Q: How do I set up my computer to work with Line 6 gear?
Make sure your Line 6 device is powered by the same power source as the computer (when applicable).
Be sure that your system exceeds the minimum requirements listed on the product's box.
Disable 'multiple users' on the system, automatic updates, as well as all themes/dashboards.
Disable the internal sound card
Turn off all other programs outside of the recording application(s), including anything that may be running in your system tray.
Turn off all anti-virus software and malware, including products such as ZoneAlarm, Defender, Norton Anti-virus, Firewalls, and pop up blockers
Be sure the date and time is set correctly on your computer
Disable all power saving, sleep mode options, wireless devices, and screen savers (especially on laptop computers).
Remove all Recording applications/playback programs that are not being used from your hard drive.
Unplug all non-essential USB, Firewire, and PCI connections (i.e. Web cameras, cameras, printers, scanners, MP3 players).
Disable disc compression options, system sounds, the indexing service, and your wireless Internet connection.
XP Users
Right click on "My Computer" and select "properties", select "advanced", select "performance settings", "visual effects", and select "adjust for best performance"
Run your system cleanup and disc defragmenter found under Start > All Programs > Accessories > System Tools.
Control Panel/Line 6 devices > In your Line 6/MIDI devices, select
16 bit audio
512 MB for buffer size
Move the Buffer slider to the second tick mark from the left under "extra small"
Be sure to select the same settings for bit rate and buffer size in your recording application as well
Windows 7/8/Vista Users
Go into your computer's control panel and click on the 'Sound' icon. Select your Line 6 device, then click on the 'Properties' button. Click on the 'Advanced' tab in the 'Properties' window. In the 'Default Format' box, try all the different bit and sample rate combinations to see if it fixes any issues you may be having.
Windows 10
Go into your computer's control panel and change the view to "small or large icons" Select Line 6 Audio/MIDI Devices. In your Line 6/MIDI devices, select
16 bit audio
You can also click on the 'Sound' icon. Select your Line 6 device, then click on the 'Properties' button. Click on the 'Advanced' tab in the 'Properties' window. In the 'Default Format' box, try all the different bit and sample rate combinations to see if it fixes any issues you may be having.
Mac Users
Disable any dual operating systems (dual boot, Parallels, etc.)
Run "repair disc permissions" from hard drive
Laptop computers: Try removing the power supply to see if there is better performance. If so, try a different power supply.
Q: I am getting pops/clicks in my audio stream when I open other programs?
A: There is no quick fix to solve this situation, but some end users have had success by installing a higher quality video card.
Q: I am not able to get my computer to recognize the Line 6 device?
- Plug your Line 6 device directly into the back of the computer. If you are on a laptop, try multiple USB inputs (as many laptops will route keyboard/mouse functions through a USB port, reducing the bandwidth).
- Check out the following driver installation documents:
USB Driver Installation: Mac
USB Driver Installation: Windows
Q: I am experiencing latency, how can I reduce it?
A: The normal way of reducing latency is to reduce the buffer size. Buffer sizes of 512 will allow latency of about 10ms when using 44.1kHz. You usually set buffer sizes to a power of 2, so if you wanted to lower the latency, try 256, 128 or even 64. If you experience too many dropouts, you will need to increase the buffer size again.
Follow these links for more tips and tricks for getting the most out of your computer recording experience.
If you are having difficulty using your Line 6 gear with a computer after following these guidelines, please complete your support profile (log on to your Line 6 account and go to "My Account") and post a question in the Line 6 forums.*
Audiooptimierung für das Computersystem:
Wie konfiguriere ich meinen Computer, damit er mit Line 6 Geräten läuft?
Ich Line 6 Gerät sollte an die selbe Stormquelle angeschlossen sein wie Ihr Computer3
Stellen Sie sicher, dass Ihr Computer die minimalen Systemvoraussetzungen erfüllt, welche auf der Kiste des Gerätes angegeben sind.
Schalten Sie "mehrere Benutzer", automatische Updates und Themen, sowie Dashboards auf Ihrem Computer aus.
Schalten Sie die internet Soundkarte des computers ab.
Schließen Sie alle unnötigen Programme sowie Software die in dre Taskleiste läuft.
