Helix Stadium Native FAQ
What is Helix Stadium Native?
Helix Stadium Native is a plugin for your DAW that features all the amp, cab, and effects from Helix Stadium, as well as ProxyTM clone and Cab IR loading. Its presets are fully compatible with Helix Stadium XL and Helix Stadium Floor hardware so you can effortlessly transfer your tones from the studio to the stage and back again.
How is Helix Stadium Native different from the Helix Stadium app?
The Helix Stadium app is a remote macOS/Window editor and librarian for Helix Stadium hardware. Conversely, Helix Stadium Native includes all of Helix Stadium’s amps, preamps, cabs, effects, and other DSP solutions as a native plugin within your DAW software, without the need for Helix Stadium hardware. You can add as many instances of Stadium Native as your computer’s horsepower allows—in fact, it’s common for producers and engineers to add plugins like Helix Stadium Native not just on guitar and bass tracks, but also synths, vocals, drum busses, bagpipes, nose flutes, you name it. (Pro Tip: Modulation > Retro Reel sounds awesome on almost everything.)
Which plug-in formats are supported?
macOS: VST3, AU, and AAX
Windows: VST3 and AAX
The only thing I get over Helix Native is AgouraTM amps, right?
First, you get whatever Agoura amps are available now… and those we release in the future. But there are numerous other advantages:
  • Preset compatibility with Helix Stadium XL and Helix Stadium Floor
  • Can load Proxy Amp+Cab, Amp, Preamp, and Distortion/Overdrive/Fuzz pedal clones
  • 48 block locations (vs. 32)
  • Multiple splits and merges per path
  • Supports projects with sample rates up to 192kHz (OG Native was limited to 96kHz)
  • Unlimited preset locations, organized however you want (vs. 8 setlists)
  • Hundreds of favorites organized into nested folders (vs. 128 in a static list)
  • Unlimited Cab IR locations, organized however you want (vs. 128 in a static list)
  • 2x the base resolution for all Cab IRs
  • All cab blocks are now dual
  • Effects can be placed between linked amps and cabs
  • Sidechaining for Dynamics and select Filter blocks
  • Focus view—seamlessly morph between 5 distinct sounds per amp or effect
  • Graphic control of mic placement
  • Graphic view of IR curves
  • Graphic control of EQ
  • New 7-band parametric EQ with per-band bypass and adjustable filter slopes
  • Higher resolution model graphics
  • Selectable slider or knob view
  • Widening window creates multiple columns of sliders in slider view
  • Preset Info
  • Preset Clip (each factory preset contains a dry guitar/bass clip to hear it in context)
  • Double-click the name of any block parameter to display its definition
  • Input block trim
  • Mouse scroll wheel and trackpad now scrolls parameters; SHIFT-scroll wheel/trackpad adjusts focused parameter
  • Automation-assigned parameters are now displayed as names in the DAW’s automation list
  • Automation-assigned parameters now display values on the DAW track’s automation lanes
  • Preset search
  • Amp/cab/effect search
  • Cab IR search
  • Proxy clone search
  • Quick subcategory scroll
  • Improved needle and strobe tuner
  • Tuner can show either sharps or flats
And most importantly, this is just the beginning.
Can Stadium Native also import presets from OG Helix Native and Helix/HX hardware?
Yes, plus entire setlists from Helix Floor, Helix Rack, Helix LT, and Helix Native.
Can presets made in Helix Stadium Native be loaded into OG Helix Native or Helix/HX boxes?
No.
Can I disable Hardware Compatibility Mode to expand the simultaneous block count beyond that of Helix Stadium XL/Floor?
Yes, but only with the full and 15-day trial licenses.
How many computers can I install Stadium Native onto?
Licensing is tied to your Line 6 account and up to four computers can share a single license.
How much?
  • Helix Stadium Native—$399.99
  • Helix Stadium Native for registered Helix Stadium XL or Helix Stadium Floor owners—$99.99
  • Upgrade from Helix Native to Helix Stadium Native—$99.99
  • Upgrade from Pod Farm Platinum to Helix Stadium Native—$199.99
  • Upgrade from Pod Farm to Helix Stadium Native—$299.99
  • Oh, and there’s a free Intro license too
Wait. What do you mean free?
