The Line 6 Audio-MIDI Control Panel FAQ
Français
Deutsch
Explained below is a definition of the Line 6 Audio-MIDI Control Panel. It explains and defines the function of each setting within the application.
The "Driver" tab
Driver Operating at:
The "Driver operating at:" status actually shows the sample rate and bit depth of the data going through the USB cable and the hardware. For X3, the hardware always runs at 48000 Hz, 24 bit regardless of what the driver is doing, so you'll always see 48k, 24bit.
From the Gearbox Manual page 3.4
Driver Operation indicator:
TonePort & GuitarPort devices - Displays what sample and bit rate the current device is operating at(or with no text if not in use).
Note: POD XT devices do not utilize this feature and therefore no text will appear here when a PODxt is the selected device. These devices run at a fixed sample rate which is why you'll see the Sample Rate Converter light always on when viewing the Control Panel with a POD XT device connected. The POD XT is always converting from the custom rate to it's fixed sample rate.
Similarly, the SRC light will always be on for X3, unless you're running the driver at 48kHz.
Lock Format:
The "Lock Format" check box affects two things.
1)All WDM applications
2)The hardware sample rate, if it isn't already locked by the hardware (like X3 or XT).
Lock Driver Format: When checked, this forces the Line 6 audio driver to operate at the Sample
and Bit rate settings entered in the two fields below (as opposed to following the sample rate requested
by a host audio application).
Note: Lock Format doesn't affect the ASIO driver. All sample rates will still work for ASIO even if Lock Format is checked. With TonePort devices, Lock Format will lock that hardware to the given sample rate. If ASIO software asks for a different sample rate, our driver will perform the necessary Sample Rate Conversion.
ASIO Settings:
The ASIO Settings section are the displayed settings of what you are actually running your ASIO driver at.
From the Gearbox Manual page 3.3/3.4
ASIO Client:
If you are running audio software that is using this Line 6 device as its
ASIO sound card, the name of the software will appear here. If not in use by an ASIO software, none is displayed here as shown.
Default Buffer Size:
The ASIO buffer size in use. Note this field is only active when in use by an ASIO application. As your audio software documentation will likely tell you, the ASIO Buffer Size will affect the responsiveness and latency of the audio. The lower the setting, the faster the response, but with the trade-off of higher processor usage and the risk of audio dropouts. Raise the value if you are getting inconsistent playback or recording in the audio software. Basically, 512 is generally a good average setting.*
Default Bit Depth:
The ASIO bit depth in use. Note this field is only active when in use by an ASIO application. It is best to use the highest bit rate your ASIO software will support to ensure high quality
audio.
Sample Rate Converter:
TonePorts support 44.1 and 48 kHz sample rates natively. Some TonePorts also support 88 and 96 kHz sample rates by way of an internal sample rate converter. This indicator lights up to show you when this converter is active, which can be any time your ASIO software is requesting a different sample rate than what your device natively supports. TonePort UX8 supports 44.1, 48, 88.2 and 96 kHz sample rates natively, meaning that these sample rates are not converted.
The Inputs and Recording tab:
From the Gearbox Manual page 3.5:
Input Source Select:* This is a mirrored control for the Source Select within the GearBox application where it allows the user to select which physical input is used on the device. Note that this control is ONLY selectable when the GearBox software is not in use by the current device. When GearBox is in use, it remains grayed out, but displays the current Source that is selected within GearBox. When Gearbox is not in use by the selected Line 6 device, this Input Source Select, like the Source Select in the GearBox application, offers a list of input options.
GuitarPort and PODxt devices are always fixed to only route their instrument 1 /4 input signal into GearBox. When a GuitarPort or PODxt is the selected device, this Input Source Select list offers only Instrument as the source.
F.A.Q. zur Line 6 Audio-MIDI Steuerung:
Im Folgenden sind die Funktionen des Line 6 Audio-MIDI erklärt:
Der "Driver" Reiter:
Der "Driver Operating at:"Status zeigt Ihnen die Samplerate und Bitauflösung der Daten an, die durch das USB Kabel und die Hardware gehen. Für das X3, die Hardware läuft immer auf 48kHz, 24bit egal was der Treiber macht also wird Ihnen immer 48kHz, 24bit angezeigt.
Aus dem GearBox Benutzerhandbuch, Seite 3.4:
Driver Operation Anzeige:
TonePort und GuitarPort Geräte: Anzeige der Samplerate und Bitauflösung des derzeit angeschlossenen Gerätes (oder ohne Text wenn es nicht benutzt wird).
Achtung, PODxt Geräte benutzen diese Eigenschaft nicht und somit wird dann auch kein Text angezeigt, wenn ein PODxt ausgewählt wird. Diese Geräte laufen mit einer festgesetzten Samplerate, deshalb wird das Sample Rate Converter Licht immer an sein wenn Sie die Steuerung mit einem PODxt Gerät öffnen. Das PODxt wird immer von der benutzerdefinierten Samplerate auf seine festgesetzte Samplerate konvertieren.
