Zur deutschen Version.
La version française.
Please read through the DT50/DT25 Terminology FAQ first, to familiarize yourself with the terms that will be referenced here.
Application
Q: Are there any presets on the DT50/DT25 amplifier in the manner of previous Line 6 amps?
A: No. The DT50/DT25 behaves like a traditional amp where the user simply dials in a tone to the WYSIWYG (what you see is what you get) functionality.
Q: Are the DT50/DT25 amplifiers Mono(phonic)?
A: As with most tube amplifiers, yes.
Q: Which type of amp modeling is using with the DT50/DT25?
A: Line 6's newest HD amp models (same as our new POD HD).
Q: How does the power amp tubes contribute to the DT50/DT25's sound?
A: The EL34's (DT50) or EL84's (DT25) are the main source of distortion in the amp. The guitar signal is actually being amplified at every progressive stage in the circuit, but the power tubes are the first to truly "clip" and provide the distortion that most tube amp devotees desire.
Q: How does the modeling of the DT50/DT25 contribute to the overall tone?
A: In the DT50/DT25's "normal mode", the modeling performs the function of the preamp: mating the digital preamp with the analog power amp so the whole system creates the sound of the amp modeled. This is different than our previous Spider Valve amps, where we modelled the entire amp model (pre-amp and power amp) and then fed that signal through the output tube power section.
In "low power mode" (pulling the master volume switch out on the DT50 or on the DT25 flipping the switch on the back panel), the digital modeling section will assume duties for the power amp section and the Master Volume has been scaled so that you can have the sound of a driven power amp at lower monitoring volume levels. If you turn the master volume knob all the way up in this mode, you will have Spider Valve-like tones behavior (where the pre and power amp software modeling signal is pushing the EL34 or EL84 tubes).
In both Normal and Low Power modes, cabinet modeling is applied to the output signal fed to the power tubes. When using a POD HD device connected via L6 Link, you must use the default cabinet model that is recalled on the POD HD 'pre' amp model when using the L6 Link connection with the DT amp to get the same type of sound as using the DT amplifier by itself with the same amp model.
Lastly, when using Low Volume Mode on the DT amp with a POD HD connected via L6 Link, the sound of a 'Pre' amp model selected on the POD preset will sound slightly different if an identical amp model is selected on the DT amplifier (on Channel B ). This is because when using the Low Volume Mode on the DT amp with L6 Link, Channel A on the DT amp with the POD modeling is still using the just the PRE amp model with the scaled Master Volume knob, whereas Channel B on the DT amp uses the preamp AND power amp modeling with the scaled Master Volume. The inclusion of the power modeling is what makes it sound differently.
Q: What is the difference between the DT25 and the DT50 amplifier?
A: The DT25 operates at 25 watts maximum output using two (2) EL84 power tubes vs. the EL34's found in our DT50's. Otherwise, it is essentially the same as its big-brother, the DT50. For more info, please check the new product page for the DT25 here.
DT50/DT25 Voicings Switch
I Negative Feedback Loop (NFL) setting is high; channel control behavior much like that of a West Coast American amp of the 1960s.
Recommended settings: Class AB & Pentode.
II NFL is medium; channel control behavior much like that of a classic British amp of the 1960s known for it's "glassy" yet warm tones.
III Zero Negative Feedback Loop operation (a very open/dynamic feeling amp); channel control behavior much like that of a 'chime-like tone' British amp of the 1960s.
Recommended settings: Class A & Pentode (clean) or switch to Triode (for rounder, more vintage feel).
IV NFL is low in value, with an added low frequency resonance ideally suited for modern high-gain voicing; channel control behavior much like that of a more recent West Coast American amp of the 1990s.
Class A & Class AB Switch
Class A: Cathode biased. Provides the player with more dynamic with touch sensitivity. DT50 operates at 25 watts. DT25 operates at 10 watts.
Class AB: Fixed biased. Provides greater headroom and power than Class A. DT50 operates at 50 watts. DT25 operates at 25 watts.
Pentode & Triode Switch
Pentode: Clearer tone and more headroom.
Triode: Rounder tone, less output and more vintage feel.
L6 Link
L6 LINK is a proprietary Digital Audio connection developed for exclusive connection between the POD HD series modeling processors and the DT50/DT25 amplifier(s). Do NOT connect any other sort of analog audio device that appears to have a standard 3-pin (XLR) connector to the L6 LINK, as damage will occur.
