Q: Which type of USB is my Line 6 device compatible with?
A: Most Line 6 USB products are compatible with USB 1.x and 2.0. The UX8 and POD X3 USB Devices are USB 2.0 exclusive devices. Connecting these to USB 1.x ports will result in failed connectivity.
The following Line 6 units are compatible with all 3 types of USB Ports:
Guitarport
Toneport Series (GX, UX1, UX2, KB37)
Toneport DI (Gold/Silver)
POD Studio series (GX, UX1, UX2, KB37)
POD XT/XT Live/XT Pro
Pocket POD
Backtrack
The following Line 6 units are ONLY compatible with USB 2.0:
POD X3/X3 Live/X3 Pro
Toneport UX8
Q: How are 2.0 USB ports different from 1.1 ports?
A: As we all may know, USB ports are on your computer so you are able to connect external devices to work with your system. Most computers today come with one or more USB ports and they're so fast and easy to use. It's easy just to plug something into a port and go. Most newer computers come with USB 2.0 ports, but some of the older ones still have 1.0 or 1.1 (which are very similar to each other).
To find out which version you have, follow these directions:
Select the start menu, then go to "My Computer"
Unknown Attachment
right click on the "my computer" icon, then select "manage".
Unknown Attachment
Click on the "Device Manager" under "Computer Management". Scroll down on the right side of the box until you locate the Universal Serial Bus (USB) controllers, then expand the list by clicking the addition (+) symbol. If you have a USB 2.0 controller in your computer, the word "enhanced" will be listed somewhere in one of those names.
Q: Can I use a USB Hub to connect my Line 6 unit to my computer?
A: No, USB hubs are not supported in any application of Line 6 hardware.
Q: I am receiving an "Error 10" code when attempting to connect my POD X3 or UX8 to my computer?
A: An "Error 10" occurs when a USB 2.0 device (i.e.POD X3 and UX8 series) is connected to a USB 1.x port. Please connect these units to a USB 2.0 port.
Q: I cannot find a driver to download for the Pocket POD, FBV Mk II controller or Backtrack?
A: The Pocket POD, FBV Mk II controllers and Backtrack use "class compliant" drivers that are "pre-installed" in your OS.? If you are having trouble connecting to these devices you should try a different USB port and update your OS to ensure you have the latest class compliant drivers on your system.
If you have tried all available USB ports on your computer and have either no device recognition or poor audio quality (clicks-pops), you will want to consider purchasing a PCI USB 2.0 card to connect your Line 6 USB audio interface.
Q: I am receiving an error that says my hardware is not a valid Line 6 device (error 8000710B) / the ESN on my unit is showing "00000000" when I connect to Line 6 Monkey?
A: This situation may happen when a unit is incorrectly repaired at a Line 6 service center. The unit needs to be returned to the service center that originally serviced the unit for repair.
USB Komptibilität mit Line 6 Geräten
Mit welchen USB Arten ist mein Line 6 Gerät kompatibel?
Die meisten USB Produkte sind mit 1.x und 2.0 kompatibel. Die UX8 und POD X3 USB Geräte sind USB 2.0 exklusive Geräte. Die Verbindung dieser Geräte an einen USB 1.x Port schlägt dann fehl.
Folgende Line 6 Geräte sind mit allen 3 USB Typen kompatibel:
Guitarport
Toneport Serie (GX, UX1, UX2, KB37)
POD Studio Serie (GX, UX1, UX2, KB37)
Pocket POD
Backtrack
Die folgenden Line 6 Geräte sind nur mit USB 2.0 kompatibel:
Toneport UX8
Inwiefern sind USB 2.0 Ports unterschieden von USB 1.1 Ports?
Als erstes sollte man wissen, das der Computer USB Ports hat und Sie Ihre Geräte so mit Ihrem PC verbinden können. Die meisten Computer haben heutzutage mehrere USB Ports, sie sind schnell und einfach zu benutzen. Die meisten neuen Computer haben jedoch auch USB 2.0 Ports.
