Sonic Port VX/Sonic Port Connections
Deutsch
Français
SONIC PORT VX CONNECTIONS
1. Before connecting the Sonic Port VX, check your iPad, iPhone or iPod touch to be sure you have the latest version of the iOS operating system installed. Instructions for updating your iOS device are available HERE.
2. In order to enjoy POD® amp and effects processing, you'll need our free Mobile POD application. The Mobile POD app also provides firmware updates to the Sonic Port VX hardware.
If your iPad, iPhone or iPod touch has internet access, we recommend that you first download and install our Mobile POD app from the App Store app before you attach your Sonic Port VX for the first time. Simply search for 'Mobile POD' on the app store to find and download the Mobile POD app.
3. If you are using the Sonic Port VX with a iOS device, connect Sonic Port VX to your iPad, iPhone or iPod touch using the included 14-pin to Lightning connector cable. The Sonic Port VX has a red LED located on it's top side that will blink once a few seconds after the Sonic Port VX is successfully recognized by your iOS device. If you want to power/charge your iOS device (Lightning only) while using the Sonic Port VX, you can additionally connect the supplied USB-mini cable from the Sonic Port VX into a iOS USB power supply. If you are using the Sonic Port VX with a Windows computer, first make sure and download the Sonic Port Windows Drivers from our software page HERE before you connect the Sonic Port to your computer. If you are using the Sonic Port VX with MAC OS X 10.9 or above computer you will not need to install any drivers. To connect the Sonic Port VX to your computer simply use the supplied USB-A to USB-mini cable to connect it to your computer. Click the photo below for an illustration of these connections:
4. Connect your 1/4" instrument or other audio source to Sonic Port VX or Sonic Port. The Sonic Port VX and Sonic Port can only use one input source at a time, it will use whichever input is connected to first:
  • Using Guitar In (mono): Connect a standard 1/4" guitar cable to the Sonic Port guitar input, then plug the other end into your guitar.
  • Using AUX IN : Connect a standard stereo 1/8" line cable to the Sonic Port VX AUX input, then plug the other end into a line level audio output of your source equipment such as a keyboard, drum machine, mixer, or music player.
5. Connect two mono 1/4" Tip Sleeve cables to the Sonic Port VX's individual Left and Right outputs, then plug the other ends into a playback device such as a mixer, studio monitors, or powered PA speakers to monitor your audio. You can also connect one mono 1/4" Tip Sleeve calbe to only the Sonic Port VX's left output and the Sonic Port VX will sum together both the Right and Left outputs to allow you to connect it to mono sources such as a guitar or bass amp. To connect a pair of headphones or desktop speakers to the Sonic Port VX simply connect the 1/8" stereo cable into the 1/8" Headphone output on the Sonic Port VX. Click the photo below for a illustration of these connections:
6. If you would like to set the Sonic Port VX up on a mic stand or the included tabletop stand start off by threading the supplied mic stand mount onto the base of the Sonic Port VX. If you would like to use the Sonic Port VX on a mic stand, you can then simply attach the mic stand mount to a mic stand. If you would like to use the included table top stand for the Sonic Port VX, place the mic stand mount onto the tabletop stand and fasten them together using the supplied 1/4" thread as shown in the illustration below:
We recommend that you place the Sonic Port VX at least 10" away from the source that you are trying to record with the built in mics. We also recommend that you use pop screen with the Sonic Port VX when you are recording vocals.
7. Once you have made all your connections launch the iOS or computer app of your choice and your ready to go.
SONIC PORT CONNECTIONS
1. Before connecting the Sonic Port, check your iPad, iPhone or iPod touch to be sure you have the latest version of the iOS operating system installed. Instructions for updating your iOS device are available HERE.
2. In order to enjoy POD® amp and effects processing, you'll need our free Mobile POD application. The Mobile POD app also provides firmware updates to the Sonic Port hardware.
If your iPad, iPhone or iPod touch has internet access, we recommend that you first download and install our Mobile POD app from the App Store app before you attach your Sonic Port for the first time. Simply search for 'Mobile POD' on the app store to find and download the Mobile POD app.
