzeroberflächen an.
Falls Sie einen benutzerdefinierten Ort für Ihren Plug-Ins Ordner für Ihr DAW benutzen sollten Sie alle alten POD Farm 2 und POD Farm Elements Plug-In Dateien aus diesem Ordner entfernen und die neuen Dateien des POD Farm 2.55 Plug-Ins in diesen kopieren.
Windows XP: Die neuen Dateien sind in diesem Ordner: C:\Programme\Line6\POD Farm 2\VST\Line 6
Windows Vista/7 Dateien in diesem Ordner: C:\Programme (x86)\Line6\POD Farm 2\VST\Line 6
Mac OSX, AU Dateien in diesem Ordner: Mac HD\Library\Audio\Plug-Ins\Components
Mac OSX, VST Dateien im Ordner: Mac HD\Library\Audio\Plug-Ins\VST\Line 6
Dépannage POD Farm 2.5:
1. Le logiciel POD Farm autonome ("Standalone Mode") 2.5 n'a aucun signale d'entrée ou sortie si on le connecte avec une interface Line 6 Audio.
C'était un problème très connu avec la version 2.50 de POD Farm et était résous avec la version 2.51.
Windows: Désinstallez POD Farm 2.50, téléchargez et installez la version la plus récente de POD Farm 2.5x.
Mac: Désinstallez POD Farm 2.50 en suivant les instructions du problème prochain. Téléchargez et installez la version la plus récente de POD Farm.
2. Si vous avez un des problèmes ci-dessous avec un Mac:
POD Farm 2.5x autonome ne peut pas être autorisé sur Mac.
POD Farm 2.5x se plante en mode autonome si vous changez des presets.
Pro Tools se plante si on assigne POD Farm 2.5x à une piste ou on change un preset en POD Farm.
Les configurations du plugin POD Farm 2.5x ne sont pas enregistrées du projet Pro Tools après j'en ai enregistré, fermé et redémarré.
Essayez ceci:
Fermez tous les programmes ouverts. Allez dans le dossier HD/Utilisateur/(nom utilisateur)/ Library/Application Support/Line 6.
Attention, si vous utilisez Mac OSX Lion 10.7.x ou 10.8.x, le dossier Library est caché. Pour afficher ce dossier, vous devez ouvrir le Terminal dans le dossier Applications/Utilitaires de votre Mac. Quand Terminal est ouvert, entrez:
Appuyez Entrée. Rien ne se passe, mais une fenêtre s'ouvre avec un nouveau terminal.
Maintenant, votre dossier Library est visible. Naviguer au dossier: HD/Utilisateurs/(nom utilisateur)/Library/Application Support/Line 6.
[*]CTRL + click le dossier Line 6 et cliquez informations. Vérifiez Partage et permissions inférieur de la fenêtre et changez Lire seulement à Lire et écrire si besoin.
[*]Démarrez le License Manager et connectez à votre compte Line 6.
[*]Après vous êtes connecté, vous pouvez voir, dans le dossier ci-dessus, les éléments comme Guitarport, le License Manager ou le fichier L6system.
[*]Fermez le License Manager et vérifiez votre POD Farm 2.5x autonome encore une fois dans votre DAW.
3. Les modèles amplificateur ne sont plus disponibles sur POD Farm 2.0 ou plus ancien si on a installé la mise à jour 2.5x:
Windows:
Désinstallez POD Farm 1 et POD Farm 2 complètement en utilisant le Line 6 Uninstaller dans le dossier Tous les programmes/Line 6/Tools.
Téléchargez la version la plus récente de POD Farm 2.5x de notre site web.
Si vous avez besoin de POD Farm 1 sur votre ordinateur, vous devez installer POD Farm 1.12 AVANT installer POD Farm 2.5x.
[*]Mac:
Mettez tous les versions de POD Farm 1 ou 2 du dossier Applications/Line 6 dans la corbeille.
Cherchez manuellement dans les dossiers suivants et supprimez tous les fichiers dans ces dossiers:
Library/Frameworks (cherchez pour L6WXTG et L6WXTY et supprimez-les)
Applications/Line 6
Utilisateur/Documents/Line 6
Utilisateur/Library/Preferences (les fichiers Line 6 ressemblent à ceci: com.line6.xxxx, etc. Supprimer.)
[*]Videz la corbeille.
[*]Naviguer à Applications/Utilitaires et démarrez Terminal. Entrez le suivant:
Cd // (appuyez Entrée)
Cd /Private/var/db/receipts (Entrée)
Sudo rm âi com.line6 (Entrée)
Entrez votre mot de passe utilisateur du Mac. Attention, votre curseur ne montre pas que vous entrez des caractères. Entrez votre mot de passe et appuyez Entrée.
Cliquez Oui pour tous les options/questions pour supprimer tous les components de logiciel Line 6 restant.
[*]Téléchargez et installez POD Farm 2.5x de notre site web.
4. Les plugins RTAS ne démarrent pas après j'ai démarré POD Farm 2.5.
Un message d'erreur s'ouvre au démarrage: "Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged." Il montre également une liste des plugins POD Farm 2 et POD Farm Elements sous ce message.
Ceci est un problème Windows en connexion avec le logiciel Microsoft Visual C++ Redistributable installé qui n'est pas à jour ou pas installé correctement. Ce problème peut-être résous avec le Mise à Jour de Windows. POD Farm a besoin des bibliothèques installées avec des mises à jour de Visual C++.
5. Les plugins POD Farm 2.5x affichent des graphiques et interfaces d'utilisateur faux.
Si vous utilisez un emplacement personnalisé de votre dossier des plugins pour votre DAW, vous devez supprimer tous les fichiers du ancien POD Farm 2 ou POD Farm Elements et copiez les nouveaux fichiers du plugin POD Farm 2.55 dans ce dossier.
Windows XP: Les nouveaux fichiers sont dans ce dossier: C:\Programmes\Line6\POD Farm 2\VST\Line 6
Windows Vista/7 fichiers dans ce dossier: C:\Programmes (x86)\Line6\POD Farm 2\VST\Line 6
Mac OSX, fichiers AU dans ce dossier: Mac HD\Library\Audio\Plug-Ins\Components
Mac OSX, fichiers VST dans ce dossier: Mac HD\Library\Audio\Plug-Ins\VST\Line 6