Um herauszufinden welche Ports Sie haben, folgen Sie diesen Anweisungen:
Gehen Sie auf das Startmenü, dann Arbeitsplatz.
Unknown Attachment
Rechtsklicken Sie den Arbeitsplatz, dann Verwalten.
Unknown Attachment
Klicken Sie dann auf den Gerätemanager unter Computerverwaltung. Scrollen Sie dann nach unten im rechten Fenster bis Sie die Universal Serial Bus (USB) finden und erweitern Sie die Liste indem Sie auf das (+) Symbol klicken. Wenn Sie einen USB 2.0 Controller haben werden Sie hier das Wort "Enhanced" finden.
Kann ich ein USB Hub benutzen um mein Line 6 Gerät an an meinen Computer anzuschließen?
Nein, USB Hubs werden von Line 6 Hardware nicht unterstützt.
Ich bekomme eine "Error 10" Fehlermeldung wenn ich mein POD X3 oder UX8 an meinen Computer anschließe. Was kann ich tun?
Ein "Error 10" tritt auf, wenn ein USB 2.0 Gerät (wie POD X3 oder UX8) and einen USB 1.x Port angeschlossen wird. Schließen Sie diese Geräte ausschließlich an USB 2.0 Ports an.
Ich habe meine Treiber aktualisiert, habe aber immer noch keine Verbindung oder habe MIDI timeout Fehlermeldungen mit meinem Line 6 Gerät, was kann ich tun?
Stellen Sie zuerst sicher, dass der Treiber korrekt installiert ist. Schauen Sie sich dazu diese Seiten an:
Windows: USB Device Driver Installation
Mac: USB Device Driver Installation
Stecken Sie Ihr Line 6 Gerät direkt in das Mainboard Ihres Computers (hintere Seite des PCs). Meiden Sie USB Hubs und die USB Ports auf der Vorderseite Ihres Computers. Wenn Sie einen Laptop benutzen sollten Sie alle USB Ports ausprobieren (da manche USB Ports widerstandsfähiger sind als andere). Entfernen Sie dann alle unnötigen USB Geräte um die Last des USB Datenflusses zu verringern und deisntallieren Sie dann jegliche unnötige Software von Ihrem Computer.
Klicken Sie folgende Links, um weitere Fehlerbehebungen zu USB Problemen zu erhalten:
Audiooptimierung für das Computersystem
USB Audio Problems and Chipset Error Explanation
Ich kann keinen Treiber für mein Pocket POD, FBV Mk II oder Backtrack finden.
Pocket POD, FBV Mk II und Backtrack nutzen generische Treiber, die auf Ihrem System vorinstalliert sind. Wenn Sie Probleme mit der Verbindung dieser Geräte haben sollten Sie es mit verschiedenen USB Ports versuchen und Ihr Betriebssystem aktualisieren damit Sie den neusten generischen Treiber auf Ihrem System haben.
Wenn Sie alle verfügbaren USB ports ausprobiert haben und der Computer erkennt das Gerät immer noch nicht oder Sie haben sehr schlechte Audioqualität (Klicks, Rauschen,...) brauchen Sie vielleicht eine PCI USB 2.0 Karte um Ihre Line 6 Geräte an Ihren Computer anzuschließen.
Ich bekomme einen Fehler, der behauptet meine Hardware sei kein gültiges Line 6 Gerät (Error: 8000710B) oder die ESN auf meinem Gerät zeigt "00000000" an wenn ich es mit Line 6 Monkey verbinde. Was kann ich tun?
Dieser Fehler kann auftreten wenn ein Gerät inkorrekt in einem Line 6 Service Center repariert wurde. Das Gerät muss dann zurück ins Center, welches das Gerät repariert hat.
Compatibilité USB avec les appareils Line 6
Avec quels types USB est-ce que mon appareil Line 6 est compatible?
