Spider IV 15 FAQs and Application
Français
Deutsch
Q: Where are the song settings for the Spider IV 15 that I saw on the box?
A: The Spider IV 15 song settings can be found here:
Spider IV Settings
Q: Where can I get the manual for the Spider IV 15?
Line 6 Manuals
Q: What are the amp models on my Spider IV 15?
A: There are four amp models on the Spider IV 15: Clean, Crunch, Metal, and Insane. The tone settings list numerous songs can be used to dial sounds in as well. If you would like to return your unit to the original presets, please perform a factory reset (see below).
Q: How do I perform a factory reset on my Spider IV 15?
A: The factory reset procedure for a Spider IV 15 is to hold down the clean button as you turn on the power and hold the button for 5-8 seconds.
Q: Is there a 'Boost' & 'Gate' function?
A: Yes. Toggle the boost by holding the 'Tap' button while turning the 'Drive' knob past 12 o'clock. The gate can be toggled similarly, but using the 'Echo/Reverb' knob. See the manual for more information.
Q: Are there any videos I can view to learn about the Spider IV series?
Spider IV movies
Q: How is the Spider IV 15 different than the Spider III 15?
A: The Spider IV 15 amp models have been revoiced, the back is now a "3/4" style,and there is now an FBV controller jack for the FBV2 or FBX Express pedal.
Q: How do I use the tuner on the Spider IV 15?
A: Press the Tuner button, and notice the volume is muted during tuning. The amp model LEDs will indicate when the string you are playing is in tune. The ““Crunch” and ““Metal” LEDs will both light up when the string is in tune. If the Clean or Crunch LED are lit, the string is flat. If Metal or Insane LEDs are lit, the string is sharp. Once all your strings are in tune, press any button to exit Tuner Mode. See the manual for more information.
Setup/Connections
Q: What are the inputs and outputs on the Spider IV 15?
A: Guitars, Microphones, Basses, and Acoustic Guitars can be connected using the 1/4” instrument input. MP3/CD players can be connected using the 3.5 mm jack. Headphones can be connected using the stereo ¼â€ output.
Q: Is there a ““direct out” on the Spider IV 15? What can this be connected to?
A: The headphones jack is a stereo ¼â€ output which can also be used as a recording output or into a PA or stereo system. You can connect an external preamp into the CD input or the Mic input of the Spider IV 15.
Q: Can the Spider IV 15 and the CD/MP3 input be used at the same time? Will I hear both of these devices through the headphones?
A: Yes
Q: Can I use an FBV controller with the Spider IV 15?
A: Yes, the FBV2 and FBV Express (original or Mk II) are recommended for use with the Spider IV 15. The FBV Shortboard (original or Mk II) will work, but there will be a number of buttons that have no functions (i.e. banks, effects, stomps, etc.)
Q: Does the Spider IV 15 have an effects loop?
A: There is not an effect loop on the Spider IV 15 amplifier.
Q: How do I power the Spider IV 15?
A: The Spider IV 15 uses a standard IEC power cable to a wall outlet.
Q: How can I get a cover for the Spider IV 15?
A: The Spider IV 15 does not have a cover available from Line 6 at this time.
Registration/Warranty
Q: What is the warranty on the Spider IV 15?
A: the warranty on the Spider IV 15 is twelve months from the date of purchase.
Q: How can I register my Spider IV 15?
A: Product Registration F.A.Q.
Troubleshooting/Service
Q: My Spider IV 15 seems to be malfunctioning. What can I do as an end user?
A: Line 6 Amp Troubleshooting
Q: Where can I get replacement knobs for my Spider IV 15 amp?
A: Line 6 Store
Ou puis-je trouver les configurations des chansons pour le Spider IV?
Spider IV Settings
Ou est-ce que je peux lire le mode d’emploi ?
Line 6 Manuals
Quels sont les modèles d’ampli sur le Spider IV 75 ?
Le Spider IV a quatre modèles : Clean, Crunch, Metal et Insane. Les modèles ont des configurations de ton pour ajuster le individuellement. Si vous voulez les preset originales, vous pouvez réinitialiser le Spider IV.
Comment est-ce que je réinitialise mon Spider IV ?
Maintenez enfoncé le bouton Clean tandis que vous allumez l’appareil. Pour 5-8 secondes.
Y a-t-il une fonction « Boost & Gate » ?
Oui, maintenez enfoncé le bouton « Tap » et tournez « Drive » en même temps pour « Boost ». « Gate » fonctionne de même façon, mais avec le bouton « Echo/Reverb » plutôt que le bouton « Drive ».
Y a-t-il des vidéos tutoriels pour le Spider IV ?
Spider IV movies (en anglais)
Quelle est la différence entre le Spider IV 15 et le Spider IV 15 ?
Le Spider IV a été réharmonisé, le dos est un ¾ et il y en a un Jack FBV pour les pédales FBV2 et FBV Express.
Comment est-ce que j’utilise l’accordeur avec le Spider IV ?
Poussez le bouton Tuner. Les LEDs sur le modèle d’ampli vous signifie à quel moment la corde est accordée. « Crunch » et « Metal » éclairent si la corde est accordée. Si Crunch ou Clean éclairent, la corde est plat. Si « Metal » ou « Insane" éclairent, la corde est tranchante. Poussez aucun bouton pour sortir ce menu.
Installation et connexions :
Quels sont les sorties et entrées sur le Spider IV ?