Connect a digital XLR cable (AES/EBU cable) from the POD HD L6 LINK jack directly to the DT amp's L6 LINK IN jack. Most XLR cables should provide sufficient performance, but use a digital XLR (AES/EBU) cable for best performance and signal to noise ratio.
When linking two DT amps, all controls including master volume work independently on both amps. The only thing that syncs is the channel switch, i.e. switching the channel on amp A switches it on amp B as well.
Specifications
DT50 Specifications
DT25 Specifications
Q: Is there a chart for the amp models of the DT series amps and the POD HD series?
A: Yes, there is a .pdf document with this information here.
*Please note, most of the amp models on the DT series are only accessible via MIDI. Please reference the following document for information on accessing these models:
Using MIDI to Change Amp Settings on the DT50/DT25 Amplifiers
Q: What speakers are used the DT50/DT25 amps?
A: DT50/DT25 112 Combo has the Celestion custom G12H90 12" speaker. DT50 212 Combo has a Celestion custom G12H90 12" and a Celestion Vintage 30 12" speaker.
Q: What tubes ship in the DT50/DT25 amps?
A:
DT50: Electro-Harmonix 12AX7 preamps tubes (2) and Electro-Harmonix EL34 power tubes (2).
DT25: Chinese-branded 12AX7 preamp tube (1) and Electro-Harmonix EL84 power tubes (2).
Q: What is the Bias Spec on the DT50's EL34 power tubes?
A: 36 mV +/- 1 mV.
Q: What is the Bias Spec on the DT25's EL84 power tubes?
A: 22 mV +/- 3 mV.
Q: What Line 6 controllers work with the DT50/DT25?
A: Any of the POD HD series units. They utilize the new proprietary L6 Link (3-pin) digital connection to control amp topology settings in Channel A to whatever parameters are set in the active POD HD patch.
There is a jack labelled for "Footswitch" on the back of the amp to allow for switching between Channel A and B. Please use a "tip-sleeve" (mono 1/4") latching-type footswitch to use this feature.
Setup/Connection
Q: Is there a headphone output on the DT50/DT25 series?
A: No.
Q: Is there a bias switch to change the power tubes to 6L6's or other tube types?
A: No, the DT50/DT25 series do not offer bias-switchable options and were designed to operate with the EL34 (DT50) or EL84 (DT25) power output tubes.
Q: Can I run my DT50/DT25 without a speaker load?
A: No! You should always run a tube amplifier with a speaker load present. Please follow the properly load connection requirements as silkscreened on the back of the amplifier chassis.
Q: Will installing casters on a DT50/DT25 112 or 212 combo chassis void my warranty?
A: No, correctly installed casters will not void the warranty. However, if you are not 100% sure on how to correctly install casters, please take your amp to a qualified amp/service technician and have them install the hardware. We do NOT cover damage caused to the amplifier from an incorrect installation!
*** Here is a link to one of our Forum Members (MDinice) who was kind enough to share a template for Ernie Ball type casters: https://line6.com/community/thread/57744?tstart=0 (the template is also available at the bottom of this document). Known-Issues
12AX7 Preamp Tube Swapping: If you decide to swap out different 12AX7 preamp tubes, do NOT use anything labeled 'LP' (Long Plate) for the first preamp tube stage (labeled as V3), as 'LP' labeled tubes are extremely microphonic.
Q: How do I control the v2.0 update features of the DT25/DT50 amplifier using MIDI?
A: We have created a document to help with sending MIDI to your DT amplifier to control the various additional features of the v2.0 update. Please see the following document for these instructions:
Also, here is a link with information on troubleshooting tube amplifiers:
Troubleshooting Your Tube Amp
Bitte lesen Sie sich zuerst DT50/DT25 Terminology FAQ durch um sich mit den Begriffen bekannt zu machen, die im folgenden Dokument Verwendung finden.
Gibt es Presets auf dem DT25/DT50, so wie auf anderen Line 6 Verstärkern?
Nein, die DT25/DT50 Verstärker verhalten sich genau wie traditionelle Verstärker.
Sind die DT25/DT50 Verstärker Mono?
Ja, so wie die meisten Röhrenverstärker.
Welche Art Verstärkermodelierung wird bei den DT25/DT50 angewandt?
