The Helix 3.01 update addresses potential severely corrupted audio output. Due to this, we recommend updating your Helix family device as soon as possible. This issue may also be experienced on Helix Native; an update for Native will be available in the very near future.
IMPORTANT! Click here for detailed update instructions.
New Amps in 3.0
Helix Floor, Helix Rack, Helix LT, Helix Native, HX Stomp
[data-colorid=hojqr3as0x]{color:#16a085} html[data-color-mode=dark] [data-colorid=hojqr3as0x]{color:#5fe9ce}[data-colorid=qgilrioiw3]{color:#16a085} html[data-color-mode=dark] [data-colorid=qgilrioiw3]{color:#5fe9ce}[data-colorid=grtqrcdfll]{color:#16a085} html[data-color-mode=dark] [data-colorid=grtqrcdfll]{color:#5fe9ce}[data-colorid=sh8qdx13dt]{color:#16a085} html[data-color-mode=dark] [data-colorid=sh8qdx13dt]{color:#5fe9ce}[data-colorid=g6jcg0e1j1]{color:#16a085} html[data-color-mode=dark] [data-colorid=g6jcg0e1j1]{color:#5fe9ce}US Princess, based on* the Fender® Princeton Reverb
Das Benzin Mega, based on* the Mega channel of the Diezel VH4
Das Benzin Lead, based on* the Lead channel of the Diezel VH4
New Cabs in 3.0
1x10 US Princess, based on* the Fender® Princeton Reverb cab
1x12 US Princess, based on* the Fender® Princeton Reverb with a 12" Alnico Blue driver
New Effects in 3.0
Helix Floor, Helix Rack, Helix LT, Helix Native, HX Effects, HX Stomp
Distortion > Horizon Drive (Mono, Stereo), based on* the Horizon Devices Precision Drive. Includes an extra Gate Range parameter that, when set to "Extended," drops the gate's threshold down to -90dB
Distortion > Swedish Chainsaw (Mono, Stereo), based on* the BOSS® HM-2 Heavy Metal Distortion (Made in Japan black label)
Distortion > Pocket Fuzz (Mono, Stereo), inspired by* the Jordan Boss Tone fuzz
Distortion > Bighorn Fuzz (Mono, Stereo), based on* the 1973 Electro-Harmonix® Ram's Head Big Muff Pi
Distortion > Ballistic Fuzz (Mono, Stereo), based on* the Euthymia ICBM fuzz
Dynamics > Horizon Gate (Mono, Stereo), based on* the Horizon Devices Precision Drive's gate circuit. Includes an extra Gate Range parameter that, when set to "Extended," drops the gate's threshold down to -90dB. Works best before an amp
EQ > Acoustic Sim (Mono, Stereo), based on* the BOSS® AC-2 Acoustic Simulator. Includes an extra Shimmer parameter that imparts some motion to the harmonics, reminiscent of how a string's vibration tends to affect the other strings. Just like the original, works best with single-coil pickups. Can be used alone or in conjunction with an acoustic IR
Modulation > Poly Detune (Mono), Line 6 Original. Great for those who avoid traditional chorus pedals
Delay > Poly Sustain (Mono), Line 6 Original infinite sustain with a modulated poly pitch engine built in Assign Poly Sustain to a stomp footswitch. By default, Poly Sustain appears bypassed. First play the note or chord you wish to sustain, and then press the footswitch (on) to sustain it indefinitely. Keep playing while the note or chord loops. TIP: Some players may find it easier to change the footswitch mode to Momentary; that way, the note or chord sustains only while you hold the switch on, much like the sustain pedal on a piano. Press the switch again (off), and the sustained note or chord fades out. Interval—Sets the pitch of the sustained note or chord. TIP: This parameter is especially cool for creating massive drones to play over Attack—Sets the speed at which the sustained note or chord fades in Decay—Sets the speed at which the sustained note or chord fades out after bypassing the effect Mod Freq—Sets the speed of the built-in modulation Mod Depth—Sets the depth of the built-in modulation FX Level—Sets the level of the sustained signal RandDpth—Higher values increase the randomization of the section of audio being sustained, resulting in a more natural, but less predictable drone RandSpeed—Controls how fast the randomization wanders Level—Controls the overall output level of the block
Delay > Glitch Delay (Mono, Stereo), Line 6 Original performance delay that lets you freely manipulate the repeats' behavior in real-time Time—Sets the delay time; press the knob to toggle between ms/sec and note values Delay Div—Divides the delay time into smaller increments Mix—Controls the wet/dry mix of the delay. When set to 0%, no delay is heard; when set to 100%, no dry signal is heard Feedback—Controls the overall number of repeats heard for the entire sequence SliceFdbk—Controls the number of repeats heard for individual slices. At higher values, you could call this "Super Chaotic Feedback" Shuffle—Determines the likelihood of repeats shuffling/reordering Octaves—Determines the likelihood of repeats playing back an octave higher or lower Reverse—Determines the likelihood of repeats playing backward Seq Drift—Determines the likelihood of the entire sequence changing every time it loops around. When set to 0%, the same sequence loops forever. TIP: Assign this parameter to a footswitch set to toggle between a higher number and 0%. If you hear a random sequence you want to maintain, press the switch to set Seq Drift to 0%, and it'll repeat that way indefinitely Smoothing—Higher values apply smoothing between slices and can give a synth-pad type quality, lower values maintain transients. Or set it just high enough to avoid pops and clicks Trails—When on, delay repeats continue to ring out after the block is bypassed
Pitch/Synth > Poly Pitch (Mono), Line 6 Original
NOTE:
Polyphonic pitch engines are designed for shifting complex chords with minimal artifacts at the expense of latency (and our algorithms have lower latency than leading standalone poly pitch pedals). If you're looking to pitch individual notes (such as in a solo), monophonic pitch-shifting is often preferred. See the Tracking parameter below for more information
IMPORTANT!
3.0's new poly models are
extremely
DSP-intensive. Some effects can eat up roughly a quarter of all available DSP on a Helix Floor, Rack, or LT or half (!!!) of all available DSP on HX Stomp or HX Effects. You also can't run more than one on the same path/DSP (unless you're running Helix Native with Hardware Compatibility Mode turned off). Don't say we didn't warn you...
IntervalSets the pitch of the effect in semitones
CentsSets the pitch of the effect in cents
ShiftTimeDetermines how long it takes for the signal to ramp up or down to the set pitch when the block is enabled. Press the knob to toggle between ms/Sec and note/beat values. TIP: Want to hit the switch and have Poly Pitch dive bomb and land exactly one bar later? Press the knob to select note values and set ShiftTime to "1/1"
ShiftCurveDetermines the trajectory curve of the pitch shift over time. StartSlow values are concave (slower changes to start, speeding up toward the end); StartFast values are convex (the opposite). At the knob's extremes (Start Slow 5 and Start Fast 5), the pitch will actually overshoot a little before settling on the target pitch. The default is "Linear"
ReturnTimeDetermines how long it takes for the signal to return to normal pitch when the block is bypassed. Press the knob to toggle between ms/Sec and note/beat values
ReturnCurvDetermines the trajectory curve when returning to the original pitch. StartSlow values are concave (slower changes to start, speeding up toward the end); StartFast values are convex (the opposite). At the knob's extremes (Start Slow 5 and Start Fast 5), the pitch will actually overshoot a little before settling on the original pitch. The default is "Linear"
TrackingDetermines how the poly pitch engine reacts to your playing. Leave this set to "X Stable" (the default, with the fewest artifacts when pitch shifting complex chords) and only select a different setting if you experience too much latency when playing fast lead lines
Auto EQDetermines how much compensation EQ is applied to the shifted signal. If the effected signal sounds too harsh when pitched up (or dull when pitched down), adjust this setting to taste. The higher the value, the more EQ is applied at the shift end points; when set to 0.0, no compensation EQ is applied
MixControls the wet/dry mix of the pitch-shift
LevelControls the overall output level of the block
Pitch/Synth > Poly Wham (Mono), Line 6 Original. Automatically assigned to EXP 1 and the toe switch toggles it on and off. See Poly Pitch notes above for additional information
Pitch/Synth > Poly Capo (Mono), Line 6 Original. A Simpler version of Poly Pitch when you just want to transpose your playing. See Poly Pitch notes above for additional information
Pitch/Synth > 12 String (Mono), Line 6 Original 12-string guitar emulation
Volume/Pan > Stereo Imager (Stereo), Line 6 Original. Used to increase the apparent stereo width of your signal when connecting Helix to two amps or a stereo playback system; just make sure there aren't any mono blocks after it!
