Updating the Spider IV (75, 120, 150, 150HD) using the FBV Mk II and Line 6 Monkey
Deutsch
Français
This document explains how to update the Spider IV (75, 120, 150, 150HD) using the FBV Mk II and Line 6 Monkey using Windows XP, Vista, 7, and Mac OSX 10.4.11, 10.5.8, and 10.6.x. Before you get started, you will need to have your Spider IV connected to the FBV Mk II (Express or Shortboard) using a CAT-5 cable, and you will need to have your FBV Mk II unit connected to an open USB port on the back of your computer (do not use a USB hub). Be sure that your computer is connected to the internet.
Here is a video that shows you how to update your Spider:
Close out any other applications running on your computer before updating the amp.
This update has been successfully performed many times by our users. If you experience connection/timeout issues:
  1. Try another USB cable.
  2. Ensure that the pedal is NOT connected to the computer through a USB hub.
  3. Avoid plugging into USB ports found on keyboards, monitors, or laptop docks.
  4. Make sure to connect the interface into a USB port directly into the computer, especially into the back of a desktop.
  5. If problems persist, make sure to try to get a connection on all of the USB ports on your computer.
If you continue to not get a good connection, you should try the update on another computer, as the first one may have a configuration issue. It is best to also try on a different network in the event your network's configuration is causing the connection issues. Satellite internet, dial-up connections and tethering to a phone are not supported by Line 6.
Line 6 Monkey Instructions:
1) Run Line 6 Monkey and you will be asked which unit you want to work with. Highlight the Spider IV unit and select ‘OK’.
2) If Monkey asks you to register your gear, you can select ‘remind me later’.
3) Highlight ‘flash memory’, then select ‘update selection’.
4) If Monkey asks you to register your gear, you can select ‘remind me later’.
5) Select ‘Yes’ to continue.
6) Select "I Accept" for the software agreement and select ‘continue’.
7) Select ‘Yes’ to update the Flash memory.
8) Allow the unit to go through the update process. This can take up to 5 minutes.
9) Select ‘OK’ when the update is finished.
10) You will see a green check mark in from of flash memory to show it is now up to date.
Das Aktualisierungsverfahren des Spider IV (75, 120, 150, 150HD) anhand eines FBV MkII via Monkey Software wird in diesem Dokument erläutert, für Windows XP, Vista, 7 sowie Mac OSX 10.4.11, 10.5.8 und 10.6.x. Bevor Sie aber loslegen müssen Sie erst das FBV MkII (Shortboard oder Express) via USB an den Computer und mit CAT-5 (RJ45) Kabel an den Spider IV anschließen. Stellen Sie außerdem sicher, dass der Computer eine Internetverbindung hat.
Wie aktualisiere ich mein Spider IV: Video. (nur in englisch verfügbar)
Schließen Sie alle anderen Programme auf Ihrem Computer bevor Sie das Update starten.
Sollten Sie Probleme bei der Aktualisierung haben dann:
  • Versuchen Sie ein anderes USB Kabel,
  • Schließen Sie das Pedal auf keinen Fall über einen USB Hub an. Stecken Sie das Gerät immer direkt hinten in den Computer.
  • Testen Sie es mit allen USB Ports, die zur Verfügung stehen.
Wenn Sie immernoch Probleme haben, versuchen Sie das Update auf einem anderen Computer durchzuführen denn es kann auch an der Konfiguration des Computers liegen. Sie können zudem noch ein anderes Netzwerk austesten, denn eventuell hat Monkey Verbindungsprobleme.
Anweisungen zum Update:
  1. Starten Sie Line 6 Monkey und es sollte Sie auswählen lassen, mit welchem Gerät Sie arbeiten wollen. Markieren Sie den Spider IV und klicken Sie dann auf ‘žOK’.
  2. Wenn Monkey Sie fragt, ob Sie das Gerät registrieren wollen, dann können Sie auch ‘žRemind me later’ anklicken.
  3. Markieren Sie ‘žFlash Memory’ und klicken Sie dann auf ‘žUpdate Selection’.
  4. Wenn Monkey Sie fragt, ob Sie das Gerät registrieren wollen, dann können Sie auch ‘žRemind me later’ anklicken.
  5. Klicken Sie ‘žYes’ um fortzufahren.
  6. Klicken Sie ‘žI Accept’ und dann ‘žContinue’.
  7. Klicken Sie ‘žYes’ um Flash Memory zu aktualisieren, dies kann einige Minuten dauern.
  8. Drücken Sie ‘žOK’ sobald das Update fertig ist.
  9. Vor dem Flash Memory sollten Sie nun ein grünes Häkchen sehen, welches angibt, dass das Update vollständig ist.
Ce document explique comment vous pouvez mettre le Spider IV (75, 120,150 et 150HD) Ã jour en utilisant un Shortboard/Express MkII sur un ordinateur Microsoft et Mac OSX 10.4.11, 10.5.8 et 10.6.X.
Connectez votre FBV MkII au Spider IV. Connectez le FBV MkII avec un câble USB à votre ordinateur, n’™utilisez pas un hub USB. Vérifiez si l’™ordinateur est connecté à l’™internet.
Ici, un vidéo que vous montre le processus. (en anglais)
Fermez tous les autres programmes avant la mise à jour.
Si vous avez de problèmes avec l’™installation :
  1. Éssayez un autre câble USB.
  2. Toujours connectez le câble USB dans l’™arrière de l’™ordinateur.
  3. Éssayez tous les ports USB.
  4. Éssayez un autre ordinateur, c’™est possible que l’™ordinateur a des problèmes de configuration.
  5. Éssayez un autre réseau, c’™est possible que la configuration du réseau cause des problèmes.
Instructions Line 6 Monkey :
  1. Démarrez Line 6 Monkey, le programme vous donne le choix quel appareil vous voulez utiliser. Sélectez le Spider IV et cliquez « OK ».
  2. Si Monkey veut registrer votre appareil, vous pouvez cliquer sur « Remind me later ».
  3. Sélectez Flash Memory et cliquez sur « Update Selection ».
  4. Si Monkey veut registrer votre appareil, vous pouvez cliquer sur « Remind me later ».
  5. Cliquez « Yes » pour continuer.
  6. Cliquez « I Accept » et « Continuer ».
  7. Cliquez « Yes » pour mettre à jour le Flash Memory.
  8. Après l’™installation (jusqu'Ã 5 minutes), cliquez « OK ».
  9. Maintenant, vous pouvez voir une coche verte à côté de Flash Memory.
