Version française.
Deutsche Version.
We always recommend that you run the latest firmware in your AMPLIFi amplifier. Your AMPLIFi Remote application will inform you whenever a firmware update is available, so you'll always know you have the latest version! Follow the instructions below to update the firmware of your AMPLIFi.
Here is outline of the steps needed to complete the AMPLIFi Firmware update process:
Pair AMPLIFi 30/75/150/TT via Bluetooth with iOS device.
Start and complete the update from AMPLIFi Remote app Settings page.
Follow post-update instructions that appear within the AMPLIFi Remote app:
Turn the AMPLIFi 30/75/150/TToff.
Power up AMPLIFi 30/75/150/TT while pressing Large Master Volume and Tone Select button.
Re-pair the Bluetooth connection between the AMPLIFi and your iOS device.
Exit the AMPLIFi Remote app by double-pressing the Home button then drag the AMPLIFi Remote app window up towards the top of the screen completely close the app.
Re-launch the AMPLIFi Remote app and you should see your AMPLIFi 30/75/150/TT connect again automatically to the app.
**Before getting started ensure that your iOS device has a consistent connection to a cellular or wifi network. We recommend to make sure your iOS device has at least a 50% charge on the battery or plug your iOS device into it's power supply to prevent the iOS device from shutting down during the update. While performing the update we also recommend that leave your iOS device idle within close proximity and unobstructed line of sight of the AMPLIFi to avoid interruptions in the updating process. **
CLICK HERE for a video tutorial on Bluetooth Pairing your AMPLIFi.
CLICK HERE for a video tutorial on updating the firmware on your AMPLIFi.
Full Instructions
Enable Bluetooth on the device you would like to stream audio from.
Put the AMPLIFi 30/75/150/TT into 'Pairing Mode' by pressing and holding the Bluetooth button located on the upper left of the top panel - it will begin to flash to indicate it is in 'Pairing Mode'.
Within the Bluetooth options of your device an entry for 'AMPLIFi' will appear.
Select the 'AMPLIFi' entry and pair with it - the Bluetooth LED will stop flashing and become solid lit blue.
Download the AMPLIFi Remote app directly from the Apple App store.
Launch the AMPLIFi Remote app.
Log in to your Line 6 user account. If you do not already have a Line 6 user account, you can create one
HERE
or with the link provided on-screen within the app.
Once the app is launched, tap the 'Menu' icon in the upper left corner.
Tap the 'Settings' icon in the lower left of the menu.
From the 'Settings' menu, tap the option labeled 'Amp Flash'.
You will then see the updates available for your AMPLIFi 30/75/150/TT.
To begin the update process simply tap the 'Update' button and allow 10-45 minutes for the update to complete.
After you receive a notification from the AMPLIFi Remote App that the update portion of the process was completed successfully turn off the AMPLIFi 30/75/150/TT.
While pressing and holding both the large Master Volume knob and the Tone Select button, switch the power back on the AMPLIFi 30/75/150/TT.
Re-pair the Bluetooth connection between the AMPLIFi 30/75/150/TT and your iOS device.
If your firmware update is interrupted and unsuccessful the AMPLIFi hardware may display symptoms such as all of it's LEDs being lit or flashing. In this case, try again to use the AMPLIFi Remote app to update the firmware and make sure to review our AMPLIFi Bluetooth Connectivity Troubleshooting information HERE.
Q: What should I do if the update is accidentally interrupted or fails?
A: If your update is accidentally interrupted or fails turn your AMPLFi off and back on again. Press the Bluetooth button once and re-pair your AMPLIFi with your iOS device. Re-start the update in the Setting page of the AMPLIFi Remote app.
Q: What happens if I receive a call while the amp is updating?
A: If you receive a call while your AMPLIFi is updating make sure to stay within range of the AMPLFi, and when you call completes the update will resume.
AMPLIFi 30/75/150/TT: Firmwareupdate
Wir empfehlen, die Firmware ihres AMPLIFi Verstärkers immer auf dem neuesten Stand zu halten. Ihre AMPLIFi Remote App wird Sie immer davon informieren wenn ein neues Firmware Update zur Verfügung steht. So können Sie immer sicher sein, dass Sie die neueste Firmware auf Ihrem AMPLIFi läuft.
**Bevor es los geht, stellen Sie bitte sicher, dass Ihr iOS Gerät eine beständige Internetverbindung hat. Wir empfehlen, dass die Batterie Ihres iOS Gerätes entweder mindestens 50% aufgeladen ist oder Sie hängen es gleich ans Ladegerät damit sich das iOS Gerät nicht während des Updates abschaltet. Außerdem empfehlen wir, dass Sie das Gerät einfach nah bei Ihrem AMPLIFi liegen lassen, um Unterbrechungen des Updates zu vermeiden.**
Klicken Sie hier für ein Video Tutorial wie Sie Ihr AMPLIFi per Bluetooth koppeln können.
Klicken Sie hier für ein Video Tutorial wie Sie die Fimware aktualisieren können.
Schalten Sie Bluetooth auf dem Gerät an von welchem Sie Musik auf Ihr AMPLIFi übertragen wollen.
Drücken und halten Sie nun den Bluetooth Knopf oben auf dem AMPLIFi, dieser sollte dann anfangen zu blinken.
Jetzt sollte Ihr AMPLIFi als Gerät auftauchen.
Wählen Sie nun hier das AMPILIFi aus um die Geräte zu koppeln. Der Bluetooth Knopf auf dem AMPLIFi leuchtet nun durchgehend blau.
Laden Sie sich die AMPLIFi Remote App aus dem Apple App store herunter.
