Apple has recently pivoted away from using Intel-based CPUs with its computers, instead favoring the Apple Silicon processor, also known as the M1 Chip. Both Intel and Apple Silicon systems run on macOS 11.0 Big Sur.
As it stands, some Line 6 products are not fully supported on computers using Apple Silicon processors, so we cannot offer technical support for those products installed on M1 systems at this time.
We highly encourage you to check with the manufacturers' websites of your music system’s hardware and software for M1 compatibility.
Workaround on M1 Systems
NOTE: Any workarounds offered are not official solutions. Issues experienced with workarounds offered cannot be addressed until official support is offered.
Starting with Big Sur macOS 11, Apple introduced Rosetta v2, which allows applications to run in an emulated mode. Rosetta runs automatically with our software that is NOT a plugin. To use Rosetta with our plugins, locate your DAW in the Applications folder. Use command â+I and check the “Open in Rosetta” box. You may have to rescan your plugins afterwards.
Testing
Applications and plugins tested (latest versions) on M1 systems running macOS 11.0 Big Sur:
Helix Native: working as expected on DAWs running under Rosetta
Echo Farm 3.0: working as expected on DAWs running under Rosetta
Amp Farm 4.0: working as expected on DAWs running under Rosetta
POD Farm 2 (Plugin): working on DAWs running under Rosetta, but takes a few seconds to appear after adding an instance of the plugin
POD Farm 2 (Standalone): working as expected
Ampeg SVT Suite: working as expected on DAWs running under Rosetta
HX Edit: working as expected
POD Go Edit: working as expected
Powercab Edit: working as expected
POD HD500 Edit: App launched properly, device was unable to connect
POD HD500X Edit: App launched properly, device was unable to connect
POD Pro X Edit: App launched properly, device was unable to connect
Spider Valve Mk II Edit: working as expected
Spider V Remote: working as expected
Spider IV Remote: working as expected
Workbench HD: working as expected
Line 6 FBV Control: working as expected
Line 6 Updater: working as expected
Line 6 License Manager: installs as expected, yet devices do not populate in Line 6 License Manager. There is currently an open bug for this issue.
Tested and available:
M1-compatible Hardware Audio Drivers for:
Helix
Helix LT
Helix Rack
HX Stomp
HX Stomp XL
POD Go
POD Go Wireless
POD HD
POD HD Pro
POD HD Pro X
POD HD500
POD HD500X
Hardware Audio Drivers for most TonePort/POD Studio products (see below for exceptions)
Will not be updated to support Silicon-based systems:
StageScape: Audio Driver
POD X3: Audio Drivers, Editors, Updaters, Control Panel app and License Manager
POD XT: Audio Drivers, Editors, Updaters, Control Panel app and License Manager
TonePort UX8: Audio Drivers, Updaters, Control Panel app and License Manager
TonePort/POD Studio KB37: Audio Drivers, Updaters, Control Panel app and License Manager
POD HD300/400
Line 6 Monkey
