Helix/HX 3.60 (released April 25, 2023) includes 3 new amps, 9 new cabs, 2 new effects, additional improvements, and bug fixes, and is strongly recommended for all users.
How do I update to 3.60?
IMPORTANT![data-colorid=dwbk4r2qy0]{color:#e74c3c} html[data-color-mode=dark] [data-colorid=dwbk4r2qy0]{color:#c32818}[data-colorid=cqm5myppfq]{color:#e74c3c} html[data-color-mode=dark] [data-colorid=cqm5myppfq]{color:#c32818}[data-colorid=yc8x7vdofs]{color:#e74c3c} html[data-color-mode=dark] [data-colorid=yc8x7vdofs]{color:#c32818} The 3.60 update process may take 30 MINUTES OR MORE TO COMPLETE. This is totally normal, as it includes thousands of additional IR files.
Updating Helix/HX Hardware
With Helix/HX connected to your computer, launch HX Edit (3.01 or higher), and make sure you're signed in. HX Edit knows when a new update is available and will walk you through the entire update procedure for both hardware and software, including backing up everything to your computer. IMPORTANT! If you're running HX Edit 3.00 or older, download HX Edit 3.60 and repeat step 1. HX Edit 3.60 (macOS): https://line6.com/software/readeula.html?rid=11893 HX Edit 3.60 (Windows): https://line6.com/software/readeula.html?rid=11894
If your Helix Floor/Rack/LT is currently running firmware 3.15 or older, halfway through the update to 3.60, Helix's LCD reads "Boot Failure. Entered Update Mode!" THIS IS NORMAL. Breathe deep, everything is fine. You're almost there. HX Edit will display a message indicating the device must be reset. Click resume and wait for the second part of the update to complete.
Perform a factory reset.
IMPORTANT! MAKE SURE YOU HAVE A BACKUP FIRST, AS A FACTORY RESET WILL ERASE ALL YOUR WORK!
Helix Floor/LT: While holding footswitches 9 & 10 (bottom row, 2 middle switches), turn on Helix Floor/LT
Helix Rack: While holding knobs 5 & 6 (2 furthest right knobs below the screen), turn on Helix Rack
HX Effects: While holding footswitches 6 & TAP (2 farthest right switches on the bottom row), turn on HX Effects
HX Stomp: While holding footswitches 2 & 3, turn on HX Stomp
HX Stomp XL: While holding footswitches C & D, turn on HX Stomp
OPTIONAL: Performing a factory reset loads the new 3.60 Factory Presets, but restoring from your backup will overwrite these. Spend some time exploring these and export the factory presets you want to keep (or drag them to your desktop). If you have unused setlists in Helix Floor/Rack/LT, you can also export the entire FACTORY 1 bundle for loading into an unused setlist later.
From the top File menu, select Restore From Backup... If you don't have any important presets in Setlist 1, click the disclosure triangle next to Presets and uncheck the first setlist's box; this will retain 3.60's FACTORY 1 setlist. Select the backup file created in Step 1 and click Restore Backup.
Updating Helix Native
Before updating Helix Native, it is highly recommended that you export a preset/setlist bundle. Click the gear icon in the lower left, select the Presets/IRs tab, and then click Export Bundle. Some hardware compatibility modes (HX Stomp, HX Stomp XL, HX Effects) do not have this feature as they have only one setlist. In these cases, at the top of the preset list, click the yellow EXPORT to export the setlist.
Quit your DAW and download and install Helix Native 3.60:
Helix Native 3.60 (macOS): https://line6.com/software/readeula.html?rid=11895
Helix Native 3.60 (Windows): https://line6.com/software/readeula.html?rid=11896
Open your DAW and open an instance of Helix Native.
OPTIONAL: The only way to hear 3.60's new factory presets is to restore them. IMPORTANT! MAKE SURE YOU'VE EXPORTED A BUNDLE (OR ANY IMPORTANT SETLISTS) FIRST, AS RESTORING FACTORY SETLISTS WILL ERASE ALL YOUR WORK! Click the gear icon in the lower left, select the Presets/IRs tab, and then click Restore Factory Setlists. Click Yes.