Wir verwenden sie neusten Line 6 HD Verstärkermodelle. (wie im POD HD)
Wie tragen die Röhren zum Sound der DT25/DT50 bei?
Die EL34 (DT50) und EL84 (DT25) sind die Hauptquelle für die Verzerrung des Verstärkers. Das Signal wird nach und nach im Verstärker verstärkt, aber die Röhren haben hier den größten Einfluss. Sie liefern den ersehnten Verzerrungston, den die meisten Röhrenverstärker haben.
Wie trägt das Modelling der DT25/DT50 zum Sound bei?
Im ââ¬Å¾Normalââ¬Å Modus übernimmt das Modelling die Funktion des Vorverstärkers. Es führt die digitale Vorverstärkung mit der analogen Endstufe zusammen um den modellierten Sound zu erreichen. Bei unseren alten Spider Verstärkern, im Gegensatz, haben wir den gesamten Verstärker modelliert und dieses Signal durch die Röhren geschickt.
Im ââ¬Å¾Lowââ¬Å Modus übernimmt das digitale Modelling die Arbeit der Endstufe und der Master Volume Knopf ist so skaliert, dass Sie den Ton einer aufgedrehten Endstufe auch bei niedrigen Abhörlautstärken erreichen. Wenn Sie den Master Volume Knopf hinten gegen drehen erhalten Sie einen Sound der ähnlich klingt wie die Spider Valve Verstärker.
In beiden Modi wird das Cab Modelling in den Ausgang gespeist, direkt in die Röhren. Wenn Sie ein POD HD Gerät verwenden, welches via L6 Link verbunden ist, müssen Sie das standard Cab Modell benutzen, welches auf dem POD HD Vorverstärker Modell ist wenn Sie es mit L6 Link an den DT Verstärker anschließen. So erhalten sie den gleichen Ton, den Sie erhalten würden, wenn Sie den DT Verstärker allein mit diesem Modell verwenden würden.
Außerdem wird der Ton im ââ¬Å¾Lowââ¬Å Modus auf dem DT, wenn dieser per L6 Link an einen POD HD angeschlossen ist und Sie ein Vorverstärkermodell auswählen auf dem POD, etwas unterschiedlich klingen als wenn Sie das Modell sofort auf dem DT auf Kanal A auswählen. Das kommt daher, dass wenn Sie den ââ¬Å¾Lowââ¬Å Modus auf dem DT mit L6 Link verwenden der Kanal A auf dem DT mit POD Modelling immer noch nur das Voverstärker Modell mit skaliertem Master Volume verwendet während Kanal B auf dem DT Voverstärker UND Endstufe modelliert.
Was ist der Unterschied zwischen DT25 und DT50?
Der DT25 hat maximal 25 Watt mit seinen zwei EL84 im Gegensatz zu den EL34 im DT50 mit maximal 50 Watt.
DT 50 und DT 25 Stimmungen:
I â⬓ Negative Feedback Loop (NFL) eingestellt auf High. Die Kanalkontrolle verhält sich wie bei einem West Coast American Verstärker aus den 60er Jahren.
Empfohlene Eisntellungen: Class AB & Pentode.
II â⬓ NFL ist auf Medium eingestellt. Die Kanalkontrolle verhält sich wie ein klassischer britischer Verstärker der 60er Jahre.
III â⬓ Zero Negative Feedback führt zu einem sehr dynamischen und offenen Verstärkersound. Die Kanalkontrolle wirkt wie bei einem britischen Verstärker der 60er Jahre.
Empfohlene Einstellungen: Class A & Pentode oder Triode.
IV â⬓ NFL auf niedriger Einstellung: Zusätzliche Tieffrequenzresonanz für den modernen High-Gain. Die Kanalkontrolle wirkt wie bei einem neueren West Coast American Verstärker der 90er Jahre.
Empfohlene Einstellungen: Class AB & Pentode.
Class A & Class AB Schalter:
Class A: Gittervorspannung (Cathode Bias). Dynamischerer und empfindlicher. DT 50 läuft hier mit 25 Watt und DT 25 mit 10.
Class AB: Fixed Bias: Mehr Headroom als in Class A. (DT50 läuft auf 50 Watt und DT25 auf 25).
Pentode & Triode Schalter:
Pentode: Klarerer Ton und mehr Headroom.
Triode: Runderer Ton mit weniger Ausgangssignalstärke und Vintage Gefühl.
