Flextone III/HD147 Tone Transfers
Flextone III and HD 147 MIDI Sysex (Memory Dumps)
There are 3 special hidden functions on the Flextone III that will transmit a Sysex message that can be recorded by a MIDI application, or sent to another Flextone III amplifier.
1. Presets & Amp Setups - To transmit all of your custom presets and Amp Defaults: press and hold theTap Tempo, Comp & Mod Select buttons while powering up the amp. Connect the MIDI out of the source amp to the MIDI In of your computer or another amp. (If you are connecting to another HD 147, you can power up the target amp normally.) Press the Delay Select button to send the message.
2. The Whole Enchilada - To transmit the entire memory of the amplifier including your custom presets, amp setups, and DSP software, (the brains behind the operation): press and hold the Tap Tempo, Gate & Mod Select buttons while powering up the amp. Connect the MIDI out of the source amp to the MIDI In of your computer or another amp. (If you are connecting to another HD 147, you can power up the target amp normally.) Press the Mod Select button to send the message.
3. The Edit Buffer - To transmit the current state of the amp, press and hold theTap Tempo and any of the A, B, C or D buttons.