I updated but why don't I see [Model X] in HX Edit?
HX Edit can't magically pull new model names and graphics from your Helix/HX hardware; you must update HX Edit as well (which you would've done had you followed "How do I update to 3.60?" above).
My Helix/HX is at version X.XX. Can I go straight to 3.60?
Yes, but note that if you're starting from 2.80 or lower, the update may appear to happen three times and will take notably longer than 30 minutes. This is normal.
New Amps in 3.60
Helix Floor, Helix Rack, Helix LT, Helix Native, HX Stomp, HX Stomp XL
Amp/Preamp > Grammatico GSG, based on* the Grammatico GSG100.
"The Grammatico GSG100 is an amp based on the study of legendary amps made around 1980. This model aims to capture all the unique details of this amplifier circuit, many of which are quite different than popular guitar amps from the major companies. The GSG100 is a feature-rich and complicated amp. There are many amazing sounds in the amp; however, the controls allow for such a wide range of adjustment that it's possible to get unpleasant sounds from it as well. To best use the amp, it really helps to know exactly what each of these features is doing to the guitar signal. Let's go through the parameters as they are found in the Helix model:"
Ben Adrian, Sound Design Manager
DriveThis is the first volume control on the amp. It's called "drive" on the model to fit the pattern of all the Helix models. On the real amp is says "Volume."
Bass, Mid, TrebleThe normal tone controls on the amp (called a tone stack by amp nerds), located between the first and second gain stages in the preamp. These have different ranges than traditional guitar amp tone controls. Also, the whole voicing of the tone stack can be changed with the "Rock/Jazz" switch, which will be explained later.
PresenceThis is like the presence controls on other guitar amps. It changes the amount of high frequency in the power amp by modifying the EQ filtering in the power amp's negative feedback loop.
Ch VolThis controls the output level of the amp model. It has no effect on the tone or distortion of the amp model
MasterThis is the master volume on the front panel of the amp. It is located between the preamp and power amp and can be used to get more or less power amp distortion. This amp is VERY loud, and most players would probably run the master volume on the lower side. If the master volume is cranked, the power amp distortion can be pushed into unpleasant territory. Most players would never crank the master in real life as the actual output would be way too loud for most musical settings.
Mid SwitchThis switch changes the value of the treble capacitor in the tone stack. When it is off, the amp has more of a scooped sound. When it is on, there is a noticeable upper-mid boost.
Jazz/RockThis switch changes the wiring of the tone stack circuit. It allows for two totally separate tonal voices. Jazz is quieter with a lower center frequency for the mids. Rock is louder with a more traditional mid frequency center. Tone controls rarely translate well between the Jazz and Rock settings. If a good sound is achieved in one mode, it is not guaranteed that the same settings in the opposite mode will still sound pleasing.
OD SwitchThis turns the two-gain-stage tube overdrive circuit on and off. This circuit is located AFTER the tone controls and Drive knob. When the overdrive is turned on it's as if a third and fourth gain stage is added to the preamp. Generally, it's best to set up the base tone of the amp with the Drive and tone controls first, and then adjust the overdrive circuit to work with the desired base tone.
OD DriveThis controls the amount of drive or saturation in the overdrive circuit. Since the whole overdrive circuit is after the amp's regular drive and tone controls, the range of OD Drive knob will change based on those earlier knob settings.
OD LevelThis controls the output level of the overdrive circuit.
BrightThis is a three position switch. The settings are "off" and two different values of bright capacitor. This bright capacitor works with the Drive (volume) knob earlier in the circuit, and is similar to other amps that have bright switches. When the Bright switch is engaged, the effect is more pronounced with lower Drive settings. The bright becomes less effective at higher Drive settings. When the Drive is at 10, the switch is effectively removed from the amp circuit, and changing the switch settings has no audible effect.