L6 Link:
L6 Link ist eine Digitale Audio Verbindung von Line 6. Entwickelt exklusiv für den Verbindungsaufbau zwischen POD HD und DT25 sowie DT50 Verstärkern. Verbinden Sie KEIN anderes Gerät mit XLR Anschluss mit L6 Link. Dies kann Schäden hervorrufen.
Stecken Sie ein XLR Kabel (AES/EBU) in den POD HD L6 LINK Ausgang und das andere Ende in den Jack Eingang des DT Verstärkers. Die meisten XLR Kabel sollten ausreichend Performance liefern. Sie können aber auch ein digitales XLR Kabel verwenden um die beste Performance zu erreichen.
Spezifikationen:
DT50 Specifications
DT25 Specifications
Gibt es seine List der Verstärkermodelle für die Verstärker der DT Serie?
Ja. Es gibt ein pdf Dokument hier.
Achtung, die meisten Vorverstärkermodelle für die DT Serie können nur via MIDI erreicht werden. Nutzen Sie dazu folgendes Dokument:
Welche Lautsprecher warden im Verstärker verwendet?
Im DT50 und DT25 112 Combo sind Celestion Custom G12H90 12ââ¬Å Lautsprecher installiert. Die DT50 212 Combo hat auch einen 12ââ¬Å Celestion Custom und zusätzlich einen Celestion Vintage 30 12ââ¬Å.
Welche Röhren Sind in den Verstärkern eingebaut?
DT50: Electro-Harmonix 12AX7 Voverstärker Röhren. (2 Stück) Sowie Electro-Harmonix EL34 Röhren. (2 Stück)
DT25: Eine 12AX7 Voverstärker Röhre aus chinesicher Herstellung sowie zwei Sovtek EL84 Röhren.
Was ist die Voreinstellung der DT50 EL34 Röhren?
36mV +/- 1mV.
Was ist die Voreinstellung der DT25 EL84 Röhren?
22mV +/- 3,V
Welche Line 6 Steuerungen funktionieren mit den DT25 und DT50?
Alle POD HD Geräte. Diese Geräte verwenden die neue, digitale L6 Link Verbindung um Kanal A auf die Einstellungen im derzeitigen POD HD Patch zu setzen.
Auf der Rückseite ist ein ââ¬Å¾Footswitchââ¬Å Jack, um zwischen Kanal A und B zu wechseln. Wenn Sie dieses Feature verwenden wollen, schließen Sie bitte einen TS Mono (1/4ââ¬Å) Fußschalter hier an.
Gibt es einen Kopfhörerausgang am DT25/DT50?
Nein.
Gibt es einen Vorspannungsschalter um die Röhren auf 6L6 oder andere Röhrenarten aumzuschalten?
Nein, die DT25/DT50 Verstärker sind für den EL34/EL84 Gebrauch entworfen.
Kann ich die DT25/DT50 ohne Lautsprecherlast verwenden?
Nein! Sie sollten Röhrenverstärker niemals ohne angeschlossenen Lautsprecher verwenden. Bitte folgen Sie den Belastungsvorschriften auf der Rückseite des Gerätes.
Erlischt meine Garantie, wenn ich Rollen an meine DT50/DT25 112 oder 212 Combo installiere?
Nein, bei korrekt installierten Rollen bleibt die Garantie bestehen. Sollten Sie jedoch nicht 100% sicher sein wie Sie die Rollen installieren sollen, sollten Sie die Installation von einem qualifizierten Techniker durchführen lassen. Line 6 deckt keine Schäden, die durch falsche Installation von Rollen entstehen.
Eines unserer Forenmitglieder MDinice hat netterweise eine Vorlage hochgeladen für die Installation von Ernie Ball Rollen: https://line6.com/support/thread/57744?tstart=0
Bekannte Probleme:
Austausch der 12AX7 Vorverstärker Röhren: Verwenden Sie keine Long Plate ââ¬Å¾LPââ¬Å Röhren, da diese extrem mikrofonisch sind.
Wie kann ich die neuen Funktionen des 2.0 Updates auf dem DT25/DT50 Verstärker per MIDI kontrollieren?
Wir haben ein Dokument erstellt um Ihnen dabei zu helfen:
Und hier noch ein Link mit Informationen zur Fehlerbehebung bei Röhrenverstärkern:
Avant de lire ce document familiarisez-vous avec les termes utilisés: DT50/DT25 Terminology FAQ
Est-ce quâ⬙il y en a des presets sur les amplis DT25 et DT50 comme pour les autres amplis Line6 ?
