How to Update G10 Transmitter Firmware via Spider V Amps
Desplázate hacia abajo para ver las instrucciones en español.
Faites défiler la page vers le bas pour trouver des instructions en français.
Anweisungen auf Deutsch finden Sie weiter unten.
Per le istruzioni in Italiano scorrete verso il basso.
Overview: For those who have access to a Spider V (MKI or MKII) amp and wish to update the G10T Transmitter, it must be done in the order shown below (first update the amp, then the G10). We strongly suggest updating the amp with the latest version of the Line 6 Updater from a desktop/laptop computer, even though it is possible to update the amp from a mobile device.
Video Tutorial: Updating a Relay-Ready Spider V Amp and G10T Transmitter With a Mac Computer
Video Tutorial: Updating a Relay-Ready Spider V Amp and G10T Transmitter With a Windows Computer
I. Update the Spider V Amp Firmware With a Computer
  • First, (for Windows users) download and install the Spider V drivers
  1. Go to Line6.com and click on "Support"
  2. Select "Downloads" and set the three pulldown windows under "Free Software Downloads" to: [Spider V 60], [Line 6 Drivers], [your PC OS]
  3. Click "GO"
  4. The page will update with the Line 6 drivers for the Spider V. Click 'GET DOWNLOAD' to download the driver installer to your computer.
  5. Log in to your free Line 6 User account (or create a new account)
  6. Click on 'ACCEPT AND DOWNLOAD' and follow the instructions to save the driver installer
  7. When the installer has been downloaded, double-click on it and follow the instructions to install it in your computer
  • Next,
    download and install the Line 6 Updater for Spider V
  2. Select "Downloads" and set the three pulldown windows under"Free Software Downloads" to: [spider V 30], [Line 6 Updater], [your Mac or PC OS]
  3. Click "GO"
  4. The page will update with the Line 6 Updater for the Spider V. Click 'GET DOWNLOAD' to download the updater program to your computer.
  5. Click on 'ACCEPT AND DOWNLOAD' and follow the instructions to save the updater installer
  6. When the program has been downloaded, double-click on it and follow the instructions to install it in your computer
  • Lastly, update the Spider V amp
  1. Connect the Spider V’s USB port to your computer with a traditional USB cable
  2. Slide the "SELECT" switch to the USB port labeled Mac/PC
  3. Turn the amp on
  4. Open the Line 6 Updater application and sign in with your Line 6 User Account
  5. Click on the Spider V amp
  6. Click the “Update” button next to the latest firmware version at the top
  7. Follow the prompts to begin the update process
  8. Do not turn off or unplug your Spider V or computer during the update
  9. Watch for the update status to be completed on the Spider V LCD. Once completed, the amp will restart.
  10. Disconnect and reconnect the USB cable, then repeat the process for the G10T Transmitter
Note:
If you experience a failed update or your amp locks up during boot up, you can hold down the Amp and FX buttons to enter Update Mode. Once it's in Update Mode, attempt the update procedure again.
II. Update the G10T Firmware with the Spider V Amp
  • Make sure the Spider V amp is still connected to the computer, and that the computer is still connected to the internet
  • Insert the G10T all the way into the Spider's Input jack
  • Ensure that the "SELECT" switch is still engaged with the USB port labeled "Mac/PC". Turn on your Spider amp if it's off.
  • Run the Line 6 Updater program. Sign in to your Line 6 User Account.
  • Click on “Relay G10T”
  • Click the “Update” button next to the latest firmware version. Follow the prompts to begin the update process. Important: Do not turn off or unplug your Spider V amp or computer during the update.
  • The Updater will say the amp is resetting, but take note of the amp's display, as it will continue updating, ultimately showing "Part 1 of 1 100% Updating Transmttr". The amp will reset itself, ending the update process.
