Q: What are the input connections for the Spider Cabinet?
A: The left or right input (single cable) connection is 4 ohms, with all four (4) speakers active. When both cables are used there will be an 8 ohm load on each side, using two (2) speakers for each side.
Q: How should the Spider head be connected to the Spider cabinet?
Spider II/III HD 75
- The HD75 is a mono head, which will have the same 75 watt/4 ohm total output when using one or two speaker cables between the head and cabinet.
Spider II/III/IV HD 150:
- The stereo outputs of the Spider 150 HD Series are rated at 8 ohms per side. You will need to connect both outputs of the head to both the Spider cabinet inputs. Be sure to use two (2) speaker cables to connect your head to your cabinet to ensure you have the correct ohm load. Be Careful not to use instruement cables to make this connection. Using instrument cables can produce a lower output volume than expected when the master is set between 6 and 9 o'clock, with the master volume is between 9 and 12 o'clock your signal can become extremely distorted, with the master volume at 12 o'clock or higher you will loose output all together. Be aware that the Spider cabinet jacks will produce an impedance of 4 ohms (either left or right jacks) when a single cable is connected, which will damage the Spider 150 HD.
Q: Can I use other cabinets besides the Spider cabinet?
A: Yes, the Spider HD and 150 (combo) series will work with any standard stereo 4x12 cabinet with two 8 ohm loads. Be aware that many guitar speaker cabinets will not have the flat response speakers found in Spider Cabinets, so the tone may be different than originally intended. A 16 ohm stereo cabinet will sound about 3dB quieter than an 8 ohm cab, but would not damage the Spider HD. A 4 ohm load on the other hand, will damage the Spider HD 150.
Q: What are the speakers the Spider 4x12 cabinet?
A: The Line 6 Spider cabinet uses four (4) 12" speakers rated at 16 ohm. The custom Celestion speaker manufactuered specifically for Line 6, but a common replacement speaker is the Celestion 70/80 speaker.
Q: Is there a video where I can see the Spider Head and cabinet connections?
Line 6 Head and Cabinet Connections
Quels sont les entrées pour le Spider Cab?
Les entrées gauche et droite sont 4 Ohms avec tous les haut-parleurs actifs (4). Les deux en même temps sont 8 Ohms avec 2 haut-parleurs par côté.
Comment est-ce que je connecte la tête d’ampli avec le baffle Spider ?
Spider II/III HD 75
Le HD75 est une tête d’ampli mono. Il a 75 watt à 4 ohms si vous utilisez 1 ou 2 câbles entre tête d’ampli et baffle.
Les sorties stéréo du Spider 150 HD sont 8 ohms par côté. Vous devez brancher les deux sorties de la tête aux entrées du baffle. Utilisez 2 câbles haut-parleurs pour connecter la tête d’ampli au baffle. N’utilisez pas des câbles instruments. Les jacks du Spider baffle produisent une impédance de 4 ohms si un câble seul est connecté. Ce endommagera le Spider 150 HD.
Puis-je utiliser des autres baffles ou seulement le Line 6 baffle ?
Oui, Spider HD et 150(combo) fonctionnent avec tous les baffles standards stéréo 4x12 avec 8 ohms. Beaucoup de baffles guitares n’ont une réponse en fréquence plate comme les Spider IV. Un baffle 16ohms est plus ou moins 3dB plus faible qu’un baffle 8ohms mais cette configuration n’endommage pas le Spider HD. Attention, 4ohms endommageraient le HD 150.
Quels haut-parleurs est-ce que vous installez dans le baffle 4x12 Spider?
On utilise 4 hautparleurs de 12’’ à 16ohms. On installe des Celestion Custom, spécialement fabriqué pour Line 6 mais le Celestion 70/80 est le hautparleur de remplacement général.
Y a-t-il une vidéo des connexions du Spider ?
Was hat die Spider Box für Verbindungen?
Der linke und rechte Eingang sind beide 4 Ohm bei allen 4 Lautsprechern angeschlossen. Wenn Sie beide Eingänge gleichzeitig benutzen, dann wird eine Impedanz von 8 Ohm auf beiden Seiten entstehen. 2 Lautsprecher pro Seite.
Wie soll ich Spider Topteil mit Box verbinden?
Spider II/III HD 75:
Der HD75 ist ein mono Topteil, welches 75 Watt und 4 Ohm Ausgang hat wenn 1 oder 2 Kabel benutzt werden.
Die Stereo Ausgänge das Spider HD 150 sind 8 Ohm pro Seite. Sie müssen beide Ausgänge an die Spider Box Eingänge anschliessen. Nutzen Sie dazu bitte nur Lautsprecherkabel und keine Instrumentkabel. Achtung, die Jacks werden eine 4 Ohm Impedanz produzieren wenn nur ein Kbale angeschlossen ist.
Kann ich andere Boxen benutzen?
Ja, Spider HD und 150(combo) werden mit den meisten 4x12 Verstärkern bei 8Ohm verschiedene. Aber achtung, diese Boxen haben oftmals keine Flachreaktioneszeit. Ein 16 Ohm Lautsprecher wird ca. 3dB leiser sein als 8Ohm aber sie werden den Verstärker auch nicht zerstören. Wenn aber 4 Ohm Ladung angeschlossen wird, wird das höchstwahrscheinlich den Spider HD 150 beeinflussen.
Welche Lautsprecher sind eingebaut?
Der Line 6 Spider Box mit 12ââ¬Ëââ¬Ë Lautpsrechern an 16 Ohm. Wir benutzen einen speziell für Line 6 hergestellten Celection Custom Lautsprecher. Die Celestion 70/80 ist ein verbreiteter Ersatzlautsprecher.
Gibt es ein Video zur Verbindung des Topteils und der Box?
