Renaming Setlists with Helix HX Edit 3.0 or above
To rename your desired setlist within the HX Edit 3.0 or above, be sure to click on the setlist name with your LEFT mouse button and hold it for a second. When you use a longer mouse click you should see the cursor appear with a blue highlight. Then, you can rename your selection.
This will not work within the drop-down menu. Only the selected setlist name.
