Mission Expression Pedals FAQ
Mission EP1-L6 Expression Pedal For Line 6 Products
Part number: 99-040-3505
The Mission EP1-L6 connects to the Line 6 device with a single TS cable. TRS cables are not required for Line 6 expression pedals.
Pedal Dimensions: 10″ x 4″ x 3″
Weight: 3.2lb
Potentiometer: 10K Ohm Linear
Compatible Line 6 devices
  • DL4 Delay MkII
  • Helix
  • Helix Rack
  • Helix LT
  • Helix Control
  • HX Stomp
  • HX Stomp XL
  • HX Effects
  • Firehawk FX
  • Pod Studio KB37
  • Toneport UX8
  • M13
  • M9
  • M5
  • DL4 Delay
  • FM4 Filter
  • DM4 Distortion
  • MM4 Modulation
  • FBV Shortboard MkII
  • Mobile Keys
  • Pod HD 500
  • Pod HD 500X
  • Pod HD 400
  • Pod X3 Live
  • Pod XT Live
Mission SP1-L6H Expression Pedal With Switch For Helix
Part number: 99-040-3605
The Mission SP1-L6H connects to the Line 6 Helix Rack or Rack controller with a single TS cable for expression, and a single TS cable for the toe switch. TRS cables are not required for Line 6 expression pedals. The toe switch function is only supported on the Helix Rack and Rack controller. Other Line 6 devices do not have a toe switch input. The switch output may be left unconnected if this function is not required. The Mission EP1-L6 is recommended for other Line 6 products where a toe switch input is not available.
Pedal dimensions: 10″ x 4″ x 3″
Weight: 3.2lb
Switch: TS Momentary
Compatible Line 6 Devices:
  • Helix Floor
  • Helix LT
  • Helix Rack
  • Helix Rack Controller
  • HX Stomp
  • HX Stomp XL
  • DL4 MK2
Q: Do I need to reprogram my changes with the Mission Expression Pedal every time I plug the pedal in?
A: You do not need to restart your effect unit every time you want to reset the expression pedal. Your expression pedal settings will remain the way you set them up regardless of effect knob settings. Your expression pedal settings can be saved to the effects parameters saved by the footswitches.
Q: Can I use the Mission Expression Pedal to control the volume, wah, or tweak function on my Line 6 product?
A: Yes. Simply plug the Mission Expression Pedal into either the "PEDAL 1" jack or the "EXPRESSION PEDAL" jack on the back of the device.
Q: How do I use the Mission Expression Pedal with a POD unit when connected to the unit or an FBV shortboard?
A: Press the "Edit" button, then turn the "Select" knob until you see the "Wah/Volume" page. On the Volume side, select or highlight "Assign" with the third soft button located under the main display. Turn the "Effect Tweak" knob to change from Volume to Tweak. In the PODxt, these parameters are changed on the page after the "Wah/Volume" page. By changing from "Volume" to "Tweak", you have engaged the Mission pedal to control any function that comes under "Tweak". To find out what's under the "Tweak" selection, turn the "Select" knob to the next page where you will see "FX Tweak | Tempo". On the FX tweak side, you may scroll through the stomp tweaks, delay tweaks, mod tweaks etc. Make sure if you select, say, the delay time, the delay button light must be on and so on with the other effects types.
Q: How do I use a Mission Expression Pedal with a Stomp Box Modeling Pedal?
A: See the following document for information on how to use the Mission Expression Pedal with your Four button modeling pedal:
Expression Pedal & Stompbox Modeler Pedal FAQ
