OSX 10.9/GarageBand 10 won't authorize POD Farm 2
Version française.
Deutsche Version.
We have discovered that even if you've authorized your POD Farm 2 license with Line 6 License Manager, GarageBand 10 on OSX 10.9 will not allow you to use POD Farm as an AU plug-in on an audio track. The plug-in window launches showing that plug-in is not authorized. To ensure the plug-in is working as it should, we encourage you to test it on another DAW, such as Reaper, which is a free download.
GarageBand 10 changes the location where the authorization files are found. However, there's a workaround to try:
1. Authorize your computer (or Hardware / L6 Device) - using License Manager
2. Start up Pod Farm (not plugin) and see that things are working okay
3. Copy the entire ~/Library/Application Support/Line 6/GuitarPort folder
into:
~/Library/Containers/com.apple.garageband10/Data/Library/Application
(create that folder path as needed)
NOTE: You may get a pop-up from the OS asking you to lower your security settings to use this AU. You will not be allowed to use POD Farm, or other certain plug-ins, until this settings change is made.
If you continue to have issues with POD Farm 2 after trying the workaround, please contact Apple Support at the link below for assistance with configuring GarageBand's security settings to allow POD Farm 2 to be authorized:
https://www.apple.com/support/contact/
Nous avons découvert même si vous avez autorisé votre licence POD Farm 2 avec le Line 6 License Manager, GarageBand 10 sur OSX 10.9 ne vous laisse pas utiliser POD Farm comme AU plugin avec une piste audio. La fenêtre plugin s’ouvre mais le plugin n’est pas autorisé. Pour assurer le plug-in fonctionne comme il le devrait, testez le sur une autre DAW comme Reaper (logiciel gratuit).
Le logiciel GarageBand change l’emplacement des fichiers d’autorisation. Mais Il y en a une solution pour ce problème :
  1. Autorisez votre ordinateur (ou appareil Line 6) en utilisant le License Manager.
  2. Démarrez POD Farm (pas le plugin) et vérifiez si le programme fonctionne correctement.
  3. Copiez le dossier : ~/Bibliothèque/Application Support/Line 6/GuitarPort dans : ~/Bibliothèque/Containers/com.apple.garageband10/Data/Library/Application Support/Line 6/GuitarPort (Créez ce dossier si nécessaire)
Attention, c’est possible que vous ayez besoin de changer vos réglages de sécurité pour permettre POD Farm ou autres plugins de fonctionner.
Si vous continuez d'avoir des problèmes avec POD Farm 2 après cette solution, contactez le service clientèle d’Apple pour vous assister avec les configurations de sécurité pour GarageBand.
https://www.apple.com/fr/support/contact/
Wir haben festgestellt, dass nachdem Sie Ihre POD Farm Lizenz per Line 6 License Manager autorisiert haben, GarageBand unter OSX 10.9 Sie POD Farm als Plugin nicht verwenden lässt. Im Plugin Fenster wird das Plugin als nicht autorisiert angezeigt. Um sicher zu stellen, dass das Plugin korrekt funktioniert sollten Sie es zunächst mit einer anderen DAW testen, wie z.B. Reaper. (gratis Software)
GarageBand 10 verändert den Speicherort für die Dateien die notwendig sind zur Autorisation. Es gibt jedoch Abhilfe für dieses Problem:
  1. Autorisieren Sie Ihren Computer (oder Line 6 Hardware) anhand des License Managers.
  2. Starten Sie POD Farm (nicht das Plugin) und überprüfen Sie ob das Programm ordnungsgemäß funktioniert.
  3. Kopieren Sie dann den gesamten ~/Library/Application Support/Line 6/GuitarPort Ordner nach: ~/Library/Containers/com.apple.garageband10/Data/Library/Application Support/Line 6/GuitarPort (Erstellen Sie diesen Ordner falls notwendig.)
Achtung, eventuell öffnet sich hier ein Fenster um die Sicherheitseinstellungen zu verändern. Sie müssen diese verringern, damit POD Farm und andere Plugins funktionieren.
Sollten Sie weiterhin Probleme haben mit POD Farm 2 nach dieser Problembehebung, sollten Sie versuchen den Apple Kundendienst zu kontaktieren. Dort kann man Ihnen dann weiterhelfen, die Sicherheitseinstellungen korrekt zo verändern, sodass GarageBand POD Farm als Plugin benutzen kann.
https://www.apple.com/de/support/contact/