Cómo actualizar el firmware del transmisor G10 mediante los amplificadores Spider V
Descripción general: Aquellos usuarios que dispongan de un amplificador Spider V (MKI o MKII) y deseen actualizar el transmisor G10T, el proceso debe realizarse en el orden indicado a continuación (primero actualizar el amplificador y luego el G10). Recomendamos encarecidamente actualizar el amplificador con la última versión del Line 6 Updater desde un ordenador de sobremesa/portátil, aunque puede hacerse desde un dispositivo móvil.
Tutorial en vídeo: Actualizar un transmisor G10T y un amplificador Spider V compatible con Relay con un ordenador Mac
Tutorial en vídeo: Actualizar un transmisor G10T y un amplificador Spider V compatible con Relay con un ordenador Windows
I. Actualizar el firmware del amplificador Spider V con un ordenador
  • En primer lugar, (para usuarios de Windows) descarga e instala los controladores del Spider V
  1. Visita Line6.com y haz clic en [Soporte]
  2. Selecciona “Downloads” y, en las tres ventanas desplegables de “Free Software Downloads”, selecciona “Spider V 60”, “Line 6 Drivers”, “el sistema operativo de tu PC”.
  3. Haz clic en [GO].
  4. La página se actualizará con los controladores de Line 6 para el Spider V. Haz clic en [GET DOWNLOAD] para descargar el instalador del controlador en tu ordenador.
  5. Inicia sesión en tu cuenta de usuario gratuita de Line 6 (o bien crea una cuenta nueva).
  6. Haz clic en [ACCEPT AND DOWNLOAD] y sigue las instrucciones para guardar el instalador del controlador.
  7. Una vez descargado el instalador, haz doble clic en él y sigue las instrucciones para instalarlo en tu ordenador.
  • A continuación, descarga e instala el Line 6 Updater para Spider V
  1. Visita Line6.com y haz clic en [Soporte].
  2. Selecciona “Downloads” y, en las tres ventanas desplegables de “Free Software Downloads”, selecciona “Spider V 30”, “Line 6 Updater”, “el sistema operativo de tu Mac o PC”.
  4. La página se actualizará con el actualizador Line 6 para el Spider V. Haz clic en [GET DOWNLOAD] para descargar el programa del actualización en tu ordenador.
  5. Haz clic en [ACCEPT AND DOWNLOAD] y sigue las instrucciones para guardar el instalador del actualizador.
  6. Una vez descargado el programa, haz doble clic en él y sigue las instrucciones para instalarlo en tu ordenador.
  • Por último, actualiza el amplificador Spider V
  1. Conecta el puerto USB del Spider V a tu ordenador con un cable USB tradicional.
  2. Desliza el conmutador SELECT hasta el puerto USB marcado como Mac/PC.
  3. Activa el amplificador.
  4. Abre la aplicación Line 6 Updater e inicia sesión con tu cuenta de usuario de Line 6.
  5. Haz clic en el amplificador Spider V.
  6. Haz clic en el botón [Update] situado junto a la última versión del firmware en la parte superior.
  7. Sigue las instrucciones para empezar el proceso de actualización.
  8. No desactives ni desconectes tu Spider V ni el ordenador durante la actualización.
  9. Consulta el estado de la actualización en la pantalla LCD de Spider V. Una vez completada, el amplificador se reiniciará.
  10. Desconecta y vuelve a conectar el cable USB; a continuación, repite el proceso para el transmisor G10T.
Nota:
Si falla la actualización o si tu amplificador se bloquea durante el arranque, puedes mantener pulsados los botones AMP y FX para entrar en el modo Update. Una vez en el modo Update, intenta realizar nuevamente el procedimiento de actualización.
II. Actualizar el firmware del G10T con el amplificador Spider V
  • Comprueba que el amplificador Spider V sigue conectado al ordenador y que éste sigue conectado a Internet.
  • Inserta totalmente el G10T en el jack de entrada del Spider.
  • Comprueba que el conmutador SELECT sigue conectado al puerto USB marcado como “Mac/PC”. Activa el amplificador Spider si está desactivado.