Looper > Shuffling Looper (Mono, Stereo), Line 6 Original. Part looper, part sampler, part inspiration generator, part performance instrument, the Shuffling Looper intelligently chops up your playing and gives you real-time control over reordering, octave shifting, reversing, and repeating. It's all immense fun (even on vocals, drums, and percussion), but you'll want to familiarize yourself with its controls. IMPORTANT: The Shuffling Looper does not currently respond to Command Center > HX Commands or per-function MIDI commands
Add the Shuffling Looper to a preset and assign it to a footswitch.
Turn Knob 1 (Slices) to set the number of slices your loop will be chopped into. 8 slices is the default.
Press the switch to begin recording. The LED lights red, indicating the loop is recording.
At the end of your loop, press the switch. The LED lights green, and the sliced loop sequence immediately plays.
During playback, adjust the following knobs (or assign them to controllers, like expression pedals or snapshots):
SlicesChanges the number of slices your loop will be chopped into
SeqLengthDetermines the number of slices in the sequence. This can be changed even after recording a loop
ShuffleDetermines the likelihood of slices shuffling/reordering. At 0%, the slices never shuffle; at 100%, they're constantly reshuffling
OctaveDetermines the likelihood of slices playing back an octave higher or lower
ReverseDetermines the likelihood of slices playing backward
RepeatDetermines the likelihood of slices repeating
SmoothingHigher values apply smoothing between slices and can give a synth-pad type quality, lower values maintain transients. Or set it just high enough to avoid pops and clicks
Seq DriftDetermines the likelihood of the entire slice sequence changing every time it loops around. When set to 0.0, the same sequence repeats forever; when set to 10.0, the sequence changes completely every time it loops TIP: Assign this parameter to a footswitch set to toggle between a higher number and 0%. If you hear a random sequence you want to maintain, press the switch to set Seq Drift to 0%, and it'll repeat that way indefinitely
PlaybackSets the looper's playback level
Low CutApplies a low cut (or high pass) filter to the loop, letting you remove the looper signal below a certain frequency
High CutApplies a high cut (or low pass) filter to the loop, letting you remove the looper signal above a certain frequency
Want to change it up? While the loop is playing, press the switch to randomize its slice sequence.
Quickly double-press the switch. Playback/recording stops, and the LED lights white, indicating a loop is in memory. Press again to restart.
While the loop is playing or stopped, press and hold the switch. The recording is deleted, and the LED lights dim white.
New Features in 3.0
True Preset Spillover
Helix Floor, Helix Rack/Control, Helix LT only
Despite what some might have you believe, the only digital multieffects units with true preset spillover were the DigiTech GSP1101, 2112, and 2120, and they accomplished this by dedicating a second identical DSP to spillover and only spillover. (Basically, to hear two dynamically allocated presets with absolutely zero gapnot some global reverb or delay smeared to cover the gapyou need enough DSP to run both of them simultaneously.) So... if you're willing to sacrifice half your DSPthat is, COMPLETELY DISABLE PATH 2you too can have true preset spillover. IMPORTANT! Unfortunately, Looper recording or playback will not currently spill over from one preset to another. Also, note that there may be a slight hiccup when switching between two presets with different impedance values for the Guitar Input.
In the Global Settings > Preferences menu, set Preset Spillover to "On." (SHORTCUT: Hold ACTION and press HOME.) A dialog appears, reading "Remove Path 2 to enable preset spillover?"
Press Knob 6 (OK).
Press HOME. Path 2 has disappeared! You may now switch presets to your heart's delight with true spillover, but note that if Preset A is still spilling over into Preset B (say one of its delay's feedback is making it self-oscillate), switching to Preset C will abruptly cut off Preset A.