FET BoostThe GSG100 has a solid state, FET (Field Effect Transistor) boost circuit at the very beginning of the amp circuit. It is akin to placing a FET Boost pedal before the amp. On the physical unit there are two input jacks, but on the model it is placed on a switch and can even be made foot-switchable. The FET Boost has a fixed boost amount of about 7 to 9 dB and also gives a slight EQ change.
PABThis stands for "Preamp Boost." The PAB works by removing the tone controls from the circuit. Tone controls work by removing frequencies and signal level. Engaging the PAB circuit returns all of this lost signal level, but the side effect is that tone controls no longer work. It truth, the treble knob does work slightly, and the mid switch will change how much lows and mids comes through the circuit. In general, though, the PAB trades tone control functionality for a full blast level between tube gain stages 1 and 2.
SagThis is a control that is added to all the Helix models. Every tube amp has some amount of power supply sag, which feels like compression, squish, and sustain to the player. This control makes the sag amount user-adjustable.
HumThis is a control that is added to most of the Helix models. Preamp tube heaters in tube amps will leak a little bit of 60 cycle hum into the audio signal. When this hum mixes with the distorted audio signal, a non-musical distortion is created at low levels. To some players, this low-level, non-harmonic distortion adds a bit of realism to the amp model. The best way to put it is that sometimes the model sounds more "wrong" without the hum. However, if you don't like it, you can just turn it down.
RippleThis is a control that is added to most of the Helix models. Power amp circuits will sometimes let a little bit of rectified 120Hz hum (that the power supply filter caps can't quite fully remove) into the audio signal. When the power supply is being pushed hard, more of this ripple can get through the audio path. Much like the hum, this provides a bit of non-musical distortion to the power amp at distorted settings. To some people, this sounds like harmonic complexity that is enjoyable and realistic. Other players just don't like it and turn it off.
BiasThis control is in most Helix models. It adjusts the bias of the tubes in the power amp, causing a change in tonality and the distortion characteristic.
Bias XThis is the most difficult parameter to describe in Helix models, so hang on. All tube amps need to bias the power amp tubes. This is usually achieved by applying a negative voltage to the input audio signal. (Cathode bias works differently, but that's a story for a different time.) However, when the power tubes are distorting, free electrons can form around the input grid and cause a shift in the bias voltage. This shift only happens during the moments when distortion is occurring. This shift causes a tonal and texture change much like adjusting the bias control. However, once the tubes leave the distorted state, the free electrons dissipate and the bias returns to normal. Another way to put it (less accurately) is that this is a level/envelope controlled bias shift. This behavior is modeled in all Helix amps, and the Bias X control allows users to control the amount of bias shift that is happening. It is a very subtle change, so please don't expect high drama from this knob.
Grammatico GSG factory presets to check out:
Helix Floor/Rack/LT/Native
FACTORY 104B [013] Grammatico GSG
FACTORY 113A [048] Grammatico JNC. Preset created by John Cordy
FACTORY 113B [049] Screams JNC. Preset created by John Cordy
HX Stomp
14A [039] DIR:Gram GSG
20A [057] DIR:GRAM JNC. Preset created by John Cordy
20B [058] DIR:SCREAMS JNC. Preset created by John Cordy
HX Stomp XL
10D [039] DIR:Gram GSG
15B [057] DIR:GRAM JNC. Preset created by John Cordy
15C [058] DIR:SCREAMS JNC. Preset created by John Cordy
Amp/Preamp > Line 6 Elmsley, Line 6 Original
"The Line 6 Elmsley is a new Line 6 original amplifier that employs a parallel distortion topology that layers distinct saturation characteristics across the lower and upper registers. The Elmsley features a smooth and present bottom end with some exceptional sparkle and definition all through the midrange and above. The result is an amplifier that is dazzling across the full spectrum, and the amplifier deals with pedals in spades.
"The other new key feature of The Elmsley's power amp section is the Negative Feedback (NFB) parameter, where the amount of feedback within the power section's response can be dialed anywhere from wild and unhinged, tight and punchy, and anything in between. As with many amplifier designs, the presence and depth controls are part of this negative feedback circuit and functions to control the brilliance and resonance of the power amp, respectively. As the NFB param is reduced, the presence and depth controls' influences are also influenced, and they become effectively deactivated when the NFB knob is at zero. These interactions allow the player to create countless tonal variations to suit their needs.
