æ¥æ¬èªã¯ä¸è¨ãã覧ãã ãã ã
How to Activate Helix Native
Download the latest version of Helix Native at
https://line6.com/software/
Run the Helix Native installer. We suggest you temporarily disable all third party antivirus programs during the installation. During the install, take note of the VST3 and AAX Plugin folder locations. If you choose to install the PC VST2 plugin, you will be able to choose your own folder location. On Mac, VST2 is installed at /Library/Audio/Plug-Ins/VST/.
PC VST2 only: Open your recording program's preferences and point it to the folder that Helix Native was installed to.
Start your DAW, create an audio track, then add Helix Native as a plugin (see below for links to your particular DAW).
On first run, you will be prompted to sign in to your Line 6 account to authorize your license.
Individual DAW Set-up Articles
Q: I can't find the Helix plug-in, even after following the steps in the articles above.
A. Possible causes:
The default VST3 folder on Windows is C:\Program Files\Common Files\VST3\. Ensure your DAW has scanned that directory.
Helix Native is a VST Effect. When searching your DAW's plug-ins list, make sure to look under VST Effects and not VST Instruments.
Helix Native is 64-bit only, and therefore won't appear in a 32-bit DAW.
Q: What are the default locations for Helix Native plug-in files?
This version of Helix Native plug-in installs on a Mac to:
AU Plug-in
/Library/Audio/Plug-Ins/Components/Helix Native.component
VST2 Plug-in
/Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst
VST3 Plug-in
/Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3
AAX Plug-in
/Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin
This version of Helix Native plug-in installs on Windows to:
VST3 Plug-in
C:\Program Files\Common Files\VST3\Line 6\Helix Native (x64).vst3
AAX plugin:
C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Line 6\Helix Native.aaxplugin
n
NOTE: The VST2 plugin installation location, if installed, will be determined by the user during the installation process.
Helix Nativeãã¢ã¯ãã£ãã¼ãããæ¹æ³
Helix Nativeã®ææ°ãã¼ã¸ã§ã³ã https://jp.line6.com/software/. ãããã¦ã³ãã¼ããã¾ãã
Helix Nativeã¤ã³ã¹ãã¼ã©ãèµ·åãã¾ããã¤ã³ã¹ãã¼ã«ä¸ã¯ãã¹ã¦ã®ãµã¼ããã¼ãã£ã¼è£½ã¢ã³ãã¦ã£ã«ã¹ã½ããã䏿çã«ç¡å¹ã«ãã¦ãããã¨ãæ¨å¥¨ãã¾ããã¤ã³ã¹ãã¼ã«ä¸ã«ãVST3ããã³AAXãã©ã°ã¤ã³ã»ãã©ã«ãã®å ´æãæ§ãã¦ããã¾ããããWindows PCã§VST2ãã©ã°ã¤ã³ãã¤ã³ã¹ãã¼ã«ãããã¨ã鏿ããå ´åã¯ããã©ã«ãã®å ´æãèªèº«ã§é¸æãããã¨ãã§ãã¾ããMacã§ã¯ãVST2ã¯ã/Library/Audio/Plug-Ins/VST/ãã«ã¤ã³ã¹ãã¼ã«ããã¾ãã
PC VST2ã®ã¿: ã¬ã³ã¼ãã£ã³ã°ã»ããã°ã©ã ã®ããªãã¡ã¬ã³ã¹ãéããHelix Nativeãã¤ã³ã¹ãã¼ã«ããããã©ã«ããæå®ãã¾ãã
DAWãèµ·åãããªã¼ãã£ãªã»ãã©ãã¯ã使ãã¦ãããHelix Nativeããã©ã°ã¤ã³ã¨ãã¦è¿½å ãã¾ãã (DAWå¥ã«ã¯ä»¥ä¸ã®ãªã³ã¯ããåç §ãã ãããè±æ).
æåã«èµ·åããéã«ãã©ã¤ã»ã³ã¹ããªã¼ã½ã©ã¤ãºãããããLine 6ã¢ã«ã¦ã³ãã¸ã®ãã°ã¤ã³ãæ±ãããã¾ãã
DAWå¥è¨å® ï¼è±æï¼
Q: ä¸è¨ã®æé ã«å¾ã£ã¦ããHelix Nativeãã©ã°ã¤ã³ãè¦ã¤ããããªãã®ã§ããã
A. 以ä¸ã®åå ãèãããã¾ã:
Windowsä¸ã®ããã©ã«ãã®VST3ãã©ã«ãã¯ãC:\Program Files\Common Files\VST3\ã«ããã¾ããDAWããã®ãã£ã¬ã¯ããªãã¹ãã£ã³ãã¦ããã確èªãã¦ãã ããã
Helix Nativeã¯VSTã¨ãã§ã¯ãã§ããDAWã®ãã©ã°ã¤ã³ã»ãªã¹ããæ¢ãéã¯ãVST Instrumentsã§ã¯ãªãVST Effectsãis a VST Effectã確èªãã¦ãã ããã
Helix Nativeã¯64-bitã®ã¿ãªã®ã§ã32-bit DAWã«ã¯è¡¨ç¤ºããã¾ããã
Q: Helix Native ãã©ã°ã¤ã³ã»ãã¡ã¤ã«ã®ããã©ã«ãã®å ´æã¯ã©ãã«ããã¾ãã?
ãã®ãã¼ã¸ã§ã³ã®Helix Nativeãã©ã°ã¤ã³ã¯ãMacã®ä»¥ä¸ã®å ´æã«ã¤ã³ã¹ãã¼ã«ããã¾ã:
AU Plug-in : /Library/Audio/Plug-Ins/Components/Helix Native.component
VST2 Plug-in : /Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst
VST3 Plug-in : /Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3
AAX Plug-in : /Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin
ãã®ãã¼ã¸ã§ã³ã®Helix Nativeãã©ã°ã¤ã³ã¯ãWindowsã®ä»¥ä¸ã®å ´æã«ã¤ã³ã¹ãã¼ã«ããã¾ã::
VST3 Plug-inã: C:\Program Files\Common Files\VST3\Line 6\Helix Native (x64).vst3
AAX plugin: C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Line 6\Helix Native.aaxplugin
NOTE: ããVST2ãã©ã°ã¤ã³ãã¤ã³ã¹ãã¼ã«ããå ´åã¯ãã¤ã³ã¹ãã¼ã«ã®éä¸ã§ã¦ã¼ã¶ã¼ãæå®ããå ´æã«ãªãã¾ãã