To return to normal operation with two paths, turn Preset Spillover back to "Off." (SHORTCUT: Hold ACTION and press HOME again.) A dialog appears, reading "The preset must be reloaded. All unsaved changes will be lost!" So if you've made changes to the preset, be sure to save it before turning Spillover off.
Press Knob 6 (OK).
But but but... I don't wanna lose Path 2 for spillover!
Then keep using snapshots.
Favorites
Helix Floor, Helix Rack/Control, Helix LT, Helix Native, HX Effects, HX Stomp
If you've dialed in an amp or effects block exactly the way you like it, you can now save its settings as a favorite so it can be added very quickly, complete with bypass state and footswitch assignment. (Favorites in HX Effects do not recall footswitch assignment.) Favorites appear in a new "Favorites" category and can be renamed, reordered, and cleared. From HX Edit, you can use the Export and Import Favorites to create an endless collection of them on your hard drive, and even share them with friends and across devices (where supported). TIP: If you don't want a favorite to be recalled with its footswitch assignment, save the block as a favorite without assigning a footswitch."
Choose one of your favorite amps or effects and tweak it exactly how you like it, with or without footswitch assignment. (Favorites in HX Effects do not recall footswitch assignment.)
Press ACTION and then press Add to Favorites. The Favorites list appears.
If you wish to replace an existing favorite (you get 128 total), select it and press Replace Favorite. If you wish to add a new favorite, select the location where you want to place it and press Add New Favorite.
OPTIONAL: While the Favorites list is open, press ACTION. To reorder the selected favorite up or down the list, turn Reorder Favorite (on HX Effects, press Reorder Up or Reorder Down) To rename the selected favorite, press Rename Favorite To clear the selected favorite, press Clear Favorite To clear all favorites, press Clear All Favorites. A dialog appears. Press OK to confirm.
All right, so what?
Here's what:
At any time, select an empty block and turn the joystick (Big Knob on HX Effects or Lower Knob on HX Stomp). All your perfectly-tweaked favorite amps and effects instantly appear, without having to open the model list at all. If you typically keep effect types on the same stomp footswitches, you could conceivably create a brand new preset with all of your favorite stuffincluding all footswitch assignmentsin less than 10 seconds. Creating tones has never been faster or easier. TIP: If you keep one or more external pedals connected to Helix's FX Loops, add the FX Loop blocks as favorites and then rename them after the real thing.
Wait. Did you really name the 3.0 update after the 2004 romantic comedy starring Ben Stiller and Jennifer Aniston that has a dismal rating of 27% on Rotten Tomatoes?
Huh. I guess it sounds dumb when you put it that way.
User Model Defaults
3.0 lets you save any amp, cab, or effect block's settings as default, so every time you call that model up, it sounds exactly the way you want it. Or, if you want to revert it to factory default, you can do that too. Editing/saving a User Default does not affect any existing instances of the model currently in use in your presets.
Choose any model and tweak it exactly how you like it.
Press ACTION and then User Default. From Helix Native or HX Edit, right-click (Mac: control-click) the block icon and select "User Default."
Global Settings > Preferences > Auto Impedance
Helix Floor, Helix Rack/Control, Helix LT, HX Stomp
A new Global Settings > Preference parameter determines how the Guitar In's impedance circuit behaves when Input > In-Z is set to "Auto." When set to "First Block" (the default, and how Helix has worked since the beginning), the impedance circuit reflects the impedance of the first block on Path 1A, regardless of whether it's enabled or bypassed. When set to "First Enabled," the impedance circuit reflects the impedance of the first enabled block on Path 1A. Called "Auto Impedance" because "Sorry-this-took-so-long-we-love-you-Tito83" wouldn't fit.
Min/Max Value Indicators
Helix Floor, Helix Rack/Control, Helix LT, HX Stomp [Feature already in HX Effects]
Parameters assigned to controllers or snapshots now display small white Min Value (below) and Max Value (above) indicators above and below the value bar. You can now see the range of continuous controllers from the Home screen.
8 Blocks in HX Stomp
HX Stomp's simultaneous block count has been increased from six to eight.
IMPORTANT! Although HX Stomp now has two additional block locations, this doesn't mean it magically has more DSP horsepower to accommodate those blocks. Don't be surprised if you're not able to fill all eight blocks with exactly what you want, especially considering the new polyphonic pitch models take up a lot more DSP. We've taken note of those who've bemoaned HX Stomp's 6 block limit, and if the same person now complains about running out of DSP with 8 blocks, we're sending hooligans to their home to administer an atomic wedgie.
NOTE: It shouldn't come as any surprise, but any presets you make in 3.0 will not be compatible with 2.92 or earlier firmware.
Command Center in HX Stomp
HX Stomp [Feature already in Helix Floor, Helix Rack/Control, Helix LT, and HX Effects]
Why would people expect a stompbox with only three footswitches to also act as a master MIDI controller? Yeah, we don't know either, but enough of you asked for it, and it wasn't exceedingly difficult to add.
Press together to open the Menu and then press Knob 3 (Command Center).
Turn the Upper Knob to select the command source (Instant 1-6, Footswitch 1-5, or EXP 1-2).
Turn Knob 1 (Command) to select the type of command you wish to transmit. For information on the types of commands HX Stomp transmits, see the HX Stomp 3.0 Owner's Manual.
Wait, does this mean I can use HX Stomp as both an audio interface AND a remote control for YouTube lesson videos by sending QWERTY hotkeys?
Yes.
Tuner in Helix Native
Helix Native now has the same needle and strobe tuner from Helix.
Click the tuner icon.
From the Type pull-down menu, choose the tuner type: Coarse, Fine, or Strobe.
Gain Reduction Meters in Helix Native
The following block types display a gain reduction meter in the inspector when selected:
Dynamics > Compressor
Dynamics > Gate
Artist Presets
IMPORTANT! Because we never want to overwrite your own presets, upgrading to 3.0 does NOT automatically make these presets visible; there are two methods to restore them:
METHOD ONE: Resetting Factory Presets
WARNING! Restoring factory presets will completely overwrite your own, so make sure they're backed up first!
Make sure you've backed up your presets and turn off Helix/HX.
Perform the following procedure:
Helix Floor/LT: While holding footswitches 7 and 8 (two leftmost switches on the bottom row), turn on Helix Floor/LT. Wait for "Will restore stock Presets and Setlsts..." to appear and let go
Helix Rack/Control: While holding knobs 3 and 4 (two middle knobs below the screen), turn on Helix Rack. Wait for "Will restore stock Presets and Setlsts..." to appear and let go
Helix Native: Click the gear icon in the lower left corner, select the Presets/IRs tab, and click "Restore Factory Setlists"
HX Effects: While holding footswitches 5 and 6 (two middle switches on the bottom row), turn on HX Effects. Wait for "Will reset Presets..." to appear and let go
HX Stomp: While holding footswitches 1 and 2, turn on HX Effects. Wait for "Will reset Presets..." to appear and let go
METHOD TWO: Manually Loading 3.0 Factory Setlists via HX Edit
WARNING HX Effects/Stomp users! Loading a factory setlist file will completely overwrite your own, so make sure everything's backed up first!
WARNING Helix Floor/Rack/LT/Native users! Loading a factory setlist file will completely overwrite the current setlist, so make sure it's backed up first! We strongly recommend you choose an empty (or unwanted) setlist to overwrite.
Click here and download the setlist file(s) for your Helix or HX product.
Connect Helix/HX to your computer and launch HX Edit 3.0 (or higher).
If you have Helix Floor, Rack, LT, or Native, select the Presets tab and click the Setlists pull down to select the setlist you wish to overwrite (see image below). HX Effects and HX Stomp do not have multiple setlist locations, so you can skip this step.
Drag the .hls setlist file you downloaded in Step 1 onto the Preset List.
Helix 3.0 includes factory presets created by the following artists:
Helix Floor, Helix Rack/Control, Helix LT, Helix Native [FACTORY 1 setlist]
13B-14CFish (Christina Aguilera)
14DJeff Waters (Annihilator)
15A, 15BRichie Castellano (Blue Öyster Cult)
15CRobbie Calvo
15DRyan "Fluff" Bruce (Dragged Under)
16A-16DFelix Martin
17AMario Quintero (Spotlights)
17B, 17CBumblefoot (Sons of Apollo)
17D, 18ABilly Sheehan (Sons of Apollo, Winery Dogs)
18BAndy Abad (Jennifer Lopez)
18C-19BMisha Mansoor (Periphery)
19CDuke Erikson (Garbage)
19DSteve Marker (Garbage)
20AEric Avery (Garbage)
20BBill Kelliher (Mastodon)
20CJohn Browne (Monuments)
20DOlly Steele (Monuments)
21AJon Button (The Who)
21BTrev Lukather (Levara)
21CSteve Howe (Yes)
21DDustin Kensrue (Thrice)
22APete Thorn
22BRhett Shull
22CJade Puget (A.F.I.)
22D, 23AJeff Schroeder (The Smashing Pumpkins)
23BGraham Coxon (Blur)
23C, 23DChris Buck
24ALewis Allen (Sam Smith)
24B-25ARabea Massaad
25BSoren Andersen
25CDevin Townsend
25D, 26ANathan Navarro
26B-26DVernon Reid
27BPhilip Bynoe
27CMarkus Reuter
HX Effects
12A-12DJulien Baker
13ASarah "Noveller" Lipstate
13B, 13CSteve Stevens
3.0 Owner's Manuals
Helix Floor, Helix Rack/Control, Helix LT, Helix Native, HX Effects, HX Stomp, HX Edit
As it's immensely expensive and complicated to translate Owner's Manuals into the many languages we're required by law to provide, Helix and HX Owner's Manuals have not been updated since 2.X. They've now been updated for 3.0.
You can also access the 3.0 Pilot's Guide from within Helix Native itself. Click the question mark in the lower left corner and select "Pilot's Guide"
HX Effects
HX Stomp
HX EditAccess the 3.0 Pilot's Guide from within HX Edit itself. Click the question mark in the lower left corner and select "Pilot's Guide"
Other Changes and Improvements in 3.0
On HX Stomp, Global Settings > Footswitches > Stomp Select now has an "Off" value. When set this way, neither touching nor pressing will change which block is in focus [value is already in Helix Floor, Rack, and LT]
Pitch/Synth > 4 OSC Generator OscFreq parameters now display single Hz resolution between 100 and 1000 Hz
HX Edit now lets you restore individual setlists from a backup
In HX Edit, Favorites and User Model Defaults can now be restored from a backup, independent of setlists, presets, IRs, and Global Settings
Gain reduction meters now also appear for the Input block's noise gate [Helix Floor, Rack, and LT only]
Gain reduction meters and signal present indicators are now more responsive
Parameter knob ballistics have been improved
Parameter slider handles are thinner to accommodate new min/max value indicators
Press-turning a knob to assign Snapshot control now requires a bit more turning to minimize accidental assignments
New splash screens for Helix Floor/Rack/LT and HX Stomp
Bug Fixes in 3.01
In extremely rare cases with specific blocks in a specific order, audio could become severely corruptedFIXED
In certain cases, the Delay > Glitch Delay can exhibit minor pops and clicks when placed on Path 2, regardless of where its Smoothing parameter is set (that is, not the good type of glitchiness)FIXED
Many other minor fixes and improvements
Bug Fixes in 3.0
When synced to external MIDI clock or retriggering via TAP, certain models with tremolo circuits' LFO set to square wave would invert the waveformFIXED
If Helix had been left powered on for 24 hours or longer with the same preset active (What? Why?), its reverb blocks could become disabled until selecting another presetFIXED
Known Issues in 3.01
Distortion > Vermin Dist's resonant filter was mapped incorrectly, and is especially apparent at higher gain settings. This will be fixed in 3.10
In the Poly Pitch models, very fast playing may exhibit some minor onset smearing. Additional improvements to the poly pitch engine are forthcoming
Variax Model min and max sliders do not automatically update when a Variax is connected
After importing a .WAV file into the current 'Empty' slot of an Impulse Response block, all audio output can stop
When Tuner View is active while Spillover is engaged, changing presets can sometimes cause audio output to stop
Clearing a Split block on Path 2 does not automatically remove its bypass assignment
