James Tyler Variax Variax/Standard/Shuriken Accessories
Version française.
Deutsche Version.
Every James Tyler Variax guitar includes the following accessories:
  • One Workbench interface
  • One USB cable
  • One Category 5 Variax Digital Interface cable
  • One Allen wrench tool set
  • One battery (*US made JTV guitars are shipped with 2 batteries)
  • One battery charger
  • One battery charger power supply w/ international adapters
Allen wrench sizes:
(for JTV 89)
1 -“ 4mm hex, for truss rod adjust (relief)
1 -“ 5/64" hex, for individual piezo level intonation adjust (intonation)
1 -“ 7/64" hex, for bridge post adjust (action)
1 -“ 3/32" hex, common generic tool in most guitar tool kits
1 -“ 5/32" hex, common generic tool in most guitar tool kits
1 -“ 0.050", for bridge set screw horizontal overall Bridge intonation adjust (intonation)
1 - 1.5mm, for tremolo set screw [even though the 89 is a set bridge]
3/32 and 5/32 are common generic tool in most guitar tool kits that use linear, rather than metric parts.
(for JTV 89F)
1 - 4mm hex, for truss rod adjust JTV-89F (relief)
1 - 5/64" hex, for individual piezo level intonation adjust (intonation)
1 - 7/64" hex, for Locking nut and bridge string locks
1 - 3/32" hex, common generic tool in most guitar tool kits
(for JTV 59 and 69)
1 - 1.5mm hex, for tremolo set screw adjust on the JTV-69 series
1 - 4mm hex, for truss rod adjust JTV-69 (relief)
1 - 4mm hex short arm, for truss rod adjust JTV-59 (relief)
1 - 7/64" hex, for bridge post adjust (action)
1 - 0.050" hex, for bridge set screw horizontal overall Bridge intonation adjust (intonation)
3/32 is a common generic tool in most guitar tool kits that use linear, rather than metric parts.
(for the Variax Standard)
1 - 4mm hex, for truss rod adjust (relief)
1- 1.5mm or 1.25mm hex (for earlier units), piezo saddle height adjust (action)
(for the Shuriken)
1- 0.050 inch hex, piezo saddle height adjust (action)
If any of these items are missing from your new JTV purchase, feel free to submit a support ticket at line6.com/support. We will route your request to our Parts department for fulfillment.
Les éléments suivants sont inclus avec tous les guitares James Tyler Variax :
  • L’interface Workbench.
  • Un câble USB.
  • Un câble Cat 5 Variax Digital Interface.
  • Un ensemble d’utiles Allen.
  • Une batterie (les guitares de la série US ont 2 batteries).
  • Un chargeur de batterie.
  • Une alimentation pour le chargeur de batterie. Avec des adaptateurs internationales.
Toutes les clés Allen :
  • 1x 1,5mm
  • 1x 4mm
  • 1x 2mm
  • 1x 2,8mm
  • 1x 2,4mm
  • 1x 1,3mm
Si un de ces éléments manque, n'hésitez pas à soumettre un ticket de support sous : www.fr.line6.com/support
Alle James Tyler Variax Gitarren beinhalten folgendes Zubehör:
  • Die Workbench Interface.
  • Ein USB Kabel.
  • Ein Cat5 Varaix Digital Interface Kabel.
  • Ein Set Inbusschlüssel.
  • Eine Batterie (im Falle der US Serie sind 2 Batterien enthalten)
  • Ein Batterieladegerät.
  • Ein Netzteil für das Batterieladegerät.
Inbusschlüsselgrößen:
  • 1x 1,5mm
  • 1x 4mm
  • 1x 2mm
  • 1x 2,8mm
  • 1x 2,4mm
  • 1x 1,3mm
Sollte eines dieser Teile fehlen können Sie jederzeit ein Supportticket auf www.de.line6.com/support erstellen.