La plupart des produits USB sont compatibles avec 1.x et 2.0. L'UX8 et le POD X3 sont seulement compatible avec USB 2.0. La connexion de ces appareils à un port 1.x échoue.
Les appareils suivants sont compatibles avec tous les trois types USB:
Guitarport
Série Toneport (GX1, UX1, UX2, KB37)
Série POD Studio (GX, UX1, UX2, KB37)
Pocket POD
Backtrack
Les appareils suivants sont seulement compatibles avec USB 2.0:
Toneport UX8
Dans quelle mesure est-ce que les ports USB 2.0 sont différents des ports 1.1?
D'abord, on doit savoir que l'ordinateur a ces ports USB et que vous pouvez connecter vos appareils à votre pc via ces ports. La plupart des ordinateurs d'aujourd'hui a plusieurs ports USB, ils sont rapides et facile à utiliser. La plupart des ordinateurs nouveaux ont aussi des ports USB 2.0.
Pour découvrir lesquels ports vous avez, suivez ces instructions:
Menu démarrer -> Poste de travail. Clic droite.
Unknown Attachment
Faites un clic gauche sur Gérer.
Unknown Attachment
Dans la gestion de l'ordinateur, cliquez le gestionnaire de périphériques. Cherchez Universal Serial Bus (USB) dans la fenêtre droite et développez la liste par cliquer sur le (+). Si vous avez un contrôleur USB, vous pouvez voir le mot "Enhanced" comme sur la capture d'écran suivante:
Puis-je utiliser un hub USB pour connecter mes appareils Line 6?
Non, les hubs USB ne sont pas soutenus du hardware Line 6.
Je reçois une erreur "Error 10" si je connecte mon POD X3 ou UX8 à mon ordinateur. Qu'est-ce que je peux faire?
L'erreur 10 se produit si un appareil USB 2.0 (comme POD X3 ou UX8) sont connectés à un port USB 1.x. Connectez ces appareils uniquement aux ports USB 2.0.
J'ai actualisé mes pilotes mais j'au toujours pas une connexion ou reçois une erreur MIDI timeout avec mon appareil Line 6, que puis-je faire?
Le pilote doit être installé correctement. Veuillez visiter ces sites web concernant ca:
Insérez votre appareil Line 6 directement à l'arrière, dans la carte mère de l'ordinateur. N'utilisez pas les hubs USB ou les ports USB de devant. Si vous utilisez un portable, essayez tous les ports USB. (Certains ports sont plus résistants qu'autres.) Débrochez tous les appareils USB inutiles pour réduire la charge du flux des données et désinstallez tous les logiciels inutiles.
Pour autres solutions, visitez ces liens:
Optimisation audio pour le système d'ordinateur
Je ne peux pas trouver des pilotes pour mon Pocket POD, FBV Mk II ou Backtrack. Qu'est-ce que je fais?
Le Pocket POD, FBV Mk II et Backtrack utilisent des pilotes génériques qui sont préinstallés sur votre système d'exploitation. Si vous avez des problèmes de connexion avec ces appareils, essayez différents ports USB et mettez à jour votre système d'exploitation pour recevoir les pilotes génériques les plus récents.
Si vous avez essayé tous les ports USB, et l'ordinateur le reconnait pas votre Appareil ou vous avez une qualité audio très mauvaise (clics, bruits,ââ¬Â¦), peut-être vous avez besoin d'une carte PCI USB 2.0 pour connecter vos appareils USB Line 6.
Je reçois une erreur qui dit que j'ai un appareil Line 6 invalide (erreur: 8000710B) ou le numéro ESN sur mon appareil montre "00000000" si je le connecte avec Line 6 Monkey. Qu'est-ce que je peux faire?
Cette erreur peut se produire si un appareil a été réparé incorrectement dans un centre de service Line 6. L'appareil doit retourner au centre qui a réparé l'appareil pour résoudre ce problème.