3. Connect the Sonic Port to your iPad, iPhone or iPod touch using the included 14-pin to Lightning connector cable or the 30 pin cable depending on your iOS device.The Sonic Port has a red LED located on it's top side that will blink once a few seconds after the Sonic Port is successfully recognized by your iOS device. Click the photo below for a illustration of this connection:
4. Connect your 1/4" instrument or other audio source to the Sonic Port. The Sonic Port can only use one input source at a time, it will use whichever input is connected to first:
  • Using IN L/R: Connect a standard stereo 1/8" line cable to the Sonic Port IN L/R input, then plug the other end into a line level audio output of your source equipment such as a keyboard, drum machine, mixer, or music player.
5. Connect a mono or stereo 1/4" cable to the Sonic Port OUT L/R output, then plug the other end into a playback device such as a guitar amp, mixer or powered speakers to monitor your audio. To connect a pair of headphones or desktop speakers to the Sonic Port simply connect the 1/8" stereo cable into the 1/8" Headphone output on the Sonic Port. Click the photo below for a illustration of these connections:
6. Once you have made all your connections launch the iOS app of your choice and your ready to go.
Sonic Port Anschlüsse:
1. Bevor Sie fortfahren, sollten Sie Ihr iPad, iPhone oder iPod touch auf die neueste Version des iOS überprüfen.
2. Bevor Sie aber die Effekt- und Verstärkerverarbeitung des POD® nutzen können benötigen Sie unsere gratis Mobile POD App, welche außerdem für Firmware Updates Ihres Sonic Ports sorgt. (Firmware ist Software für den Mikroprozessor Ihres Sonic Ports und bereits in diesem enthalten, sie braucht jedoch Updates von Zeit zu Zeit genau wie Software auf Ihrem PC.)
Wenn Ihr iPad, iPhone oder iPod touch Verbindung zum Internet hat, wird es Ihnen automatisch helfen die Mobile POD App herunterzuladen, sobald Sie das Sonic Port anschließen. Ansonsten empfehlen wir Ihnen einfach die App von Hand herunterzuladen; suche Sie dazu im App Store nach "Mobile POD", klicken Sie auf "Kaufen" und installieren Sie diese im Anschluss.
3. Schließen Sie nun Ihr Sonic Port an Ihr iPad, iPhone oder iPod touch an indem Sie das 14-Pin zu Lightning Kabel oder das 30 pin kabel benutzen je nach Anschluss Ihres Gerätes. Das Sonic Port hat oben eine rote LED die 3 Sekunden lang blinkt sobald Ihr Apple Gerät das Sonic Port erkannt hat.
Wenn Sie Ihr iOS Gerät laden möchten während Sie das SonicPortVX verwenden (nur über Lightning möglich) verbinden Sie bitte das mitgelieferte USB-mini Kabel des SonicPort VX mit dem USB-Netzteil Ihres iOS Gerätes. Sollten Sie das SP VX unter Windows verwenden, installieren Sie bitte zuerst den SonicPort VX Windows Treiber (bevor Sie das Interface anschliessen).Falls Sie MacOSX10.9 oder neuer verwenden muss kein Treiber installiert werden.Um das SonicPort VX mit dem Computer zu verbinden verwenden Sie bitte das mitgelieferte USB-A auf USB-mini Kabel.
4. Verbinden Sie Ihre Gitarre oder andere Audioquelle mit Ihrem Sonic Port. Sie können nur jeweils eine Audioquelle gleichzeitig an Ihr Sonic Port anschliessen.
  • Unter Verwendung des "Guitar IN" (mono) können Sie Ihr standardmäßiges 6.3mm Gitarrenkabel an den "Guitar IN" des Sonic Ports und das andere Ende an Ihre Gitarre anschließen.
