Q: What are the presets on my Micro Spider amplifier?
A: There are five presets on the Micro Spider: Clean, Crunch, Metal, Insane, and Acoustic. If you would like to return your unit to the original presets, please perform a factory reset.
Q: How do I perform a factory reset on my Micro Spider?
A: The factory reset for a Micro Spider is to hold down the clean button as you turn on the power and hold the button for 5-8 seconds.
Q: Are there any videos I can view to learn about the Micro Spider?
Q: Can the Micro Spider microphone input and/or the CD/MP3 input be used at the same time with the same guitar input? Will I hear all of these devices through the headphones?
A: Yes
Q: I noticed that the mid-range knob reacts differently on my Micro Spider's Insane Setting than other Spider amplifiers I have played on?
A: The Micro Spider's midrange control is optimized for the volume/tone features for that particular patch, so the control response may seem a little different than other Spider amplifiers.
Q: Is there a ââ¬Åvocal eliminatorââ¬Â so I can jam with my CD/MP3 input without the vocals getting in the way of my incredible shredding?
A: No, but that usually doesn't stop people from shredding.
Setup/Connections
Q: What can I connect to the Micro Spider?
A: Guitars, Microphones, Basses, Acoustic Guitars, via the 1/4ââ¬Â instrument input. MP3/CD players via the 3.5 mm jack, headphones via the stereo üââ¬Â output.
Q: Is there a direct out on the Micro Spider?
A: The headphones jack is a stereo üââ¬Â output which can also be used as a recording output.
Q: Can I use an FBV controller with the Micro Spider?
A: There is no FBV control capability on the Micro Spider.
Q: Can I connect an external pre-amp (i.e. Line 6 POD) to the Micro Spider? Can I connect the Micro Spider into a PA system of home stereo?
A: You can connect an external preamp into the CD input or the Mic input of the Micro Spider, and connect the headphone outputs of the Micro Spider into a PA or stereo system.
Q: Does the Micro Spider have an effects loop?
A: There is no effect loop on the Micro Spider amplifier.
Specifications
Q: How do I power my Line 6 Micro Spider?
A: You can use the Line 6 PX 2 (included), or you can use six (6) C-cell batteries (not included).
Q: How can I get a cover for the Micro Spider?
A: The Micro Spider does not have a cover available from Line 6 at this time.
Registration/Warranty
Q: What is the warranty on the Micro Spider?
A: the warranty on the Micro Spider is twelve months from the date of purchase.
Q: How can I register my Micro Spider?
https://line6.com/account/registergear/
Troubleshooting/Service
Q: My Micro Spider seems to be malfunctioning. What can I do as an end user?
Q: Where can I get replacement knobs/speakers/logos for my Micro Spider amp?
A: Line 6 Store
Q: Where can I download a Micro Spider manual?
Welche Presets sind auf dem Micro Spider vorinstalliert?
Es sind 5 Presets bereits auf dem Spider installiert: Clean, Crunch, Metal, Insane und Acoustic. Sollten Sie die Presets zurücksetzen wollen, dann müssen Sie das Gerät auf die Werkseinstellungen zurückstellen.
Wie kann ich main Spider Micro auf Werkseinstellungen zurücksetzen?
Halten Sie einfach die Clean Taste für 5-8 Sekunden während des Startens des Gerätes gedrückt.
Gibt es Tutorial Videos für den Micro Spider?
Können Mikro und/oder CD/MP3 Eingänge gleichzeitig mit dem Gitarreneingang verwendet werden? Und kann ich dann alle Geräte noch durch die Kopfhörer hören?
Ja und Ja.
Der Mid Knopf reagiert anders im Insane Preset als auf anderen Spider Verstärkern, ist das normal?
Ja, das ist so gewollt.
Gibt es einen Vocal Eliminator?
Nein.
Installation und Anschlüsse
Welche geräte kann ich an den Micro Spider anschließen?
Gitarren, Mikrofone, Bässe und akustik Gitarren können an den üââ¬Å Instrumenteeingang, Mp3/CD Spieler an die 3,5mm Klinke und Kopfhörer an den üââ¬Å Ausgang angeschlossen werden.
