HELIX Native troubleshooting
The two common usage issues seen with Helix Native are:
  • After a full Helix Native license is authorized, Helix Native is in Trial Mode when opened within a DAW
  • Helix Native is crashing when attempting to open on an audio track within a DAW
  • A blank screen after logging into your Line 6 account when opening Helix Native
What has helped many users in these situations is the following:
  • Disable WiFi
  • Launch your DAW
  • Insert Helix Native on a track. The login page should pop up.
  • Turn on WiFi.
  • When you sign in, Native gets reauthorized.
Another potential resolution: ad blockers, firewalls, network monitors, etc. need to recognize line6.com and line6.net as legitimate domains. Adjust or disable such software accordingly.
CPU Usage:
Another common issue that may be noticed on some systems is Helix Native's CPU usage reading higher percentage than what would be expected. Helix Native is a CPU intensive plug-in, some of our systems show readings between 27-30%, the actual usage meter will vary from system to system.
Increasing the H/W playback buffer size in your DAWs settings can reduce CPU usage to a degree.
