What is the Metallurgy Collection?
The MetallurgyTM Collection of amplifier and effects plugins was created specifically for guitarists who wish to quickly and easily access contemporary versions of classic and modern metal tones—as well as craft original tones of their own. The Collection bundles the Modern, Thrash, and Doom plugins, which are also available individually.
The Metallurgy Collection plugins feature amplifier and effects models drawn from the award-winning HX® family of products.
How many amp models per plugin?
Each Metallurgy plugin features four amplifier models carefully chosen to deliver a full range of genre-specific tones.
What kind of effects are included?
Pre-amplifier Effects
Each Metallurgy plugin features 3 (or more) mono. style-specific effects, as well as a polyphonic capo, that can be used before the amp in the signal chain.
Post-amplifier Effects
Each Metallurgy plugin features two stereo, style-specific effects that may be used after the amp in the signal chain.
What about Cabinets, Microphones, and IRs?
Each Metallurgy plugin features a choice of eight speaker cabinets and eight microphones, all based on IRs. Two mics may be selected and combined with a stereo room mic array, and up to two third-party Impulse Responses (IRs) may be substituted for the factory mics. Once you’ve logged in and authorized your Metallurgy software, IRs purchased from the Line 6 Marketplace on the same account will be made available in Metallurgy.
Can I automate parameters in the Metallurgy Collection?
Yes. Nearly every parameter in the Metallurgy Collection can be automated.
Does the Metallurgy Collection support MIDI parameter control?
Yes, nearly every parameter in the Metallurgy Collection can be controlled via MIDI CC.
Is amp switching and amp bypassing via MIDI Learn or automation available?
Switching channels via midi/automation is not available because the plugin would have to load the DSP of the alternate channel – which is essentially another model being loaded. Changing amp models in general is not supported via midi and automation.
You can bypass an amp model and its DSP by disabling (bypassing) the amp view in the top toolbar. That also is not supported via midi learn or automation. There are other ways to bypass/mute that are midi/automation supported within the cab view’s mixer.
Is the UI resizable?
Not at launch. We’re working on it.
Does the Metallurgy Collection support Retina displays (2x resolution)?
Yes. The Metallurgy Collection includes Retina support.
Is there Undo/Redo functionality?
Yes, Undo/Redo is included at launch, along with A/B Compare.
Does the Metallurgy Collection have a built-in tuner?
Yes, it does include a chromatic tuner.
Will there be a standalone version?
Yes, each plugin includes standalone functionality.
Are there any artist presets?
Not at launch.
System and Hardware Requirements for the Metallurgy Collection
Mac Computers:
Mac OS X 10.14 or newer
Runs natively on Silicon M1 systems running macOS 11.0 Big Sur or newer
64-bit AAX Native, Audio Units (AU), VST3 host DAW software
Supported Sample Rates: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz
Minimum Hardware Requirements
Core i5 2.6GHz processor or faster
8GB of RAM
200MB of free disk space
Internet connection required for initial license authorization and trial version
Windows Computers:
Windows 10 (64-bit only) or newer
64-bit AAX Native or VST3 host DAW software
Supported Sample Rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz
8GB of RAM
Note: Standalone version running on Windows systems require use of an ASIO driver and interface
What Digital Audio Workstations is the Metallurgy Collection compatible with?
Supported Hosts
The Metallurgy Collection has been tested and officially qualified against the DAW versions and plug-in formats below.
If your DAW or DAW version is not listed below, we recommend trying the The Metallurgy Collection demo first to confirm compatibility.
Your operating system must be compatible with your DAW for The Metallurgy Collection to work properly. Please refer to your DAW’s documentation for supported operating systems.
Mac
Pro Tools 2020, 2021, 2022 (AAX Native)
Studio One Professional 5 (VST3, AU)
Cubase 10.5, 11 (VST3)
Ableton Live 11 (VST3)
REAPER 6 (VST3, AU)
Bitwig Studio 3 (VST3)
Digital Performer 10 (AU)
FL Studio 20 (AU)
Logic Pro X 10.6.2 (AU)
GarageBand 10 (AU)
Windows
Pro Tools 2020, 2021 (AAX Native)
Studio One Professional 5 (VST3)
REAPER 6 (VST3)
Digital Performer 10 (VST3)
FL Studio 20 (VST3)
Cakewalk by BandLab (VST3)
Will The Metallurgy Collection work with iLok?
There is no licensing available through iLok.
Is there a demo version to try out?
Yes. You can try before you buy! The free trial is fully functional for 15 days and is available at https://line6.com/software/.
How can I purchase The Metallurgy Collection?
The Metallurgy Collection can be purchased from https://shop.line6.com.
I bought The Metallurgy Collection and I don't like it. Can I return it?
The standard return policy is 15 days from the date of purchase. Contact Customer Service with a ticket at https://line6.com/company/contact/ to request a refund.
How do I authorize the Metallurgy software on my computer?
Download the latest version of the Metallurgy software at https://line6.com/software/
Run the Metallurgy software installer. We suggest you temporarily disable all third-party antivirus programs during installation. Follow the prompts and restart your computer if required.
Launch your DAW, plugin host, or recording software, and insert the Metallurgy plugin into an audio track as an effect. (Note: the plugin may also be used via an aux bus.)
Log in with the Line 6 account you used to purchase or activate the Metallurgy software.
Click "Authorize This Computer" or the blue link displayed in the dialog.
If you can't authorize your computer with the Metallurgy software, you may have exceeded the limit of authorized devices for your Line 6/YGG account. Visit https://line6.com/account/devices/ to de-authorize any unused devices to make room. You may also contact Customer Service at https://line6.com/company/contact/ to resolve authorization issues.
How many computers can the Metallurgy Software be installed on with a single license?
Licensing is tied to your Line 6 account. Up to four computers can share a single license simultaneously. Attempts to authorize a fifth computer will result in the Metallurgy software not responding. You'd need to deauthorize one of the previous four computers, then authorize the additional computer.
How do I access third party IRs in the Metallurgy plugin?
Drag IR files into your designated IR folder (Documents > Line 6 Metallurgy > Impulse Responses (Mac or Windows) and you will see them appear within the IR browser of all instances of your Metallurgy plugins and standalone apps.
What are the exact amps and effects included in each plugin?
Metallurgy: Modern
Amps
Vitriol
Revv Generator
Badonk
Archetype
Effects
Rochester Comp
Minotaur
Caliper Drive
Mod/Chorus Echo
Dynamic Hall Reverb
Metallurgy: Thrash
Amps
Rivet Clean
Cali IV
Placater Dirty
Das Benzin
Effects
Throaty Wah
Pillars OD
Stupor OD
70s Chorus & Hot Springs reverb (Rivet Clean amp model only)
Automatic Double Tracker
Vintage Digital Delay
Metallurgy: Doom
Amps
MOO)))N
Mandarin Rocker
Doom
Mail Order Twin
Effects
Bighorn Fuzz
Wringer Fuzz
Vital Distortion
Pebble Phaser
Bias Trem & Hot Springs Reverb (included in the Mail Order Twin amp model only)
Adriatic Delay