Gibt es einen Direct Out?
Die Kopfhörer üââ¬Å Klinke ist ein stereo Anschluss, der zur Aufnahme verwendet werden kann.
Kann ich einen FBV Controller mit dem Micro Spider benutzen?
Nein, der Verstärker ist nicht kompatibel.
Kann ich einen externen Vorverstärker oder eine Stereoanlage anschließen?
Ja, den Vorverstärker können Sie an den CD oder Mikro Input anschließen und die Stereoanlage an den Kopfhörerausgang.
Hat der Micro Spider einen Effects Loop?
Nein.
Spezifikationen:
Wie versorge ich mein Micro Spider mit Strom?
Entweder mit einem Line 6 PX 2 (enthalten) oder mit sechs C Batterien.
Woher bekomme ich eine Schutzhülle?
Line 6 stellt leider keine Schutzhüllen für den Micro Spider her.
Registrierung und Garantie:
Wie lange habe ich Garantie auf den Micro Spider?
12 Monate vom Kaufdatum.
Wie kann ich meinen Verstärker registrieren?
https://de.line6.com/account/registergear/
Problembehebung und Service:
Mein Micro Spider macht Probleme, was kann ich tun?
https://line6.com/support/page/articles/_/general-faq/amplifier-troubleshooting-r439#de
Wo bekomme ich Ersatzknöpfe/lautsprecher oder Logos her?
Wo kann ich das Benutzerhandbuch herunterladen?
Quels sont les presets sur mon Micro Spider ?
Il y en a cinq presets : Clean, Crunch, Metal, Insane et Acoustic. Si vous voulez les presets originaux, vous devez réinitialiser l’appareil.
Comment est-ce que je réinitialise l’appareil ?
Tandis que vous allumez l’appareil, maintenez enfoncé le bouton Clean pour 5 à 8 secondes.
Y a-t-il des vidéos tutoriels sur le Micro Spider ?
Puis-je utiliser les entrées Micro et/ou CD/MP3 avec la même entrée guitare en même temps ? Est-ce que je peux entendre tous ces appareils dans les casques ?
Oui.
Le bouton Mid fonctionne différemment sur Insane avec le Micro Spider en comparaison avec les autres amplis Spider, est-ce que c’est normal ?
Oui, c’est normal.
Y a-t-il un ë Vocal Eliminator û ?
Non.
Installation et Connexions :
Quels appareils puis-je connecter au Micro Spider ?
Guitares, Microphones, Basses et Guitares Acoustiques à l’entrée 1/4’’ Instrument. Lecteurs MP3 et CD au 3.5mm jack et les casques à la sortie 1/4" stéréo.
Y a-t-il en Direct Out ?
Le jack de casques est une sortie 1/4" stéréo que vous pouvez utiliser comme sortie d’enregistrement.
Puis-je utiliser un contrôleur FBV avec le Micro Spider ?
Non.
Est-ce qu’on peut connecter un préampli externe ou une chaine stéréo ?
Vous pouvez connecter un préampli externe à l’entrée CD ou Micro et connecter une chaine stéréo à la sortie de casques.
Y a-t-il un Effects Loop ?
Non.
Spécifications :
Comment puis-je alimenter mon Micro Spider ?
Vous pouvez utiliser un Line 6 PX 2 ou six batteries C.
Ou est-ce que je peux acheter une couverture ?
Line 6 ne produit pas des couvertures pour le Micro Spider à ce moment.
Régistration et Garantie :
Combien de garantie y a-t-il sur le Micro Spider ?
12 mois au départ de la date d’achat.
Comment puis-je enregistrer mon Micro Spider ?
https://fr.line6.com/account/registergear/
Dépannage et Service :
Quelque chose ne fonctionne pas, qu’est-ce que je fais ?
https://line6.com/support/page/articles/_/general-faq/amplifier-troubleshooting-r439#fr
Ou puis-je télécharger le mode d’emploi ?