Starten Sie die AMPLIFi Remote App.
Melden Sie sich hier nun mit Ihrem Line 6 Benutzerkonto an. Sollten Sie noch kein Line 6 Benutzerkonto haben dann können Sie sich
hier
einen erstellen oder indem Sie auf den Link drücken in der App.
Sobald die App gestartet ist drücken Sie auf das “¾Menu“ Symbol oben Links in der Ecke.
Tippen Sie dann auf das “¾Settings“ Symbol unten links.
Im “¾Settings“ Menu können Sie dann die “¾Amp Flash“ Funktion finden. Drücken Sie auf diese.
Hier werden Ihnen die für Ihr AMPLIFi verfügbaren Updates angezeigt.
Um die Aktualisierung durchzuführen brauchen Sie nur den “¾Update“ Knopf zu drücken. Warten Sie dann 10-20 Minuten damit die Aktualisierung volsltändig angewandt werden kann.
Sollte die Aktualisierung der Firmware abbrechen oder nicht erfolgreich sein, kann es sein, dass die LEDs Ihres AMPLIFis leuchten oder blinken. In diesem Falle sollten Sie nocheinmal versuchen das AMPLIFi per AMPLIFi Remote App ein Update der Firmware durchzuführen. Zusätzlich sollten Sie sich die Informationen zur Fehlerbehebung der AMPLIFi Bluetooth Verbindung hier durchlesen.
Was soll ich tun wenn das Update unterbrochen wird oder fehlschlägt?
In diesem Fall müssen Sie das AMPLIFi abschalten und wieder neustarten. Drücken Sie dann den Bluetooth Knopf und koppeln Sie das AMPLIFi erneut. Starten Sie das Update im “¾Settings“ Menu dann wieder neu.
Was passiert wenn ich einen Anruf rehalten während der Aktualisierung?
Das ist kein Problem solange Sie in der Nähe des AMPLIFi bleiben. Die Aktualisierung wird nach dem Anruf weiter fortgefürt.
Mise à jour du firmware: AMPLIFi 75 et 150
Nous recommandons toujours que vous avez la version dernière du firmware de votre amplificateur AMPLIFi. Notre application AMPLIFi Remote vous informe chaque fois quâ⬙une mise à jour de firmware est disponible. Comme ça vous savez toujours si vous avez la dernière version. Suivez les instructions ci-dessous pour mettre à jour le firmware de votre AMPLIFi.
** Avant de commencer, assurez-vous que votre appareil iOS a une connexion internet consistante. Nous recommandons une charge de batterie dâ⬙au moins de 50% ou connectez lâ⬙appareil directement au chargeur pour empêcher u arrêt de lâ⬙appareil iOS pendant la mise à jour. Nous recommandons également que vous laissez lâ⬙appareil iOS en proximité immédiate de lâ⬙AMPLIFi pour éviter des interruptions dans le processus de la mise à jour. **
Cliquez ici pour une vidéo sur le couplage Bluetooth avec votre AMPLIFi.
Cliquez ici pour une vidéo sur la mise à jour du firmware de votre AMPLIFi.
Activez le Bluetooth sur votre appareil à partir duquel vous voulez diffuser de la musique.
Mettez lâ⬙AMPLIFi en mode 'Pairing' en appuyant sur le bouton Bluetooth sur le dessus de lâ⬙AMPLIFi. Le bouton commence de clignoter que veut dire que lâ⬙AMPLIFi est en mode de couplage.
Dans les options de Bluetooth de votre appareil, une entrée ë AMPLIFi û sâ⬙affichera.
Sélectez lâ⬙entrée ë AMPLIFi û et couplez les appareils. Le LED sâ⬙arrête de clignoter et sâ⬙allume continué.
Téléchargez lâ⬙application AMPLIFi Remote directement de lâ⬙App Store dâ⬙ Apple.
Lancez lâ⬙application AMPLIFi Remote.
Connectez-vous à votre compte Line 6. Si vous nâ⬙avez pas un compte Line 6, vous pouvez créer un
ici
ou vous pouvez cliquer sur le lien dans lâ⬙application.
Dès que lâ⬙application est lancée, tapez lâ⬙icône ë Menu û dans le coin supérieur gauche.
Tapez lâ⬙icône ë Settings û en bas à gauche du menu.
Dans le menu ë Settings û tapez lâ⬙option ë Amp Flash û.
Ici vous pouvez voir tous les mises à jour pour votre AMPLIFi.
Pour lancer la mise à jour, tapez le bouton ë Update û et laissez le faire la mise à jour pour environ 10 à 20 minutes.
Ci la mise à jour du firmware interrompue ou échoue, les boutons de lâ⬙AMPLIFi peuvent clignoter. Dans ce cas, essayez la mise à jour à nouveau. Consultez les informations de dépannage de la connexion Bluetooth AMPLIFi ici.
Quâ⬙est-ce que je peux faire si la mise à jour interrompue ou échoue?
Si la mise à jour interrompue ou échoue, désactivez lâ⬙AMPLIFi et rallumez le. Poussez le bouton Bluetooth une fois et couplez lâ⬙AMPLIFi avec lâ⬙appareil iOS à nouveau. Redémarrez la mise à jour dans le menu ë Settings û de lâ⬙application AMPLIFi Remote.
Quâ⬙est-ce qui ce passe si je reçois un appel tandis que lâ⬙AMPLIFi est mettre à jour le firmware ?
Si vous recevez un appel, restez dans la gamme du Bluetooth de lâ⬙amplificateur. Lorsque vous terminez lâ⬙appel, la mise à jour se résume.
