To uninstall the Line 6 Drivers from a MAC OSX computer, use the Line 6 Driver Uninstaller that is located on the computer at following file location:
Applications/Line 6/Drivers/Driver uninstaller
If you have used the Driver Uninstaller and still cannot succesfully install drivers or Monkey is not recognizing them as being installed, you will need to remove the remaining driver receipts using the Terminal application that is located on the computer at the following file location:
Applications/Utilities
Launch the Terminal application and type the following commands at the prompt:
sudo pkgutil --forget com.line6.driver.xtaudio.package (then press the enter key)
Enter your Mac OSX account password. Please Note: you will NOT see the cursor acknowledge any characters being input; you will need to type your system password correctly and hit "Enter".
sudo pkgutil --forget com.line6.driver.xtmidi.package (then press the enter key)
After entering in all of the commands above, close the Terminal application and restart your computer. Upon restarting the computer try again to install the latest version of our drivers available from our software page at:
After the computer has restarted, reconnect the Line 6 hardware and open the Line 6 Monkey application again to check and see if your drivers are detected and up to date.
Deinstallation von Line 6 Treibern auf einem Mac OS X:
Um Line 6 Treiber von einem Mac OS X Computer zu entfernen müssen Sie die Line 6 Driver Uninstaller Software benutzen, welche an dieser Stelle zu finden ist:
Programme/Line 6/Drivers/Driver Uninstaller
Wenn Sie den Driver Uninstaller bereits benutzt haben und können immernoch keine Treiber erfolgreich installieren oder Monkey erkennt diese nicht als installiert, dann müssen Sie die übrigen Treiberreste anhand des Terminals von Ihrem Computer entfernen. Das Terminal können Sie hier finden:
Programme/Dienstprogramme
Starten Sie das Terminal Programm und geben Sie Folgendes ein:
Sudo pkgutil --forget com.line6.driver.xtaudio.package (drücken Sie dann auf Enter)
Geben Sie nun Ihr Mac Passwort ein. Achtung, der Kursor wird Ihnen nicht anzeigen, dass Sie eine Eingabe tätigen; geben Sie Ihr Passwort korrekt ein und drücken Sie Enter)
Sudo pkgutil --forget com.line6.driver.xtmidi.package (drücken Sie dann auf Enter)
Nachdem Sie diese Befehle eingegeben haben müssen Sie das Terminal schließen und Ihren Computer neustarten. Nachdem Sie ihn neugestartet haben können Sie noch einmal versuchen die neuste Version der Treiber zu installieren. Laden Sie diese hier herunter:
https://de.line6.com/software/
Nachdem Sie Ihren Computer neugestartet haben können Sie Ihr Gerät wieder mit dem Computer verbinden, Line 6 Monkey öffnen und überprüfen ob Ihre Treiber auf dem neusten Stand sind.
Désinstallation des pilotes Line 6 sur Mac OS X:
Pour désinstaller des pilotes Line 6 de votre ordinateur Mac OS X, vous devez utiliser le logiciel Line 6 Driver Uninstaller qui est situé à cet emplacement:
Si vous avez utilisé le Driver Uninstaller mais vous ne pouvez toujours pas installer des pilotes avec Monkey ou il ne les reconnaît pas comme installés, vous avez besoin de supprimer les pilotes en utilisant le Terminal, qui est situé à :
Applications/Utilitaires
Démarrez l'application "Terminal" et entrez ceci:
Sudo pkgutil --forget com.line6.driver.xtaudio.package (poussez "Entrée")
Entrez votre mot de passé Mac. Veuillez noter s'il vous plaît: le curseur ne vous montre pas que vous entrez des caractères. Entrez le mot de passe correctement et poussez "Entrée".
Sudo pkgutil --forget com.line6.driver.xtmidi.package (poussez "Entrée")
Après vous avez entré ces commandes, fermez le Terminal et redémarrez l'ordinateur. Après vous avez redémarré, essayez d'installer les versions les plus récentes des pilotes disponibles de notre site web:
https://fr.line6.com/software/
Après l'ordinateur a redémarré, reconnectez l'appareil Line 6 et ouvrez Line 6 Monkey pour vérifier si vos pilotes sont détectés et à jour.