Sam Hwang, Sound Designer
Line 6 Elmsley factory preset to check out:
FACTORY 104C [014] Line 6 Elmsley. Turn Distortion > Minotaur off to hear more of the character of the amp. Press the NFB switch to instantly adjust with your feet
HX Stomp
14B [040] DIR:Elmsley.
HX Stomp XL
11A [040] DIR:Elmsley.
Amp/Preamp > Agua Sledge, based on* the Aguilar Tone Hammer
Agua Sledge factory presets to check out:
FACTORY 110D [039] BAS:Agua Sledge
FACTORY 111C [042] BAS:Hire Me!
HX Stomp
30C [090] BAS:Agua Sledge
HX Stomp XL
23C [090] BAS:Agua Sledge
New Cabs in 3.60
New Guitar Cabs
Cab > 1x12 Blue Bell (Single, Dual), captured from* the 1×12? Vox® AC-15 Blue Alnico
Cab > 1x12 Open Cream (Single, Dual), captured from* a custom 1x12" open back cabinet G12M-65
Cab > 1x12 Open Cast (Single, Dual), captured from* a custom 1x12" open back cabinet EVM12L
Cab > 2x12 Silver Bell (Single, Dual), captured from* the 2×12? Vox® AC-30TB Silver Alnico
Cab > 2x12 Match H30 (Single, Dual), captured from* the 2x12" Matchless® DC-30 custom G12H-30
Cab > 2x12 Match G25 (Single, Dual), captured from* the 2x12" Matchless® DC-30 custom G12M-25
Cab > 4x12 Greenback 20 (Single, Dual), captured from* the 4×12? Marshall® Basketweave G12M-20
MicSelect from up to 12 mics: 57 Dynamic—Shure® SM57 421 Dynamic—Sennheiser® MD 421-U 7 Dynamic—Shure SM7 906 Dynamic—Sennheiser e906 30 Dynamic—Heil Sound® PR 30 121 Ribbon—Royer® R-121 160 Ribbon—Beyerdynamic® M 160 4038 Ribbon—Coles 4038 84 Ribbon—AEA R84 414 Cond—AKG® C414 XLS 47 Cond FET—Neumann® U47 FET 67 Cond—Neumann U67
PositionSets the lateral location of the mic in relation to the speaker cone. Choose from Center ~ Cap Edge ~ Edge. Cap Edge may appear in a different location depending on the selected cab
DistanceSets the distance of the mic from the speaker cone. Choose from 1.00" to 12.00" in 1/4" increments
AngleSets the angle of the mic. 0 degrees is pointing directly at the speaker, 45 degrees is pointing off-axis
Low CutApplies a low cut (high pass) filter, letting you remove all audio below a certain frequency. May be useful in removing undesirable low end rumble
High Cut Applies a high cut (low pass) filter, letting you remove all audio above a certain frequency. May be useful in removing high end harshness
LevelSets the overall level of the cab
Pan (Dual only)Moves the signal left or right across the stereo sound field. For example, if you're running a stereo playback system with two or more speakers, panning the first cab to Left 100 and the second cab to Right 100 can make your tone sound notably wider. Press the knob to return to Center
Delay (Dual only)Although the new cabs in 3.60 perfectly line up with one another, there may be situations where you want to delay one side very slightly, to perhaps impart a bit of phase incoherence or at higher values, to increase the apparent stereo spread. A little goes a long way here
New Bass Cabs
Cab > 1x12 Epicenter (Single, Dual), captured from* the 1x12" Epifani® Ultralight series cabinet
Cab > 4x10 Ampeg Pro (Single, Dual), captured from* the 4x10" Ampeg® PR-410HLF
MicSelect from up to 12 mics: 57 Dynamic—Shure SM57 421 Dynamic—Sennheiser MD 421-U 7 Dynamic—Shure SM7 88 Dynamic—Beyerdynamic M88TG 52 Dynamic—Shure Beta 52A 112 Dynamic—AKG D112 D6 Dynamic—Audix D6 40 Dynamic—Heil Sound PR 40 4038 Ribbon—Coles 4038 414 Cond—AKG C414 TLII 47 Cond FET—Neumann U47 FET 67 Cond—Neumann U67
All other parameters the same as for guitar cabs (see above)
New Effects in 3.60
Helix Floor, Helix Rack, Helix LT, Helix Native, HX Effects, HX Stomp, HX Stomp XL
Distortion > Dark Dove Fuzz (Mono, Stereo), based on* the Electro-Harmonix® Russian Big Muff
SustainSets the amount of distortion
ToneSets the overall tonal balance of the distortion
LevelSets the overall level of the block
Modulation > Triple Rotary (Stereo only), inspired by* the Yamaha® RA-200 rotary speaker (famously implemented by Pink Floyd's David Gilmour).