Guitares, Micros, Basses et guitares acoustiques via l’entrée de des instruments principale, une entrée 1/4".
Y a-t-il un Direct Out sur le Spider IV ?
Le jack micro est une sortie 1/4’’ que vous pouvez utiliser comme sortie d’enregistrement. Vous pouvez connecter un préampli externe au CD IN et MIC IN.
Est-ce qu’on peut utiliser les entrées CD/MP3 et Guitare en même temps ?
Oui.
Puis j’utiliser le contrôleur FBV avec le Spider IV 15?
Oui, FBV2 et FBV Express sont recommandés mais le FBV Shortboard fonctionne aussi. Il y en a quelques boutons sui fonctionnent pas.
A-t-il un effects loop ?
Non.
Comment est-ce que j’allume le Spider IV 15?
L’appareil utilise un câble standard IEC.
Est-ce que je peux acheter une couverture pour l’ampli ?
Non, on ne produit pas de couvertures pour ce modèle.
Régistration et garantie :
Quelle est la garantie sur le Spider IV 15 ?
12 mois à partir de la date d’achat.
Comment est-ce que je peux registrer mon Spider IV 15 ?
Dépannage et service :
Qu’est-ce que je peux faire si mon Spider IV 15 a des problèmes ?
Où est ce que je peux acheter des boutons de remplacement?
Line 6 Store
Wo kann ich die Song Einstellungen des Spider IV 15 finden, die ich auf der Box gesehen habe?
Spider IV Settings
Wo kann ich das Benutzerhandbuch des Spider IV 15 lesen?
Line 6 Manuals
Welche Verstärkermodelle hat der Spider IV 15?
Der Spider IV 15 hat vier verschiedene Modelle installiert: Crunch, Clean, Metal und Insane. Die Tone Settings Liste hat zudem noch unzählige Songs, die Sie auch benutzen können. Um alle original Presets zurückzubekommen können Sie das Gerät auf Werkseinstellungen zurücksetzen.
Und wie setze ich den Spider IV 15 zurück?
Halten Sie beim Starten des Gerätes den Clean Knopf für 5-8 Sekunden gedrückt.
Gibt es Boost und Gate Funktionen?
Ja, Boost können Sie benutzen indem Sie den Tap Knopf gedrückt halten und den Drive Knopf gleichzeitig weiter als 12 Uhr drehen. Die Gate Funktion wird ähnlich aktiviert, nutzen Sie aber anstelle von Drive den Echo/Reverb Knopf.
Gibt es Tutorial Videos für den Spider IV 15?
Spider IV movies
Was ist der Unterschied zwischen dem Spider IV 15 und dem Spider II 15?
Die Verstärkermodelle auf dem Spider IV wurden neuvertont, außerdem ist der Spider IV ein ¾ Verstärker und es gibt einen neuen FBV Stecker für das FBV2 oder FBV Express Pedal.
Wie kann ich den Tuner des Spider IV benutzen?
Drücken Sie auf den Tuner Knopf. Die Amp Model LEDs werden Ihnen dann anzeigen ob die Saite, die Sie spielen korrekt gestimmt ist. Wenn Crunch und Metal LEDs leuchten, dann bedeutet das, das die Saite gestimmt ist. Wenn Clean und Crunch LEDs leuchten, dann ist die Saite tief. Wenn Metal und Insane leuchten, dann ist die Saite hoch. Wenn alle Saiten gestimmt sind können Sie einfach irgendeinen Knopf drücken, um das Menu zu verlassen.
Installation und Anschlüsse:
Welche Ein- und Ausgänge hatder Spider IV 15?
Gitarren, Mikrofone, Bässe und akustik Gitarren können an den ¼““ Instrumenteingang angeschlossen werden. MP3/CD Spieler können an den 3.5mm Jack angeschlossen werden und Kopfhörer an den ¼““ Stereoausgang.
Gibt es ein “¾Direct Out““ am Spider IV 15?
Der Kopfhöreranschluss ist ein ¼““ stereo Jack der auch als Aufnahmeausgang benutzt werden kann, wie für eine PA oder eine Stereoanlage. Einen externen Vorverstärker können Sie an den CD oder den Mikrofon Eingang des Spider IV 15 anschließen.
Kann ich Gitarren- und CD/MP3 Eingänge gleichzeitig benutzt werden?
Ja.
Kann ich eine FBV Steuerung mit dem Spider IV 15 benutzen?
Ja, wir empfehlen die Nutzung des FBV2 oder FBV Express. Der FBV Shortboard funktiniert auch aber manche Knöpfe funktionieren nicht.
Hat der Spider IV 15 einen Effects Loop?
Nein.
Wie versorge ich den Spider IV 15 mit Strom?
Mit einem ganz normalen IEC Kabel, welches Sie in die Steckdose stecken.
Wo kann ich eine Schutzhülle für den Spider IV 15 kaufen?
Line 6 stellt zur Zeit leider keine Schutzhüllen für den Spider IV 15 her.
Registrierung und Garantie:
Wieviel Garantie habe ich auf dem Spider IV 15?
12 Monate ab Kaufdatum.
Wie kann ich mein Spider IV 15 registrieren?
Fehlerbehebung und Service:
Mein Spider IV scheint nicht korrekt zu funktionieren, was kann ich tun?
Line 6 Amp Fehlerbehebung
Wo kann ich Ersatzknöpfe kaufen?
Line 6 Store
