A Catalyst may seem "dead" if a firmware update fails to complete itself. If the Catalyst fails to update:
Power down the amp and close the Updater app.
Open the Updater again, then power up the Catalyst while holding A and B to put the unit into bootloader mode.
You will then need to manually select the correct Catalyst product from three choices presented by the Updater.
Select the latest firmware version, then accept the Terms and Conditions.
After the update is complete, power down your Catalyst amplifier, then “RESET” the amplifier by holding down the “B” and “MANUAL” channel buttons while turning the power switch back on.