"The Line 6 Triple Rotary is inspired by the Yamaha RA-200 Rotary speaker. The original RA-200 was a combo solid state amplifier designed to be used with organs much like other rotary speakers. However; the RA-200 unit was unique compared to the traditional rotary speakers, which typically have rotating horns and a rotating drum over a woofer, the Yamaha designs had midrange speakers which rotated vertically on top of a traditional non-rotating speaker cabinet.
"To make the model more versatile, we made this effect to behave more as a stereo effect rather than modeling the whole cabinet, and suggest using the effect in combination with a cabinet model if recording direct or listening through FRFR systems."
SpeedSets whether the speaker reflects the Slow Speed or Fast Speed
Slow SpeedSets the rate for the Slow Speed. Press the knob to toggle between a static rate (0.0 ~ 10.0) or note values for syncing with Tap Tempo and incoming MIDI clock
Fast SpeedSets the rate for the Fast Speed. Press the knob to toggle between a static rate (0.0 ~ 10.0) or note values for syncing with Tap Tempo and incoming MIDI clock
Ramp TimeAdjusts how fast switching from Slow Speed to Fast Speed and back takes place
Mix Controls the wet/dry mix of the rotary effect. When set to 0%, no rotary effect is heard; when set to 100%, no dry signal is heard
Level Controls the overall output level of the block
DriveControls the amount of drive into the speaker's power amp
HeadroomAdds up to 12.0dB of additional headroom
Low Cut Applies a low cut (high pass) filter to the speakers, letting you remove the effected signal below a certain frequency
High Cut Applies a high cut (low pass) filter to the speakers, letting you remove the effected signal above a certain frequency
WobbleModels how evenly the rotating speaker and its ballast weight are balanced about the axis. At zero, the speaker and ballast are perfectly balanced, and as the wobble control is increased the rotation of the speakers becomes more eccentric.
SeparationThe separation of the stereo field. Practically, this simulates moving the two listening points further apart as the separation knob is increased
Rotor DriftAdjusts how close the three rotor motors are in sync with each other in speed. As each of the rotors were belt driven, there are often some differences in belt or motor wear, and it creates some subtle modulation effects between the three rotors
Rotor 2 LvlSets the individual volume of the second rotor
Rotor 3 LvlSets the individual volume of the third rotor
Changes and Improvements in 3.60
As 3.60 adds a second Grammatico amp, the three existing Grammatico LaGrange amp models have been renamed to "GrammaticoLG Nrm," "GrammaticoLG Brt," and "GrammaticoLG Jmp"
A few 3.50 factory presets have been updated to utilize 3.60 cabs where appropriate
Bug Fixes in 3.60
After a long period of time with tonestack parameters set a certain way, the Amp > Moo)))n amp models could stop processing audioFIXED
Helix Floor/Rack/LT only: The 8 TEMPLATES setlist preset numbers were offset by oneFIXED
Helix Native only: Loading an Amp+Cab > Bass model could sometimes crash the pluginFIXED