Non. Le DT25/DT50 se comporte comme un ampli traditionnel.
Est-ce que les amplis DT25/DT50 sont monophoniques ?
Oui, comme la plupart des amplis a lampes.
Quelle modélisation dâ⬙ampli est-ce que le DT25/DT50 utilise ?
Las modélisation HD la plus nouvelle de Line 6. (Comme notre nouveau POD HD)
Comment est-ce que les lampes contribuent au ton de lâ⬙ampli ?
Les EL34 (DT50) et EL84 (DT25) sont la source primaire pour la distorsion de lâ⬙ampli. Le signal de la guitare est amplifié à chaque étape progressive dans le circuit mais les lampes sont les premiers de distordre que la plupart des fidèles d'amplis à tubes désirent.
Comment est-ce que la modélisation du DT25/DT50 contribue au ton de lâ⬙ampli ?
En mode normal du DT25/DT50, la modélisation fonctionne comme le préampli. Il connecte le préampli digital avec lâ⬙ampli de puissance analogue pour créer le son dâ⬙ampli désiré. Câ⬙est différent de nos amplis Spider Valve. Pour ces amplis, nous avons modélisé tout le ampli (préampli et ampli de puissance) et dérivent ce signal à la sortie de lâ⬙ampli de puissance à lampes.
En mode ë low power û, la modélisation digitale assumera les fonctions de lâ⬙ampli de puissance et le bouton Master Volume est modifié : Un son qui ressemble un ampli de puissance avec une haute entrée qui peut être écouté avec un volume faible du moniteur. Si vous tournez le bouton Master Volume au maximum, vous recevez des tons Spider Valve (le logiciel de modélisation du ampli et préampli utilise les lampes EL34 et EL84).
En modes ë Low Power û et ë Normal û la modélisation est appliquée au signal de sortie envoyé à lâ⬙ampli de puissance à lampes. Si vous utilisés un POD HD connecté avec L6 Link vous devez utiliser le modèle de baffle par défaut de du modèle préampli sur le POD HD si vous utilisez une connexion L6 Link avec lâ⬙ampli DT pour recevoir le même son si vous utilisez lâ⬙ampli DT par lui-même.
Finalement, lâ⬙ampli a un mode ë Low Volume û sâ⬙il est connecté à un POD HD via câble L6 Link. Le ton dâ⬙un modèle préampli sélecté sur le preset POD sonnera légèrement différente si un modèle identique est sélecté sur lâ⬙ampli DT sur canal A parce que en mode Low Volume, canal A sur le DT utilise seulement le modèle préampli avec le bouton Master Volume modifié et canal B sur le DT utilise la modélisation préampli ET ampli de puissance avec le bouton Master Volume modifié. Lâ⬙inclusion de la modélisation du ampli de puissance est la différence ici.
Quelle est la différence entre le DT25 et le DT50 ?
Le DT25 a 25 watt maximum et 2 lampes EL84 et le DT50 e 50 watts maximum avec des lampes EL34. Trouvez le DT25 ICI et le DT50 ICI.
DT50/DT25 Voicings Switch :
I â⬓ La configuration de la boucle de rétroaction négative est sur HIGH. Le contrôle du canal fonctionne un peut comme un ampli West Coast American des années 1960.
Configurations recommandés : Class AB et Pentode.
II - La configuration de la boucle de rétroaction négative est sur MEDIUM. Le contrôle du canal fonctionne comme un ampli anglais classique des années 1960.
III â⬓ Aucune boucle de rétroaction négative. Un ampli dynamique
Configurations recommandés : Class A Pentode ou Triode
IV - La configuration de la boucle de rétroaction négative est sur LOW avec une résonance de fréquence basse pour les tons modernes à haut gain. Le contrôle canal fonctionne comme un des plus nouveaux amplis West Coast American des années 90.
Class A & Class AB Switch:
Class A: Cathode bias. Fournit le joueur avec plus de dynamique et de la sensibilité de toucher. Le DT50 fonctionne à 25 watts et le DT25 à 10 watts.
Class AB : Fixed biased. Fournit plus dâ⬙hauteur de niveau maximum de lâ⬙entrée et plus de puissance que Class A. Le DT50 fonctionne à 50 watts et le DT25 à 25 watts.