Schalten Sie Antiviren und Malware Software ab, wie ZoneAlarm, Defender, Norton Antiviurs, die Firewall oder auch Pop-Up Blocker.
ÃÅberprüfen Sie Datum und Uhrzeit Ihres Systems.
Schalten Sie Energiespramodus, Bildschirmschoner, kabellose Geräte sowie den Ruhemodus aus. (besonders auf Laptops)
Entfernen Sie jegliche Aufnahme/Playback Programme, die nicht benutzt werden von Ihrem Computer.
Schließen Sie alle nicht benötigten USB, Firewire und PCI Gerät/Kabel ab. (z.B.: Kameras, Drucker, Scanner oder MP3 Player)
Schalten Sie Komprimierungsoptionen, System Töne, den Index Dienst und Ihre kabellose Internetverbindung aus.
XP Benutzer:
- Rechtsklicken Sie den Arbeitsplatz, klicken Sie auf "Eigenschaften", dann "Erweitert", "Leistungsoptionen", "Visuelle Effekte" und wählen Sie "Für optimale Leistung anpassen".
- Lassen Sie die "Datenträgerbereinigung" und die "Defragmentierung" laufen.
Start -> Alle Programme -> Zubehör -> Systemprogramme.
- Systemsteuerung -> Line 6 Devices -> Line 6/MIDI Devices: Hier folgendes auswählen:
16bit Audio
512Mb "Buffer Size"
Den Buffer Regler auf den zweiten Tick von links schieben unter "Extra Small"
Wählen Sie dann die selben Bit Rate und Buffer Size Einstellungen in Ihrer Aufnahmesoftware aus.
Windows 7/Vista Benutzer:
- Gehen Sie in dei Systemsteuerung und klicken dort auf "Sound". Wählen Sie Ihr Line 6 Gerät aus und klicken Sie auf den Einstellungen Knopf.
- Klicken Sie auf "Erweitert". In der Box für "Standartformat" probieren Sie alle verschiedenen Kombinationen aus, ob eine davon Ihr Problem löst.
Mac Benutzer:
- Schalten Sie Dual-Boot Betriebssyteme aus.
- Starten Sie "Zugriffsrechte des Volumes reparieren".
Laptop Computer:
- Nehmen Sie das Netzteil ab, um zu sehen ob es dann besser funktioniert, wenn ja versuchen Sie es mit einem anderen Netzteil.
Wenn ich ein Programm starte bekomme ich Klicks und Rauschen, was kan nich tun?
Für dieses Problem gibt es keine schnelle Lösung, manche Benutzer konnten dieses Problem anhand einer neuen Grafikkarte jedoch lösen.
Mein Computer erkennt mein Line 6 Gerät nicht. Was kann ich tun?
- Stecken Sie Ihr Gerät hinten in einen der USB Ports Ihres Computers ein.
Wenn Sie auf einem Laptop arbeiten versuchen Sie den USB Port zu wechseln. (Da viele Laptops Maus/Tastatur Funktionen über den USB Port leiten, was die Bandbreite des Ports verringert.)
Schauen Sie sich folgendes Dokument zur Treiberinstallation an:
Treiber Installation
Ich habe Latenz, wie kann ich diese verringern?
Generell können Sie die Latenz über die Buffer-Größe verringern. Eine Buffer-Größe von 512 wir Latenzen von 10ms erzeugen bei Benutzung von 44.1kHz. Meist wird die Stärke der Buffer-Größe auf 2 gesetzt. Wenn Sie also einen niedrigere Latenz haben wollen, versuchen Sie 256, 128 oder sogar 64. Wenn Sie dann jedoch Aussetzer im ton bekommen müssen Sie die Buffer-Größe wieder erhöhen.
Bitte schauen Sie sich den folgenden Artikel zu Latenz an:
Sound on Sound (Englisch)
Und folgen Sie diesen Links für weitere Tipps und Tricks um Ihren Computer weiter zu optimieren:
pcmus.com homerecording.about.com jakeludington.com (Alles in Englisch)
Wenn sie noch immer Probleme haben, Ihre Line 6 Geräte mit Ihrem Computer zu verbinden nachdem Sie diese Richtlinien befolgt haben sollten Sie Sich auf line6.com anmelden, Ihr Profil ausfüllen und ein Ticket öffnen.
Optimisation audio pour le système d'ordinateur:
Comment est-ce que je configure mon ordinateur pour fonctionner avec équipement Line 6?
Connectez l'appareil Line 6 à la même source d'électricité que votre ordinateur.
Assurez-vous que votre ordinateur satisfaire aux exigences minimales du système écrits sur la boîte du produit.
Désactivez "multiples utilisateurs", mises à jour automatiques et thèmes/Dashboard.
Désactivez la carte son interne.
Fermez tous les programmes inutiles aussi que tous ce qui est en cours d'exécution dans la zone de notification.
Fermez tous les logiciels antivirus et malware comme ZoneAlarm, Defender, Norton Antivirus, le pare-feu et des bloqueurs pop-up.
Vérifiez la date et le temps de votre ordinateur.
Désactivez tous les options de dormir ou économie d'énergie, les appareils Wifi et économiseurs d'écran (particulièrement sur les portables).
Supprimez tous les logiciels d'enregistrement/lecture inutiles de votre ordinateur.
Détachez tous les câbles/appareils USB, Firewire et PCI inutiles. (comme, caméras, imprimantes, scanneurs et lecteurs MP3)
Désactivez les options de compression de disque, sons systèmes le service d'indexation et votre connexion Wifi.
Utilisateurs XP:
- Faites un clic droite sur "Poste de travail" et cliquez "Propriétés", sélectez "Avancé", "Options de performance", "Effets visuels" et sélectez "Ajuster afin d'obtenir les meilleures performances".
- Lancez votre "Nettoyage de disque" et "Défragmenteur de disque" dans "démarrer" -> "Tous les programmes" -> "Accessoires" -> "Outils de système"
- Panneau de configuration -> Line 6 Devices -> Line 6/MIDI Devices:
16 bit audio
512 Mo comme "Buffer Size"
Déplacez le glisseur Buffer à la tique deuxième de gauche sous "extra small"
Sélectez aussi le même débit binaire et taille de buffer dans votre programme d'enregistrement.
Utilisateurs Windows 7/Vista:
- Allez dans Panneau de configuration -> Son. Sélectez votre appareil Line 6, cliquez propriétés. Cliquez le bouton Avancé. Dans la boîte "Format par défaut" essayez tous les différents combinaisons de débit binaire ("Bit Rate") et taille de buffer ("Buffer Size") pour voir si ca résolu le problème.
Utilisateurs Mac:
- Désactivez les systèmes double boot.
- Lancez "Réparer les autorisations du disque" de votre HD.
Les portables:
- Détachez l'alimentation, si ca fonctionne, essayez une autre alimentation.
Je reçois des clics et bruits si j'ouvre d'autres programmes. Qu'est-ce que c'est?
Il n'y en a pas une correction vite pour ce problème mais certains utilisateurs ont installés une carte graphique de haute qualité avec succès.
L'ordinateur ne reconnait pas mon appareil Line 6. Qu'est-ce que c'est?
Insérez votre appareil Line 6 directement à l'arrière de l'ordinateur. Si vous avez un portable, essayez différentes ports USB. (Beaucoup de portables font passer des fonctions clavier/souris via des ports USB, qui réduit la bande passante.)
Utilisez ce document pur l'installation des pilotes:
J'ai de la latence, qu'est-ce que je peux faire?
Normalement, pour réduire la latence, vous devez réduire la taille buffer. Taille buffer de 512 permettra une latence de 10ms si vous utilisez 44.1kHz. Normalement, vous mettez la puissance de taille buffer sur 2 donc si vous voulez réduire la latence, essayez 256, 128 ou 64. Si vous rencontrez des drop-outs, vous devez augmenter la taille buffer.
Veuillez consulter l'article suivant sur la latence à Sound on Sound (anglais) et utilisez ces liens pour améliorer votre ordinateur pour l'enregistrement:
pcmus.com homerecording.about.com jakeludington.com (tous en anglais)
Si vous avez des problèmes avec l'équipement Line 6 après ces instructions, veuillez créer un compte sur line6.com et ouvrir un ticket ou poster dans les forums.