Download Helix Stadium Native for free and the first time you launch the plugin, you can choose to:
  1. Buy the full license (if not already purchased) to access its full set of amps (53 Agoura + 111 HX channels), cabs (46), and effects (274) —OR—
  2. Start a 15-day trial of its full set of amps (53 Agoura + 111 HX channels), cabs (46), and effects (274) —OR—
  3. Open the free Intro license version that can be used forever, but is limited to the following items:
Category
Items
Agoura Amps
  • US Luxe Black, based on* the Fender® Deluxe AB763 (Normal and Vibrato channels)
  • Essex TB30CC, based on* the Vox® AC-300CC (Normal and Top Boost channels)
  • Brit 2203MV, based on* the Marshall® JCM-800 (2203)
  • Revv 120 Red, based on* the Revv® Generator 120 (Red/High Gain Ch. 4)
  • Ampeg SVT-50th, based on* Ampeg® Heritage 50th Anniversary SVT® (Ch1 Normal, Ch1 Bright, Ch2 Normal, Ch2 Bright, and Jumped channels)
Proxy Clones
Amp+Cab, Amp, Preamp, and Distortion Proxy clone loading (limited to 4 clones per preset, whereas the full version supports up to 48 with Hardware Compatibility Mode off)
Cabs
  • 1x12 US Deluxe, captured from* the 1x12” Fender® Blackface Deluxe
  • 2x12 Silver Bell, captured from* the 2x12” Vox® AC-30 Silver Alnico
  • 4x12 1960A T75, captured from* the 4x12” Marshall® 1960A G12T-75
  • 4x12 Brit V30, captured from* the 4x12” Marshall® 1960AV V30
  • Ampeg 810 SVT AV, captured from* the 8x10” Ampeg® SVT® 810AV Heritage
Cab IRs
Cab Impulse Response loading
Distortions
  • Minotaur, based on* the Klon® Centaur
  • Scream 808, based on* the Ibanez® TS808 Tube Screamer®
  • Ratatouille Dist, based on* the Pro Co® RAT
  • Dark Dove Fuzz, based on* the Electro-Harmonix® Russian Big Muff®
Delays
  • Adriatic Delay, based on* the BOSS® DM-2 w/ Adrian Mod
  • Vintage Digital, Line 6® Original
  • Cosmos Echo, based on* the Roland® RE-201 Space Echo®
Reverbs
  • Dynamic Plate, Line 6® Original
  • Hot Springs, Line 6® Original
Modulations
  • Optical Trem, based on* the Fender® optical tremolo circuit
  • 60s Bias Trem, based on* the Vox® AC-15 Tremolo
  • Script Mod Phase, based on* the MXR® Phase 90
  • 70s Chorus, based on* the BOSS® CE-1
Dynamics
  • Deluxe Comp, Line 6® Original
  • Noise Gate (Input blocks only), Line 6® Original
EQ
  • 7-band Parametric, Line 6® Original
What’s the catch?
No catch.
What happens when the 15-day trial is up?
All instances of Stadium Native will then reflect the Intro amps, cabs, and effects above. You can upgrade to the full license at any time, and no extra plugin management is required—All existing DAW projects with the Intro set will suddenly reflect the full set.
The free Intro license doesn’t include exactly what I want! Why didn’t you give us [specific amp or effect] instead?
Huh. We’ll just have to give you your money back then.
I use OG Helix Native. Will upgrading to Stadium Native overwrite Helix Native instances in my DAW?
Nope. Stadium Native and Helix Native appear as separate plugins.
This is terrible timing. I JUST bought OG Helix Native!
No worries; there’s a 60-day grace period. If you purchased and registered Helix Native on or after June 4th 2026, you can upgrade to the full license of Helix Stadium Native for free.
Is Helix Native going away?
We’re keeping the $99.99 version for registered Helix Floor/Rack/LT and HX Effects/Stomp/Stomp XL owners so they can maintain preset compatibility, and we’ll continue to update all versions as Helix/HX hardware is updated (as well as provide maintenance updates). However, there’s no reason to buy the other versions so they’re being fully replaced by Helix Stadium Native.
When is Helix Stadium Native available for download?
Now:
