What instruments and pickups can I plug into my Relay transmitter?
Relay digital wireless systems basically just replace your instrument cable so basically you can plug anything into the transmitter that you could have plugged into your amp (as long as you don't exceed an input level of 6V p-p at the input).
Examples:
Instrument with piezo pickup - If you are currently happy with the sound you get from plugging from your instrument into your amp, then your rig will work just fine substituting Relay for your cable. The input of the Relay transmitter has a very high input impedance (1.3 Mohm) so as not to load down your instrument. This is equal to or even higher than most preamps specifically intended for piezo pickups.
Stereo pickups with Y-Cord - Could also be standard pickups combined with a bridge saddle pickup. Again, if you are happy with the sound you get using this configuration then Relay will not get in the way of your sound. Or you could run each pickup to it's own individual Relay system which could then be split into stereo.
Active instruments w/ preamps - If your instrument has an active preamp and is powered with a single 9v battery you will have no problems using Relay. If you have a double 9v preamp it is theoritically possible to clip the input of the transmitter but unlikely in the real world. Should this actually happen you can remedy it by backing off a bit on the master volume control, adding a pad to the cable or removing one of the batteries. The extra headroom offered by these systems is only a benefit if it fits in with the system gain structure (unless you are using it to purposly clip the input of your amp). Remember, unused headroom is wasted.
Where should I plug Relay into my chain?
Relay replaces the cable from your instrument to wherever the other end of that cable was plugged into. Plug your instrument into the transmitter and plug the output from the receiver into wherever that cable was before. Generally speaking, you are un-tethering yourself from the first piece in your chain. You don't have to worry about gain or level matching as Relay is a "unity" device. That means you get the same level (voltage) at the output jack of the receiver as you are getting from the output of your instrument. Nothing changes ... Relay's output level is neither louder nor softer than the original.
The output from the "tuner" out is exactly the same as the main output in level and impedance. Only difference is the pressing the "mute" button on a G50/90 transmitter shuts off the main out but leaves the tuner output active. The XLR and 1/4" outputs on the G90 are also identical and are provided to give the user more versitility in connecting to other gear.
What IS different?
Depending on how you've set the cable modeling, you could be sending a lot more "highs" into your system than ever before. This could result in more apparent noise or hiss. It would be the same as if you had connected your instrument into your system with a 1-foot cable (which is pretty difficult to do unless you are a contortionist guitarist!). Adjusting to the proper cable model should remedy this situation. On the other hand, if you are using an acoustic guitar leaving the model off will sound like the freshest set of strings you've ever played.
Relay: Digital Wireless: Was schließe ich an und wie?
Welche Instrumente und Pickups kann ich an den Relay Transmitter anschließen?
Relay Digital Wireless ersetzt einfach nur das Instrumentkabel, Sie können also fast alles in Ihren Transmitter stecken, was Sie auch in Ihren Verstärker gestöpselt hätten. (Solange Sie die Eingangsspannung von 6V pp nicht überschreiten.)
Beispiele:
Instrumente mit Piezo Pickup: Wenn Sie zur Zeit schon froh sind mit dem Soun den Sie bekommen, wenn Sie Ihr Instrument normal in den Verstärker stecken, dann wird das auch mit Relay als Kabelersatz genau so gut funktionieren. Der Eingang des Relay Transmitters hat eine extrem hohe Impedanz (1,3 Mohm), damit Ihr Instrument nicht belastet wird. Diese Impedanz ist gleich oder höher der meisten Vorverstärker speziell für Piezo Pickups.
Stereo Pickups mit Y-Kabel: (oder standart Pickups kombiniert mit "bridge saddle" Pickup). Wenn Sie zur Zeit schon froh sind mit dem Soun den Sie bekommen, wenn Sie Ihr Instrument normal in den Verstärker stecken, dann wird das auch mit Relay als Kabelersatz genau so gut funktionieren. Sie könnten aber auch die einzelnen Pickups separat an verschiedene Relay Systeme anschließen um das Stereosignal aufzuspalten.
Aktive Instrumente mit Vorverstärkern: Wenn Ihr Instrument einen aktiven Vorverstärker hat und durch eine einzelne 9V Batterie angetrieben wird, werden Sie keinerlei Probleme mit Relay haben. Wen nSie aber einen Vorverstärker mit doppelter 9V Batterie haben, ist es theoretisch möglich den Eingang des Transmitters zu übersteuern. Sollte dies passieren können Sie das Problem lösen indem Sie das Master Volume ein wenig herunterdrehen, dem Ausgang ein Padding geben oder eine der Batterien entfernen. Die zusätzliche Freiheit bei hohen Frequenzen bei solchen Systemen ist nur dann von Vorteil, wenn es mit dem Gain des Sytems zusammenpasst. (Außer natürlich, Sie verwenden es um absichtlich das Singal zu übersteuern.) Denken Sie daran, dass nicht benutze Freiheit bei hohen Frequenzen verschwendet ist.
Wo soll ich mein Relay in die Kette schalten?
Relay ersetzt einfach nur das Kabel vom Instrument zum Gerät, welches Sie mit dem Instrument verbinden wollen. Stecken Sie das Instrument in den Transmitter und dann den Ausgang des Empfängers worin auch immer das Instrument vorher steckte. Sie müssen sich nicht mehr um Gain- oder Levelabstimmung kümmern, da Relay ein "Unity" Gerät ist. Das bedeutet, dass Sie immer die gleiche Spannung im Ausgang des Empfängers haben, wie Sie aus dem Ausgang des Instrumentes bekommen. Nicht ändert... Der Ausgangspegel ist nicht höher odre tiefer als das Original.
Der Ausgang des "Tuners" hat denselben Ausgangspegel und â⬓impedanz, wie der Main-Ausgang. Der einzige Unterschied ist, dass durch drücken des "Mute" Knopfes auf dem G50/90 Transmitter nur die Main-Ausgänge und nicht der Tunerausgang abgeschaltet wird. Die XLR und 6.35mm Ausgänge des G90 sind identisch und sind vorhanden um dem Benutzer mehr Flexibilität für die Verbindung seiner Ausrüstung zu verleihen.
Was ist anders?
Jenachdem, wie Sie das Kabel-Modeling eingestellt haben kann es sein, dass Sie weit aus mehr "Höhen" in Ihr System senden, als vorher. Dies könnte zu deutlicherem Rauschen und Zischen führen. Das wäre dann dasselbe, als wenn Sie Ihr Instrument mit einem 30cm Kabel an das System angeschlossen hätten. (Was eventuell schwer zu machen ist.) Das Anpassen auf das korrekte Kabelmodell sollte dieses Problem lösen. Andererseits, wenn Sie eine akustische Gitarre benutzen können Sie das Modell abschalten und Wird das ganze sich anhören, wie der frischeste Satz Saiten, den Sie je gespielt haben.
Relay: Signal sans fil digital: Qu'est-ce que je branche et comment?
Quels instruments et micros est-ce que je peux brancher dans le transmetteur Relay?
Les systèmes numériques sans fil Relay simplement remplacent les câbles instruments, donc vous pouvez brancher tous les instruments que vous pouvez brancher dans l'ampli. (Tant que vous ne dépassez pas un niveau d'entrée de 6V pp à l'entrée).
Exemples:
Instruments avec micro piezo: Si vous êtes actuellement satisfait du son que vous obtenez de brancher votre instrument à votre ampli, votre rig fonctionnera très bien avec Relay comme remplacement pour le câble. L'entrée du transmetteur Relay a une impédance très haute 1,3 (MOhm) pour ne pas surcharger votre instrument. C'est égal ou même supérieur à la plupart des préamplis spécifiquement destinés aux micros piezo.
Micros stéréo avec câble Y: (ou micros standard combiné avec un micro bridge saddle). Vous êtes actuellement satisfait du son que vous obtenez de brancher votre instrument à votre ampli, votre rig fonctionnera très bien avec Relay comme remplacement pour le câble. Ou, vous pouvez connecter chanque micro avec un système Relay individuel pour le diviser en stéréo.
Instruments actives avec préamplis: Si votre instrument a un préampli actif et est allumé avec une seule batterie 9V, vous n'aurez aucun problème avec Relay. Si vous avez un préampli double 9V, c'est théoriquement possible de brancher l'entrée du transmetteur mais c'est peu probable en réalité. Si cet événement se produit, vous pouvez reculer un peu sur le Master Volume, ajouter un pad sur le câble ou enlever une des deux batteries. La marge supplémentaire offerte par ces systèmes est seulement un avantage si elle s'inscrit dans la structure de gain du système (sauf si vous l'utilisez pour couper intentionnellement l'entrée de votre ampli). Rappelez-vous, marge non utilisée est perdue.
Où est-ce que je dois brancher Relay dans la chaine?
Relay remplace le câble de votre instrument à n'importe quel appareil vous voulez connecter votre instrument. Branchez votre instrument dans le transmetteur et la sortie du récepteur dans n'importe où ce câble était avant. Vous n'avez pas à vous soucier de gain ou de niveau correspondant parce que Relay est un appareil d 'ëunitéû. Ca veut dire que vous recevez le même niveau de tension au jack de sortie que vous recevez de la sortie de l'instrument. Rien ne changeââ¬Â¦ Le niveau de sortie de relais n'est ni plus fort ni plus douce que l'original.
La sortie du "Tuner" est exactement le même que la sortie Main (principale) en niveau et impédance. La seule différence est que pousser le bouton "Mute" sur un G50/G90 éteints la sortie Main mais laisse la sortie du tuner actif. Les orties XLR et 6.35mm sur le G90 sont identiques et sont fournis pour donner plus versatilité à l'utilisateur pour se connecter à autres appareils.
Quelle est la différence?
Selon la façon dont vous avez configuré la modélisation de câbles, vous pourriez envoyer beaucoup plus d'ëhautsû dans votre système que jamais auparavant. Cela pourrait entraîner du bruit ou sifflement plus apparente. Ce serait le même que si vous aviez connecté votre appareil dans votre système avec un câble de 30cm. (ce qui est plutôt difficile à faire) Ajustement au modèle de câble approprié doit remédier à cette situation. D'autre part, si vous utilisez une guitare acoustique laissant le modèle off retentit comme l'ensemble le plus nouveau de cordes que vous n'avez jamais joué.