So wird das SRC Licht auch immer bei einem X3 angeschaltet sein außer Sie lassen den Treiber auf 48kHz laufen.
Lock Format:
Das Lock Format Kontrollkästchen beeinflusst zwei Dinge:
  1. Alle WDM Programme.
  2. Die Hardware Samplerate, sofern diese nicht von der Hardware festgesetzt ist.
Lock Driver Format: Wenn diese Option angekreuzt ist, wird der Line 6 Audiotreiber dazu gezwungen mit der unten eingegebenen Samplerate und Bitauflösung zu arbeiten. Im Gegensatz zur Einhaltung der Samplerate die vom Audio Programme angefordert wird.
Achtung, Lock Format beeinflusst nicht den ASIO Treiber. Alle Sampleraten werden weiterhin für ASIO funktionieren auch wenn Lock Format angekreuzt ist. Mit TonePort Geräten wird Lock Format die Hardware auf die angegebene Samplerate fixieren. Wenn ASIO Software nach einener anderen Samplerate fragt wird unser Treiber die nötige Konvertierung vornehmen.
ASIO Settings:
Die Sektion der ASIO Settings zeigt alle Einstellungen des ASIO Treibers an die tatsächlich laufen.
Aus dem GearBox Benutzerhandbuch, Seite 3.3/3.4:
ASIO Client:
Wenn Sie eine Audio Software benutzen, die das Line 6 Gerät als ASIO Soundkarte verwendet, wird der Name der Software hier erscheinen. Wenn es nicht mit ASIO Software verwendet wird, wird hier "none" stehen.
Die ASIO Buffergröße in Benutzung. Achtung, dieses Feld ist nur dann aktiv, wenn es mit einem ASIO Programm benutzt wird. Die ASIO Buffergröße wird die Reaktionsfähigkeit und Latenz des Tons beeinflussen. Je tiefer diese Einstellung, umso schneller die Resonanz. Dies führt jedoch zu einer höheren Prozessorauslastung und man riskiert Audio Aussetzer. Erhöhen Sie diesen Wert wenn Sie einen unbeständigen Ton in Ihrer Audio Software erhalten. Am Allgemeinen ist 512 eine gute, durchschnittliche Einstellung.
Default Bit Depth:
Die ASIO Bitauflösung in Benutzung. Achtung, dieses Feld ist nur dann aktiv, wenn es mit einem ASIO Programm benutzt wird. Am besten benutzen Sie die höchste, von Ihrer ASIO Software unterstützte, Bitauflösung um eine hohe Audioqualität zu gewährleisten.
TonePorts unterstützen von Haus aus 44.1 und 48kHz Sampleraten. Manche TonePorts unterstützen sogar 88 und 96kHz Sampleraten anhand eines internen Konverters. Diese Anzeige leuchtet auf um Ihnen zu zeigen, dass dieser Konverter aktiv ist. Dies kann jederzeit geschehen, wenn Ihre ASIO Software eine unterschiedliche Samplerate erfordert als die, die Ihr Gerät nativ unterstützt. TonePort UX8 unterstützt 44.1, 48, 88.2 und 96kHz Sampleraten, was bedeutet, dass keine Kovertierung stattfindet.
Der Input and Recording Reiter:
Aus dem GearBox Benutzerhandbuch, Seite 3.5:
Input Source Select ist eine Spiegelung des Source Select des GearBox Programmes, welches Ihnen die Möglichkeit gibt, den physischen Eingang, der auf Ihrem Gerät genutzt werden soll, auwählen zu können. Achtung, diese Eisntellung ist nur dann auswählbar, wenn die GearBox Software derzeit nicht von einem Gerät benutzt wird. Wenn diese von einem Gerät in Benutzung ist, wird die Einstellung grau bleiben aber Ihnen die derzeitige Quelle anzeigen, die im GearBox ausgewählt ist. Wenn GearBox nicht von einem Gerät in Benutzung ist, dann können Sie hier, wie beim Source Select der GearBox Software eine Liste von Eingangsoptionen benutzen.
GuitarPort und PODxt Geräte sind immer festgesetzt, um ausschließlich den "Instrument" 6.35mm Eingang ins GearBox zu nutzen. Wenn also ein GuitarPort oder PODxt das ausgewählte Gerät ist dann hat diese Input Source Select Liste nur eine Option, "Instrument".
TonePort UX8 hat einen größeren Satz Optionen, schauen Sie sich dazu den Inputs & Recordings Reiter an.
Panneau de configuration Line 6 Audio-MIDI: F.A.Q.
Explications des options du Line 6 Audio-MIDI:
Le tab Driver:
Le statut "Driver operating at:" vous montre la fréquence d'échantillonnage et la profondeur de bits des données traversant le câble USB et le hardware. Pour le X3, le hardware est toujours à 48000 Hz, 24bit n'importe quoi le pilote fait. Vous voyez toujours 48k, 24bit.
Retiré de la page 3.4 du manuel d'utilisation Gearbox:
Indicateur Driver Operation:
Appareils TonePort & GuitarPort: Affiche la fréquence d'échantillonnage et la profondeur de bits à laquelle l'appareil fonctionne. (Aucun texte si l'appareil n'est pas en cours d'utilisation.)
Attention, les appareils PODxt n'utilisent pas cette option donc aucun texte n'apparaît si un appareil PODxt est connecté. Ces appareils fonctionnent à une fréquence d'échantillonnage fixée donc la lumière "Sample Rate Converter" est toujours allumée si un appareil PODxt est connecté. Le PODxt toujours convertit la fréquence personnalisée à sa fréquence fixée.
De même façon, la lumière SRC est aussi toujours allumée avec un appareil X3, sauf vous exécutez le pilote à 48kHz.
Lock Format:
La case à cocher "Lock Format" affecte deux choses:
  1. Toutes les applications WDM.
  2. La fréquence d'échantillonnage du hardware si ce n'est pas fixé par le hardware (comme X3 ou XT).
"Lock Driver Format": Si coché, cette option force le pilote Line 6 de fonctionner à la fréquence d'échantillonnage et profondeur de bits entrés ci-dessous. Contrairement à l'utilisation de la fréquence d'échantillonnage demandé par l'application audio.
Attention, Lock Format n'affecte pas le pilote ASIO. Toutes les fréquences d'échantillonnage fonctionnent même si Lock Format est coché. Pour les appareils TonePort, Lock Format verrouille le hardware à la fréquence d'échantillonnage donné. Si le logiciel ASIO demande une fréquence d'échantillonnage différente, notre pilote effectue la conversion de fréquence d'échantillonnage nécessaire.
ASIO Settings:
La section ASIO Settings affiche les réglages vous exécutez le pilote ASIO réellement.
Retiré de la page 3.3/3.4 du manuel d'utilisation Gearbox:
ASIO Client:
Si vous exécutez un programme qui utilise l'appareil Line 6 comme carte de son ASIO, le nom du logiciel apparais ici. S'il n'est pas utilisé d'un logiciel ASIO, "none" sera affichée ici.
Ce montre la taille de buffer ASIO en utilisation. Cet espace est seulement active si utilisé par une application ASIO. Cette taille de buffer ASIO affectera la réactivité et latence du audio. Abaissement de cette option améliore la réactivité mais l'utilisation du processeur augmente et on risque le décrochage du son. Augmentez ce valeur si vous recevez du audio inconsistant dans le logiciel audio. Normalement, 512 est un réglage bon moyenne.
Default Bit Depth:
Ce montre la profondeur de bits ASIO en utilisation. Cet espace est seulement active si utilisé par une application ASIO. Utilisez le plus haut réglage que votre logiciel ASIO soutient pour garantir une haute qualité audio.
Les TonePorts soutiennent les fréquences d'échantillonnage 44.1 et 48kHz nativement. Certains TonePorts soutiennent 88 et 96kHz aussi avec un convertisseur de fréquence d'échantillonnage interne. L'indicateur s'allume si ce convertisseur est active, que peut-être n'importe quand votre logiciel ASIO demande une fréquence d'échantillonnage différente que laquelle votre appareil soutient nativement. Le TonePort UX8 soutient les fréquences d'échantillonnage 44.1, 48, 88.2 et 96kHz nativement que veut dire que ces fréquences d'échantillonnage ne sont pas converties.
Le tab Inputs and Recording:
Retiré de la page 3.5 du manuel d'utilisation Gearbox:
Input Source Select: C'est un réglage reflète du Source Select dans l'application GearBox, ce réglage vous permet de sélecter quel entrée physique est utilisée sur l'appareil. Attention, ce réglage est seulement sélectionnable si le logiciel GearBox n'est pas en cours d'utilisation de l'appareil. Si GearBox est en cours d'utilisation, il reste grisé mais affiche la source actuelle du GearBox. Si GearBox n'est pas en cours d'utilisation, cette sélection vous offre une liste des options d'entrées.
GuitarPort et PODxt sont fixés ici, ils font passer seulement le signal d'entrée 6.35mm "Instrument" dans le GearBox. Donc, si un GuitarPort ou PODxt est l'appareil choisis, cette liste Input Source Select a uniquement "Instrument" comme source.
Le TonePort UX8 a un nombre plus vaste des options. Veuillez visiter le tab Inputs & Recording.
