Spider IV 30 FAQs
Deutsch
Français
Application
Q: Where are the song settings for the Spider IV 30 that I saw on the box?
A: The Spider IV 30 song settings are a PDF download at the following link:
Spider IV Settings
Q: What are the amp models on the Spider IV 30?
A: There are a twelve total amp models on the Spider IV 30. There are two versions (red and green) of the following amp models: Clean, Twang, Blues, Crunch, Metal, and Insane.
Clean Red: Crisp, amazing clean tones.
Clean Green: Based on a 1973 Hiwatt custom 100 with extended tone control range and tightened up the low end.
Twang Red: based on mid 60’s Fender amps.
Twang Green: based on vintage tweed amps (i.e.’53 Fender tweed Deluxe, ’58 Fender tweed Bassman and a ’60 Gibson Explorer).
Blues Red: Three helpings of ’65 Marshall JTM-45, one scoop of ’58 Fender Bassman, a schmeer of ’63 Fender Vibroverb, and a dash of Supro for good measure.
Blues Green: Based on a fawn Vox AC-30 amplifier with an updated and expanded tone control circuit.
Crunch Red: Based on a '68 Marshall Plexi 50 Watt head.
Crunch Green: Based on a ‘68 Marshall Plexi 100 watt with a few added extras; the combination of a Variac and jumpered input channels.
Metal Red: based on the Mesa Dual Rectifier with enhancements.
Metal Green: An aggressive high gain Amp Model with a unique Mid control that will sweep though an entire spectrum of tone on one knob.
Insane Red: Line 6’s “dialed in for shreddingâ€� version of the Mesa Dual Rectifier red channel.
Insane Green: You get an obscene helping of distortion, while still retaining tonal definition and character.
The tone settings list numerous songs can be used to dial sounds in as well. If you would like to return your unit to the original presets, please perform a factory reset (see below).
Q: How do I use the tuner on the Spider IV 30?
A: Press the Tuner button, and notice the volume is muted during tuning. The amp model LEDs will indicate when the string you are playing is in tune. The 'Crunch' and 'Metal' LEDs will both light up when the string is in tune. If the Clean or Crunch LED are lit, the string is flat. If Metal or Insane LEDs are lit, the string is sharp. Once all your strings are in tune, press any button to exit Tuner Mode.
Q: How do I perform a factory reset on the Spider IV 30?
A: The factory reset procedure for a Spider IV 30 is to hold down the 'A' button as you turn on the power and hold the button for 5-8 seconds.
Q: Are there any videos I can view to learn about the Spider IV series?
Spider IV movies
Q: How is the Spider IV 30 different than the Spider III 30?
A: THe Spider IV 30 amp models have been expanded (from 4 to 12) and re-voiced, and the back is now a "3/4" style. See the FBV controller information for added control features below.
Setup/Connections
Q: What are the inputs and outputs on the Spider IV 30?
A: Guitars, Microphones, Basses, and Acoustic Guitars can be connected using the 1/4" instrument input. MP3/CD players can be connected using the 3.5 mm jack. Headphones can be connected using the stereo ¼" output.
Q: Is there a 'direct out' on the Spider IV 30? What can this be connected to?
A: The headphones jack (a stereo ¼" output) can also be used as a recording output or into a PA or stereo system. You can connect an external preamp into the CD input or the Mic input of the Spider IV 30.
Q: Can the Spider IV 30 and the CD/MP3 input be used at the same time? Will I hear both of these devices through the headphones?
A: Yes
Q: Can I use an FBV controller with the Spider IV 30?
A: Yes, the FBV2 and FBV Express (original or Mk II) are recommended for use with the Spider IV 30. The FBV Shortboard (Mk I or II) may work (but is not supported) and will allow access the 'bonus' 36 presets by being able to switch between banks 1-9. Be aware that while most end users will not have a problem with the Shortboard connections, slight voltage fluctuations from your wall outlet may cause the Spider IV 30 to power cycle itself if the FBV shortboard is connected. If this happens, simply remove the FBV shortboard.
Q: Does the Spider IV 30 have an effects loop?
A: There is no effect loop on the Spider IV 30 amplifier.
Specifications
Q: How do I power the Spider IV 30?
A: The Spider IV 30 uses a standard IEC power cable to a wall outlet.
Q: How can I get a cover for the Spider IV 30?
A: The Spider IV 30 does not have a cover available from Line 6 at this time.
Registration/Warranty
Q: What is the warranty on the Spider IV 30?
A: the warranty on the Spider IV 30 is twelve months from the date of purchase.
Line 6 Warranty Information
Q: How can I register my Spider IV 30?
product registration F.A.Q.