  • Ejecuta el programa Line 6 Updater. Inicia sesión en tu cuenta de usuario de Line 6.
  • Haz clic en [Relay G10T].
  • Haz clic en el botón [Update] situado junto a la última versión del firmware. Sigue las instrucciones para empezar el proceso de actualización. Importante: No desactives ni desconectes tu amplificador Spider V ni el ordenador durante la actualización.
  • El Updater notificará que el amplificador se está reiniciando, pero observa la pantalla del amplificador, ya que continuará actualizándose y, al final, mostrará “Part 1 of 1 100% Updating Transmttr”. El amplificador se reiniciará, finalizando el proceso de actualización.
Mise à jour du système de l’émetteur G10 via les amplis Spider V
Aperçu: Si vous disposez d’un ampli Spider V (MKI ou MKII) et souhaitez mettre l’émetteur G10T à jour, suivez impérativement l’ordre indiqué ci-dessous (mise à jour de l’ampli avant celle du G10). Nous recommandons vivement de mettre l’ampli à jour avec la dernière version de l’application Line 6 Updater à partir d’un ordinateur fixe ou portable même s’il est possible de le faire à partir d’un dispositif mobile.
Tutoriel vidéo: Mise à jour d’un ampli Spider V compatible Relay et d’un émetteur G10T avec un ordinateur Mac
Tutoriel vidéo: Mise à jour d’un ampli Spider V compatible Relay et d’un émetteur G10T avec un ordinateur Windows
I. Mise à jour du système de l’ampli Spider V avec un ordinateur
  • (Pour utilisateurs Windows) Commencez par télécharger et installer les pilotes Spider V.
  1. Rendez-vous sur Line6.com et cliquez sur [Assistance].
  2. Sélectionnez «Downloads» et réglez les trois menus déroulants sous «Free Software Downloads» sur «Spider V 60», «Line 6 Drivers», «le système de votre ordinateur».
  3. Cliquez sur [GO].
  4. La page affiche les pilotes Line 6 pour le Spider V. Cliquez sur [GET DOWNLOAD] pour télécharger l’installeur de pilote sur votre ordinateur.
  5. Connectez-vous à votre compte utilisateur Line 6 gratuit (ou créez un compte).
  6. Cliquez sur [ACCEPT AND DOWNLOAD] et suivez les instructions pour sauvegarder l’installeur de pilote.
  7. Quand l’installeur est téléchargé, double-cliquez dessus et suivez les instructions pour l’installer sur votre ordinateur.
  • Ensuite, téléchargez et installez l’application Line 6 Updater pour Spider V.
  2. Sélectionnez «Downloads» et réglez les trois menus déroulants sous «Free Software Downloads» sur «Spider V 30», «Line 6 Updater», «votre système Mac ou PC».
  4. La page affiche l’application Line 6 Updater pour le Spider V. Cliquez sur [GET DOWNLOAD] pour télécharger l’application de mise à jour sur votre ordinateur.
  5. Cliquez sur [ACCEPT AND DOWNLOAD] et suivez les instructions pour sauvegarder l’installeur de l’Updater.
  6. Quand le programme a été téléchargé, double-cliquez dessus et suivez les instructions pour l’installer sur votre ordinateur.
  • Pour finir, mettez l’ampli Spider V à jour
  1. Branchez la prise USB du Spider V à votre ordinateur avec un câble USB conventionnel.
  2. Faites glisser le commutateur SELECT sur le port USB Mac/PC.
  3. Mettez l’ampli sous tension.
  4. Ouvrez l’application Line 6 Updater et identifiez-vous avec votre compte utilisateur Line 6.
  5. Cliquez sur l’ampli Spider V.
  6. Cliquez sur le bouton [Update] à côté de la version la plus récente du système en tête de liste.
  7. Suivez les instructions pour lancer la mise à jour.
  8. N’éteignez pas et ne débranchez pas le Spider V ou l’ordinateur durant la mise à jour.
  9. Surveillez l’évolution de la mise à jour sur l’écran LCD du Spider V. A la fin, l’ampli redémarre.
  10. Débranchez et rebranchez le câble USB puis recommencez l’opération pour l’émetteur G10T.
Remarque:
Si la mise à jour échoue ou si votre ampli se bloque durant le redémarrage, maintenez les boutons AMP et FX enfoncés pour passer en mode Update. Une fois en mode Update, recommencez la procédure de mise à jour.
