DT25/DT50 FIRMWARE INSTALLATION INSTRUCTIONS
NEEDED:
A MIDI interface that connects to your computer via USB (download the current Driver for it if you don't have it installed)
2 MIDI cables (or a MIDI interface such as the M-Audio Uno that comes with attached MIDI cables, note: this interface must have its own set of Midi drivers)
NOTE: Line 6 recommends a name brand USB to MIDI interface produced by an audio company that supports/updates their drivers. Good choices include: M-Audio, Edirol, E-Mu and MOTU. These interfaces have proven to be more robust and reliable when it comes to large MIDI transfers such as the DT25 and DT50 update.
Latest version of Line 6 Monkey installed. Download and install the Line 6 Monkey software
here.
Procedure
Connect your MIDI interface to your computer via USB cable.
Connect the DT25/DT50 MIDI Out to your MIDI interface In, and connect the DT25/DT50 MIDI In to your MIDI interface Out.
NOTE: when using the M-Audio UNO, the cable labeled "To Midi In" connects to the port labeled "Midi In" on your device. The same goes for the Midi Out cable and port.
Launch the Line 6 Monkey with the DT25/DT50 connected via the MIDI interface and powered on.
Select the Flash Memory line item and click the Update Selection button to install the flash memory update into the DT25/DT50.
The device will receive the firmware data and the unit will be updated to the latest Firmware.
***If the firmware update fails and you are having trouble reconnecting to Line 6 Monkey, please try putting the unit into SAFE MODE before starting up and connecting to the Line 6 Monkey software. To do this, hold the channel select switch down to 'Channel B' and power on the DT amplifier while holding this switch down. Let go of the switch after 10 seconds or so, then re-start Line 6 Monkey and follow the steps above to update/re-install the flash memory.
Instructions d’installation du firmware DT 25 et DT 50
Vous avez besoin de :
Une interface MIDI qui connecte à votre PC via USB (téléchargez le pilote le plus récent pour cette interface)
2 câbles MIDI (ou une interface MIDI comme le M-Audio Uno avec des câbles attachés.)
Attention une interface USB à MIDI de marque d’un fabriquant audio connu comme M-Audio, Edirol, E-Mu ou MOTU est recommandé. Ces interfaces sont plus robustes et fiables pour les transfers larges comme des mises à jour.
Installez la version la plus récente de Line 6 Monkey. Téléchargez le ici :
https://fr.line6.com/software/
Procédure :
Connectez votre interface MIDI à votre câble USB.
Connectez la sortie MIDI du D25/D50 à l’entrée de votre interface MIDI et connectez l’entrée MIDI du DT25/DT50 à la sortie MIDI de l’interface MIDI.
Lancez Line 6 Monkey avec le DT25/DT50 connecté et allumez le.
Cliquez Flash Memory et Update Selection pour installer la mise à jour sur le DT25/DT50.
La mise à jour est maintenant effectuée.
Si vous avez des problèmes avec la mise à jour ou avec la reconnexion de l’appareil au Line 6 Monkey, essayez le SAFE MODE avant vous l’allumez et connectez au logiciel Line 6 Monkey. Maintenez Channel Select sur la position Channel B et allumez l’ampli DT en maintenant ce commutateur. Lâchez le commutateur après 10 secondes et redémarrez Line 6 Monkey.
Essayez de faire la mise à jour encore une fois.
Anleitung zur DT25/DT50 Firmware Installation:
Benötigt:
Eine MIDI Schnittstelle, welche Sie an Ihren PC anschließen können. (laden Sie sich bitte den neusten Treiber für das Gerät herunter.
Achtung, Line 6 empfiehlt eine MIDI Schnittstelle eines Marken-Audio Herstellers, da diese regelmäßig Treiberupdates bekommen. Marken wie M-Audio Uno, Edirol, E-Mu und MOTU. Diese Schnittstellen haben erwiesen, dass sie robuster und zuverlässig sind bei großen MIDI Dantentransferen wie die DT25 un DT50 Aktualisierungen.
Die neueste Version der Line 6 Workbench. Herunterladen können Sie Monkey hier.
Verfahren:
Verbinden Sie die MIDI Schnittstelle über USB mit Ihrem Computer.
Verbinden Sie den MIDI Ausgang des DT25 oder DT50 mit dem Eingang der MIDI Schnittstelle und den MIDI Ausgang der Schnittstelle mit dem Eingang des DT25/DT50.
Starten Sie Line 6 Monkey während das DT25/DR50 vie MIDI an Ihren Computer angeschlossen ist.
Wählen Sie Flash Memory dann Update Selection um das Update zu installieren.
Das Gerät wird nun die erforderlichen Informationen laden und sich selbst aktualisieren.
Achtung, sollte die Aktualisierung fehlschlagen und Sie müssen Line 6 Monkey wieder neu verbinden, dann solten Sie versuchen das DT25/DT50 im Safe Mode zu starten. Bevor Sie es nun wieder starten, halten Sie den Channel Select und starten Sie Line 6 Monkey. Starten Sie das Gerät neu während der Knopf in Richtung Channel B gedrückt ist Lassen Sie dann den Knopf nach ca. 10 Sekunden wieder los und starten Sie Line 6 Monkey.
Folgen Sie dann nocheinmal die Anleitung zur Firmware-Installation
