HX EFFECTS FAQ -
Helix 3.15 Release Notes -
Helix 3.10/3.11 Release Notes -
Helix Tutorials by Jason Sadites -
HX Effects Firmware Update -
Helix LT Pedal adjustment spec -
LINE 6 SERVICE PLUS EXTENDED WARRANTY PROGRAM FAQ -
Helix Scale Delay Parameter -
HELIX Support FAQ -
The Helix Looper -
L6 link and the Helix -
Impulse Response (IRs) -
HELIX Cheat Sheet -
HELIX Tutorial Videos -
Helix/Rack/LT/FX/Stomp Reset Procedures and Troubleshooting Tricks -
Helix Dimensions -
Helix XLR Inputs/Outputs and 48v Phantom Power -
Helix Expression Pedal Calibration -
HELIX/HX and External Expression Pedal Usage -
HELIX FX Models and their relations to tap tempo -
HELIX and EXT Amp Controlling -
HELIX Hidden Toe Switch -
Helix Rack Registration Issue -
Helix Snapshots and EXP pedal recall -
Helix 2.0 shortcuts -
Helix Tutorial Videos 821 -
Renaming Setlists with Helix HX Edit 3.0 or above -
Helix LT Comparison -
HELIX / HX FREE EXTENDED WARRANTY PROGRAM FAQ U.S. ONLY -
HX Stomp Tutorials by Jason Sadites -
Helix Pedal Maintenance Procedure -
Common Signal Flow Traits on the Helix -
HX Effects Tutorial Videos -
Marketplace FAQ -
Helix DSP Values -
Helix Floor/Rack/LT/HX Effects Input and Output Specs -
HX Stomp Tutorial Videos -
HX Stomp FAQ -
Mission Engineering 529 HC Power Supply Compatibility -
Trouble opening/installing Line 6 Updater software on Mac OSX -
Helix/HX Model Lists -
Mac OS X 10.11 users can't log in (expired SSL cert) -
Updating Helix/HX/Helix Native -
Helix 3.0 Factory Setlists -
Updating Helix/HX -
Importing IR (impulse response) out of memory condition error -
HX Stomp XL FAQ -
Potential Helix/HX Feedback Loop (PLEASE READ) -
How to Deactivate Demo Mode (Helix family products) -
Helix 3.50 Release Notes -
External Dual Footswitch assignments HX Stomp/HX Stomp XL -
Windows 10/11 Memory Integrity/Core Isolation Disables Driver Installation -
Helix/HX update recovery instructions -
HX ONE failed update recovery, update mode instructions -
Driver uninstall instructions for Helix drivers on Windows 7, or 8. -
HX One v3.80 Preset Corruption -
HX ONE update instructions -
HX Ones sample rate/processing