  • Unter Verwendung des "IN L/R" können Sie ein standardmäßiges 3.5mm Kabel an den "IN L/R" Ihres Sonic Ports und dann das andere Ende an den Ausgang Ihrer Tonquelle, wie z.B. ein Keyboard, Mixer oder Musik-Player, anschließen.
5. Schliessen Sie ein Mono oder Stereo 6.3mm Kabel an den "OUT L/R" Ausgang Ihres Sonic Ports an, dann stecken Sie das andere Ende in Ihr Abhörgerät wie z.B. einen Gitarrenverstärker, Mixer oder Lautsprecher um Ihren Ton abzuhören. Sofern erwünscht, können auch Kopfhörer benutzt werden, diese müssen dann einfach an den 3.5mm Kopfhörer-Ausgang angeschlossen werden.
6. Starten Sie die Audio App Ihrer Wahl, wie zum Beispiel Garage Band® oder Mobile POD. Das Sonic Port Interface dient als Audio Input oder Output für jede App, die CoreAudio verwendet.
Connexions du Sonic Port:
1. Avant de procéder, vérifiez que l'iOS de votre iPad, iPhone ou iPod touch est à jour.
2. Avant que vous puissiez utiliser le traitement des effets et amplificateurs POD®, vous avez besoin de notre application gratuite Mobile POD, cette application fais également les mises à jours du firmware de votre Sonic Port. (le firmware est du logiciel, déjà inclus, pour le microprocesseur de votre Sonic Port mais de temps en temps, ce logiciel a besoin d'une mise à jour comme le logiciel sur votre ordinateur.
Si votre iPad, iPhone ou iPod touch a une connexion d'internet, il sera vous aider automatiquement de télécharger l'application Mobile POD, une fois vous connectez le Sonic Port avec votre appareil Apple®. Autrement, vous pouvez télécharger l'application vous-même par utiliser l'App Store, entrez "Mobile POD" et cliquez sur "Acheter". Installez l'application.
3. Vous pouvez connecter le Sonic Port avec votre iPad, iPhone ou iPod touch en utilisant le câble 14 broches à Lightning ou le 30 broches cable selon de la connexion de votre appareil IOS . Le Sonic Port a une LED rouge au-dessus qui clignote 3 secondes une fois votre appareil Apple® a reconnu le Sonic Port.
Si vous voulez charger votre appareil iOS (lightning seulement) en utilisant le Sonic Port VX vous pouvez connecter le cable “mini-USB� (fourni) avec l’alimentation USB. Si vous utilisez le Sonic Port VX avec un ordinateur Windows veuillez installer le pilote Sonic Port Windows par notre site d’internet ………avant connecter le Sonic Port avec votre ordinateur. Sous MacOSX10.9 ou plus récente ce n’est pas necessaire d’installer un pilote. Pour connecter Sonic Port VX avec votre ordinateur utilisez le cable USB-A vers USB-mini fourni.
4. Connecter votre guitare ou source audio avec votre Sonic Port. Vous pouvez attacher seulement une source audio à la fois.
  • En utilisant le "Guitar IN" (mono), vous pouvez prendre un câble 6.3mm classique et insérer le dans le "Guitar IN" du Sonic Port, connectez l'autre prise à votre guitare.
  • En utilisant le "IN L/R", vous pouvez prendre un câble 3.5mm standard et connecter une prise à "l'IN L/R" du Sonic Port et l'autre avec votre sortie audio comme par exemple un clavier, un lecteur de musique ou une table de mixage.
5. Connectez un câble 6.3mm stéréo ou mono avec la sortie "OUT L/R" de votre Sonic Port et connectez l'autre coté avec votre appareil monitoring comme par exemple un amplificateur de guitare, une table de mixage ou un haut-parleur. Si voulu, vous pouvez aussi connecter des écouteurs, vous devez les connecter avec la sortie 3.5mm pour les écouteurs.
6. Démarrez l'application audio de votre choix, par exemple Garage Band® ou Mobile POD. L'interface Sonic Port sert comme entrée et sortie audio pour n'importe quelle application qui utilise CoreAudio.