Troubleshooting/Service
Q: My Spider IV 30 seems to be malfunctioning. What can I do as an end user?
Line 6 Amp Troubleshooting
Q: Where can I get a cover or replacement knobs for my Spider IV 30 amp?
Line 6 Store
Wo kann ich die Song Einstellungen finden, die ich auf der Box gesehen habe?
Die Spider IV Song Einstellungen können Sie heir als PDF Datei finden:
Spider IV Settings
Welche Verstärkermodelle sind auf dem Spider IV 30?
Auf dem Spider IV 30 sind insgesamt 12 Verstärkermodelle installiert. Für die folgenden Modelle gibt es jeweils zwei Versionen, eine Green und eine Red Version: Clean, Twang, Blues, Crunch, Metal und Insane.
Clean Red: Tolle, knackig saubere Töne.
Clean Green: Auf Basis eines Hiwatt custom 100W von 1973 mit erweiterter Tonreichweite.
Twang Red: Auf Basis von Fender Verstärkern der 60er Jahre.
Twang Green: Auf Basis verschiedener Vintage Tweed Verstärker, ein 53er Fender Tweed Delxue, ein 58er Fender Tweed Bassman und ein 60er Gibson Explorer.
Blues Red: Auf Basis eines 65er Marshall JTM-45, eines 58er Fender Bassman, eines 63er Fender Vibroverb sowie eines Supro.
Blues Green: Auf Basis eines Vox AC-30 mit modifizierten Schaltkreisen.
Crunch Red: Auf Basis eines 68er Marshall Plexi Topteils von 50W.
Crunch Green: Auf Basis eines 68er Mashall Plexi 100W mit kleineren Extras.
Metal Red: Auf Basis eines Mesa Dual Rectifiers mit Verbesserungen.
Metal Green: Ein aggressiver High Gain Sound mit einzigartiger Mid Kontrolle.
Insane Red: Line 6 Shred Version des roten Kanals eines Mesa Dual Rectifiers.
Insane Green: Massig Verzerrung bei maximaler Definition.
Wie benutze ich den Tuner des Spider IV 30?
Drücken Sie den Tuner Knopf, der Verstärker sollte sich nun stumm stellen. An den Verstärkermodell LEDs können Sie dann erkennen ob die Saiten gestimmt sind. Wenn Crunch und Metal leuchten, dann ist die Saite gestimmt, leuchtet Clean oder Crunch dann ist Sie zu tief und wenn Metal oder Insane leuchten, dann ist Sie zu hoch. Wenn dann alle Saiten gestimmt sind können Sie irgendeinen Knopf drücken um den Tuner Modus zu verlassen.
Wie kann ich das Gerät auf Werkseinstellungen zurückstellen?
Halten Sie den A Knopf einfach für 5-8 Sekunden während des Startens des Verstärkers gedrückt.
Gibt es Videos zur Spider IV Serie?
Spider IV movies
Was ist der Unterschied zwischen Spider IV 30 und Spider III 30?
Der Spider IV 30 hat zusätzliche 8 Modelle und ist komplett neu gestimmt und der Verstärker ist nun im ¾â€œ Stil.
Installation und Anschlüsse:
Welche Ein- und Ausgänge gibt es?
Gitarren, Mikrofone, Bässe und Akustikgitarren können Sie an den ¼â€œ Instrumenteingang anschließen, MP3 und CD Spieler an den 3.5mm Jack und Kopfhörer an den ¼â€œ Stereo Ausgang.
Hat der Verstärker einen Direct Out?
Der ¼â€œ Kopfhörerausgang kann als Ausgang für Aufnahmen verwendet werden oder an eine PA oder Stereoanlage angeschlossen werden. Einen externen Vorverstärker können Sie an den CD Eingang oder den Mikrofoneingang anschließen.
Kann ich Instrument- sowie CD/MP3 Eingang gleichzeitig benutzen und das ganze auf meine Kopfhörer spielen?
Ja.
Kann ich einen FBV mit dem Spider IV 30 benutzen?
Ja, FBV2 und FBV Express (original oder MkII) sind empfohlen. Das FBV Shortboard (MkI oder MkII) funktioniert eventuell und ist damit auch nicht unterstützt. Die meisten Benutzer haben mit dem Shortboard keine Probleme, Stromschwankungen können aber den Verstärker zum Abschalten bringen wenn das Shortboard angeschlossen ist. Wenn das passiert, trennen Sie das Shortboard einfach vom Verstärker.
Hat der Spider IV 30 einen Effects Loop?
Nein.
Spezifikationen:
Wie kann ich den Spider IV 30 mit Strom versorgen?
Der Verstärker braucht ein ganz normales IEC Stromkabel.
Woher bekomme ich eine Schutzhülle für den Verstärker?