II. Mise à jour du système du G10T avec l’ampli Spider V
  • Vérifiez que l’ampli Spider V est toujours connecté à l’ordinateur et que l’ordinateur est toujours connecté à internet.
  • Insérez le G10T à fond dans la prise Input du Spider.
  • Vérifiez que le commutateur SELECT est toujours réglé sur le port USB Mac/PC. Allumez l’ampli Spider s’il est éteint.
  • Lancez l’application Line 6 Updater. Identifiez-vous avec votre compte utilisateur Line 6.
  • Cliquez sur [Relay G10T].
  • Cliquez sur le bouton [Update] à côté de la version la plus récente du système. Suivez les instructions pour lancer la mise à jour. Important: N’éteignez pas et ne débranchez pas le Spider V ou l’ordinateur durant la mise à jour.
  • L’Updater signale que l’ampli se réinitialise mais surveillez l’écran de l’ampli qui finira par afficher «Part 1 of 1 100% Updating Transmttr». L’ampli se réinitialise alors, concluant ainsi la mise à jour.
Firmware-Aktualisierung des G10-Senders mit einem Spider V-Verstärker
Vorweg: Wer Zugriff auf einen Spider V (MKI oder MKII) Verstärker hat und seinen G10T-Sender aktualisieren möchte, muss in der nachfolgend beschriebenen Reihenfolge vorgehen (erst der Amp, dann der G10). Wir möchten Ihnen ans Herz legen, den Verstärker mit der aktuellen Line 6 Updater-Version von einem Computer/Laptop aus zu aktualisieren, wenngleich dies auch mit einem Mobilgerät möglich ist.
Video-Tutorial: Aktualisieren eines Relay-fähigen Spider V-Verstärkers und des G10T-Senders mit einem Mac-Computer
Video-Tutorial: Aktualisieren eines Relay-fähigen Spider V-Verstärkers und des G10T-Senders mit einem Windows-Computer
I. Aktualisieren der Spider V-Verstärker-Firmware mit einem Computer
  • (Für Windows-Anwender:) Laden Sie sich die Spider V-Treiber herunter und installieren Sie sie
  1. Surfen Sie zu Line6.com und klicken Sie auf [Support].
  2. Wählen Sie “Downloads” und mit den drei Listenfenstern unter “Free Software Downloads” zunächst “Spider V 60”, dann “Line 6 Drivers” und Ihr Computer-Betriebssystem.
  3. Klicken Sie auf [GO].
  4. Jetzt werden die Line 6-Treiber für die Spider V-Amps angezeigt. Klicken Sie auf [GET DOWNLOAD], um sich den Treiber herunterzuladen.
  5. Loggen Sie sich in Ihr Line 6-Benutzerkonto ein (oder legen Sie sich ein Konto an).
  6. Klicken Sie auf [ACCEPT AND DOWNLOAD] und befolgen Sie die Hinweise zum Sichern des Installationsprogramms.
  7. Doppelklicken Sie auf das heruntergeladene Installationsprogramm und befolgen Sie die Hinweise für die Installation auf dem Rechner.
  • Laden Sie sich jetzt den “Line 6 Updater” für den Spider V herunter
  2. Wählen Sie “Downloads” und mit den drei Listenfenstern unter “Free Software Downloads” zunächst “Spider V 30”, dann “Line 6 Updater” und Ihr Computer-Betriebssystem.
  4. Jetzt werden die Line 6 Updater-Treiber für die Spider V-Amps angezeigt. Klicken Sie auf [GET DOWNLOAD], um sich das Updater-Programm herunterzuladen.
  5. Klicken Sie auf [ACCEPT AND DOWNLOAD] und befolgen Sie die Hinweise zum Sichern des Updaters.
  6. Doppelklicken Sie auf das heruntergeladene Programm und befolgen Sie die Hinweise für die Installation auf dem Rechner.
  • Aktualisieren Sie Ihren Spider V-Verstärker
  1. Schließen Sie den USB-Port des Spider V mit einem geeigneten Kabel an den Computer an.
  2. Schieben Sie den SELECT-Schalter zum USB-Port mit der Beschriftung “Mac/PC”.
  3. Schalten Sie den Verstärker ein.
  4. Öffnen Sie den “Line 6 Updater” und loggen Sie sich in Ihr Line 6-Konto ein.
  5. Klicken Sie auf [Spider V].
  6. Klicken Sie auf den [Update]-Button neben der aktuellen Firmware-Version (ganz oben).
  7. Befolgen Sie die Anweisungen, um die Aktualisierung zu starten.
  8. Schalten Sie den Spider V bzw. Computer bei laufender Aktualisierung nicht aus und lösen Sie nie die Verbindung.
  9. Das LC-Display des Spider V informiert über den Fortgang der Aktualisierung. Am Ende des Vorgangs wird der Amp neu gestartet.
  10. Lösen Sie die USB-Verbindung und Wiederholen Sie den Vorgang für den G10T-Sender.
Anmerkung:
Wenn die Aktualisierung fehlschlägt oder der Verstärker beim Hochfahren hängen bleibt, können Sie den AMP- und FX-Taster gedrückt halten, um in den Update-Modus zu wechseln. Wiederholen Sie die Aktualisierung im Update-Modus noch einmal.
II. Aktualisieren der G10T-Firmware mit dem Spider V-Verstärker
  • Der Spider V-Verstärker muss noch mit dem Computer verbunden sein – und der Rechner muss einen Internetzugang haben.
  • Schieben Sie den G10T komplett in die INPUT-Buchse des Spider.
  • Schieben Sie den SELECT-Schalter zum USB-Port namens “Mac/PC”. Schalten Sie den Spider-Verstärker bei Bedarf ein.
  • Starten Sie “Line 6 Updater”. Loggen Sie sich in Ihr Line 6-Benutzerkonto ein.
  • Klicken Sie auf [Relay G10T].
  • Klicken Sie auf den [Update]-Button neben der aktuellen Firmware-Version. Befolgen Sie die Anweisungen, um die Aktualisierung zu starten. Wichtig: Schalten Sie den Spider V bzw. Computer bei laufender Aktualisierung nicht aus und lösen Sie nie die Verbindung.
  • Der “Updater” zeigt an, dass der Verstärker zurückgestellt wird. Im Display des Amps wird der Fortgang der Aktualisierung angezeigt und wenig später “Part 1 of 1 100% Updating Transmttr”. Der Verstärker wird schließlich zurückgestellt – die Aktualisierung ist beendet.
Come Aggiornare il Firmware del Trasmettitore G10 tramite Amplificatori Spider V
Panoramica: Coloro che hanno a disposizione un ampli Spider V (MKI o MKII) e vogliono aggiornare il Trasmettitore G10T, dovranno farlo seguendo l’ordine indicato qui di seguito (prima aggiornare l’ampli, poi il G10) Sebbene sia possibile farlo anche da dispositivo mobile, vi consigliamo vivamente di aggiornare l’ampli con l’ultima versione del Line 6 Updater da un computer desktop/laptop.
Tutorial Video: Aggiornare un Ampli Spider V Relay-Ready e un Trasmettitore G10T Con un Computer Mac
Tutorial Video: Aggiornare un Ampli Spider V Relay-Ready e un Trasmettitore G10T Con un Computer Windows
I. Aggiornare il firmware di un Ampli Spider V Con un Computer
  • Prima di tutto, (per utenti Windows) scaricate e installate i driver dello Spider V
  1. Andate su Line6.com e cliccate su [Support]
  2. Scegliete “Downloads” e selezionate nei tre menu a discesa di “Free Software Downloads” “Spider V 60”, “Line 6 Drivers” e “sistema operativo del vostro PC”.
  3. Cliccate [GO].
  4. La pagina si aggiornerà con i driver Line 6 per lo Spider V. Cliccate [GET DOWNLOAD] per scaricare sul vostro computer l’installer del driver.
  5. Loggatevi con il vostro account gratuito Line 6 (o create un nuovo account).
  6. Cliccate [ACCEPT AND DOWNLOAD] (Accetta e Scarica) e seguite le istruzioni per salvare l’installer del driver.
  7. Quando l’installer è stato scaricato, per installarlo sul vostro computer fate doppio click su di esso e seguite le istruzioni.
  • Poi, scaricate e installate Line 6 Updater per lo Spider V
  1. Andate su Line6.com e cliccate su [Support].
  2. Scegliete “Downloads” e selezionate nei tre menu a discesa di “Free Software Downloads” “Spider V 30”, “Line 6 Updater” e “sistema operativo Mac o PC”.
  3. Cliccate [GO].
  4. La pagina si aggiornerà con l’Updater Line 6 per lo Spider V. Cliccate [GET DOWNLOAD] per scaricare sul vostro computer il programma di aggiornamento (Updater).
  5. Cliccate [ACCEPT AND DOWNLOAD] (Accetta e Scarica) e seguite le istruzioni per salvare l’installer dell’Updater.
  6. Quando il programma è stato scaricato, per installarlo sul vostro computer fate doppio click su di esso e seguite le istruzioni.
  • Infine, aggiornate l’ampli Spider V
  1. Collegate la porta USB dello Spider V al computer con un normale cavo USB.
  2. Spostate il selettore SELECT sulla porta USB contrassegnata con Mac/PC.
  3. Accendete l’ampli.
  4. Aprite l’applicazione Line 6 Updater e registratevi con il vostro Account Line 6.
  5. Cliccate sull’ampli Spider V.
  6. Cliccate il pulsante [Update] in alto vicino all’ultima versione del firmware.
  7. Per iniziare l’aggiornamento seguite le istruzioni.
  8. Durante l’aggiornamento non spegnete né scollegate lo Spider V o il computer.
  9. Verificate sull’LCD dello Spider V che l’aggiornamento sia completato. Al termine, l’ampli si riavvierà.
  10. Scollegate e ricollegare il cavo USB, poi ripetete il procedimento per il Trasmettitore G10T.
Nota:
Se l’aggiornamento non va a buon fine o l’ampli si blocca all’accensione, tenete premuti i pulsanti AMP e FX per entrare in modalità Update. Una volta in modalità Update, eseguite di nuovo la procedura di aggiornamento.
II. Aggiornare il firmware del G10T con l’Ampli Spider V
  • Assicuratevi che l’ampli Spider V sia ancora collegato al computer e che il computer sia collegato ad internet.
  • Inserite completamente il G10T nel jack di ingresso dello Spider.
  • Assicuratevi che il selettore SELECT sia ancora posizionato sulla porta USB contrassegnata “Mac/PC”. Accendete il vostro Ampli Spider, se è spento.
  • Lanciate il programma Line 6 Updater. Eseguite il login al vostro Account Line 6.
  • Cliccate su [Relay G10T].
  • Cliccate il pulsante [Update] vicino all’ultima versione del firmware. Per iniziare l’aggiornamento seguite le istruzioni. Importante: Durante l’aggiornamento non spegnete né scollegate lo Spider V o il computer.
  • L’Updater indicherà che l’ampli si sta resettando, ma voi guardate lo schermo dell’ampli, che continuerà l’aggiornamento, finché al termine scriverà “Part 1 of 1 100% Updating Transmttr”. L’ampli si resetterà, terminando il procedimento di aggiornamento.