Pentode & Triode Switch :
Pentode : Du son clair et beaucoup dâ⬙hauteur de niveau dâ⬙entrée.
Triode : Son ronde avec une sensation vintage. Moins de niveau.
L6 Link
L6 Link est une connexion Digital Audio propriétaire de Line 6 développé pour une connexion exclusive des produits de Line 6 avec Line 6 Link. Ne connectez pas un autre appareil analogue avec un connecteur XLR standard au Line 6 Link. Dommage se produira.
Connectez un câble XLR digital (AES/EBU) du POD HD jack L6 LINK directement dans le L6 LINK IN de lâ⬙ampli DT. La plupart des câbles XLR offrent des performances suffisantes mais vous pouvez utiliser un câble XLR digital pour une performance meilleure.
Spécifications :
Spécifications du DT50
Spécifications du DT25
Est-ce quâ⬙il y en a une table pour les modèles des amplis DT et des POD HD ?
Oui, Il y en a un document pdf. ICI.
Attention, une plupart des modèles sont uniquement accessibles via MIDI. Consultez ce document pour plus dâ⬙informations sur lâ⬙accès de ces modèles:
Quels haut-parleurs est-ce que vous utilisez avec les amplis DT25/DT50?
Nous installons des Celestion Custom G12H90 12â⬙â⬙ dans la DT50/DT25 112 Combo et Un Celestion Custom G12H90 12â⬙â⬙ avec un Celestion Vintage 12â⬙â⬙ dans la combo DT50 212.
Quels tubes est-ce que vous utilisez ?
DT50 : Deux tubes Electro-Harmonix 12AX7 préampli et deux tubes Electro-Harmonix de puissances EL34.
DT25 : Un tube 12AX7 préampli chinois et deux tubes de puissances Sovtel EL84.
Quel est la polarisation sur les EL34 dans le DT50 ?
36mV +/- 1mV
Quel est la polarisation sur les EL84 dans le DT25 ?
22mV +/- 3mV
Quels contrôleurs Line 6 fonctionnent avec le DT50/DT25 ?
Tous les appareils POD HD. Ils utilisent la nouvelle connexion digitale L6 Link pour contrôler les configurations an canal A.
Il y en a un jack ë Footswitch û à lâ⬙arrière de lâ⬙ampli pour changer entre canal A et B. Utilisez un commutateur au pied contact 2 points (mono 1/4") de type verrouillage.
Est-ce quâ⬙il y en a une sortie casque sur les DT25/DT50 ?
Non.
Est-ce quâ⬙il y en a un commutateur pour changer les tubes en 6L6 ou autres types ?
Non les DT25/DT50 nâ⬙ont pas une fonction pour changer le type du tube. Le DT25/DT50 a été conçu pour les tubes EL34 et EL84.
Est-ce que je peux utiliser lâ⬙ampli sans impédance sur la sortie (c'est-à -dire un haut-parleur) ?
Non! Vous devriez toujours utiliser un amplificateur à tube avec un haut-parleur présent. Suivez les instructions de raccordement indiqué sur l'arrière du châssis de l'amplificateur.
Seront lâ⬙installation de roulettes sur mon DT50/DT25 annuler ma garantie?
Non, roulettes correctement installés ne seront pas annuler la garantie. Mais si vous n'êtes pas certain à 100% de comment installer les roulettes correctement, prenez votre ampli à un technicien ampli / service qualifié pour faire installer le matériel. Nous ne couvrons pas les dommages causés à l'amplificateur à cause dâ⬙un montage incorrect!
MDinice, un membre de notre forum a eu la gentillesse de partager un modèle de roulettes de type Ernie Ball : https://line6.com/support/thread/57744?tstart=0
Problèmes connus :
Si vous voulez échanger les 12AX7 tubes du préampli, nâ⬙utilisez pas les tubes LP (Long Plate) pour la première partie du préampli (V3). Les tubes LP sont très microphoniques.
Comment est-ce que je peux contrôler nouveaux fonctions de la mise à jour V2.0 de lâ⬙ampli DT25 et DT50 via MIDI ?
Nous avons crées un document pour vous aider avec la communication MIDI avec lâ⬙ampli DT pour contrôler les fonctions de la mise à jour 2.0 :
Informations sur le dépannage des amplis à tubes:
