Windows Vista - Assigning Sound Card
Once you have installed Line 6 Monkey and the applicable drivers for your Line 6 device, you will be able to assign your USB capable device as the sound card for your computer. See the following instructions for assigning your Line 6 device as a sound card for your Windows Vista Operating System:
1) Select the "start menu" and select "Control Panel".
Unknown Attachment
2) Select "Classic View" if not already selected, then select "Sound".
Unknown Attachment
3) Select the playback tab, then select your Line 6 device (this example uses a Toneport UX-1), then select "Set Default".
4) Select the Recording tab, select your Line 6 device (this example uses a Toneport UX-1), then select "set as default" (if applicable). Then select "OK".
5) Close the window. Be sure that your speakers and/or headphones are connected to your Line 6 device (rather than the computer's sound card).