Line 6 stellt leider zurzeit keine Schutzhüllen für den Spider IV 30 her.
Registrierung und Garantie:
Wie lange habe ich Garantie auf den Verstärker?
Die Garantie auf dem Verstärker beträgt 12 Monate ab Kaufdatum.
Line 6 Garantieinformationen
Wie kann ich mein Gerät registrieren?
Produktregistrierung: F.A.Q.
Fehlerbehebung und Service:
Mein Spider IV hat Probleme, was kann ich tun?
Wo kann ich Ersatzteile für mein Spider IV 30 kaufen?
Line 6 Store
Ou puis-je trouver les configurations de chansons que j’ai vu sur la boîte ?
Vous pouvez les trouver ici : Spider IV Settings
Quels sont les modèles d’amplis sur mon Spider IV 30 ?
Il y en a 12 modèles d’amplis en total. Les modèles suivantes ont deux versions (une version verte et une version rouge) : Clean, Twang, Blues, Crunch, Metal et Insane.
Clean Red : Pour un ton brillant et clair.
Clean Green : Basé sur un Hiwatt Custom 100 modifié de 1973.
Twang Red : Basé sur les amplis Fender des années 60.
Twang Green : Basé sur des amplis tweed vintage comme le Fender Tweed Deluxe de 1953, le Fender Tweed Bassman de 1958 et le Gibson Explorer de 1960.
Blues Red : Une mixture de plusieurs amplis : le Marshall JTM-45 de 1965, un Fender Bassman de 1958, un Fender Vibroverb de 1963 et un Supro.
Blues Green : Basé sur un Vox AC-30 avec circuit modifié.
Crunch Red : Basé sur une tête ampli Marshall Plexi 50 Watt de 1968.
Crunch Green : Basé sur un Marshall Plexi 100 Watt.
Metal Red : Basé sur un Mesa Dual Rectifier avec quelques augmentations.
Metal Green : Un modèle à gain élevé très agressive et une contrôle des Mis très spéciale.
Insane Red : La version Shred de Line 6 d’un Mesa Dual Rectifier en canal rouge.
Insane Green : Beaucoup de distorsion mais avec toute la définition tonale.
Comment puis-je utiliser le Tuner sur mon Spider IV 30 ?
Poussez le bouton Tuner, l’ampli est muet maintenant. Les LEDs des modèles amplis vous montrent si une corde est accordée. Crunch et Metal s’allument si la corde est accorée. Si Clean ou Crunch sont allumé, la corde est plat et si Metal ou Insane sont allumé, la corde est forte. Poussez n’importe quel bouton pour fermez le mode Tuning.
Comment puis-je réinitialiser l’appareil ?
Maintenez enfoncé le bouton A pour 5 à 8 secondes tout en allumant le Spider.
Y a-t-il des vidéos pour le Spider IV ?
Spider IV movies
Quelle est la différence entre Spider IV 30 et Spider III 30?
Vous avec plus de modèles de 4 Ã maintenant 12 modèles. Et l’arrière est maintenant ¾.
Installation et Connexion :
Quels entrées et sorties est-ce que je peux trouver sur le Spider IV 30 ?
Vous pouvez connecter Guitares, Microphones, Basses et Guitares Acoustiques au connecteur instrument 1/4" ; les lecteurs MP3 et CD au jack 3.5mm et les casques à la sortie stéréo 1/4".
Y a-t-il un Direct Out ?
Vous pouvez utiliser le jack de casques comme sortie d’enregistrement et connecter un préampli externe à la sortie Mic.
Puis-je utiliser l’entrée instrument en même temps que l’entrée CD/MP3 ? Pui-je écouter tous ça avec mes casques ?
Oui, pas de problème.
Puis-je utiliser un contrôleur FBV avec mon Spider IV 30 ?
Oui, le FBV2 et FBV Express (originale ou MkII) sont recommandés. Le FBV Shortboard (MkI et MkII) peut fonctionner mais n’est pas supporté.
Y a-t-il un Effects Loop ?
Non.
Spécifications :
Comment puis-je allumer le Spider IV 30 ?
Avec un câble standard IEC.
Est-ce que je peux acheter une couverture pour mon Spider IV 30 ?
Line 6 ne produit pas des couvertures à ce moment.
Régistration, garantie :
Y a-t-il une garantie avec le Spider IV 30 ?
Oui, une garantie de 1 année.
Comment puis-je enregistrer mon Spider IV 30 ?
Registration des produits Line6
Dépannage et Service:
J’ai des problèmes avec mon Spider IV 30, qu’est-ce que je fais ?
Dépannage des amplis Line6
Puis-je acheter des remplacements ?
Line 6 Store
