AMPLIFi FX100 Post-Update Reset and Pedal Calibration
IMPORTANT!!! Two steps are required for completing the FX100 firmware update process: reset the unit, then calibrate the pedal. Your FX100 may not function correctly after an update until these steps shown below are completed.
Deutsche Version
La version française
Note: Factory Reset replaces all presets on the device, including your custom presets, with the factory presets.
  1. Turn off AMPLIFi FX100
  2. While pressing and holding both the big knob and TAP footswitch, switch the power on
The process has completed when you see 01 in the bank display and the A footswitch is lit.
Step 2: Calibrate the Wah/Volume Pedal
NOTE: This step is mandatory to complete the update process!
  1. Turn off AMPLIFi FX100.
  2. While pressing and holding footswitch A, switch the power on.
    The display reads "00" and footswitch D LED is lit.
  3. Press footswitch D.
    The display reads "01".
  4. Move the wah/volume pedal to the toe position and press to engage the toe switch.
    The display reads "02" and footswitch D LED is lit.
  5. Move the wah/volume pedal all the way to the Heel position and press footswitch D.
    The display reads "03".
  6. Move the wah/volume pedal to the toe position without clicking the toe switch.
  7. Press footswitch D.
    The displays reads "04".
  8. Move the wah/volume pedal and note the values in the display.
    Values should scroll from 0 (heel down) to 99 (toe down).
  9. Press footswitch D to save the calibration values.
    The display reads "05".
  10. Restart AMPLIFi FX100.
Step 3: Pair your iOS device
  1. Repair your iOS device with FX100
  2. Exit AMPLIFi Remote then relaunch the app
You are done!
Folgen Sie diesen Anweisungen nachdem Sie Ihr AMPLIFi FX100 auf Version 1.1 aktualisiert haben.
Schritt 1: Zurücksetzen des Gerätes auf Werkseinstellungen:
Achtung, das folgende Zurücksetzen des Gerätes ersetzt alle Presets auf dem Gerät mit den standard Presets. Inklusive Ihrer eigenen Presets.
  1. Schalten Sie das AMPLIFi FX100 ab.
  2. Während Sie den großen Lautstärke Regler sowie den TAP Fußschalter gedrückt halten, starten Sie das Gerät ein.
Wenn Sie eine 01 auf dem Bildschirm angezeigt bekommen und Fußschalter A leuchtet ist der Vorgang abgeschlossen.
Schritt 2: Kalibrierung des Pedals:
  2. Während Sie den Fußschalter A gedrückt halten, schalten Sie das Gerät ein.
    1. Auf dem Bildschirm wird nun 00 angezeigt und Fußschalter D leuchtet.
[*]Drücken Sie den Fußschalter D.
  1. Auf dem Bildschirm wird jetzt 01 angezeigt.
[*]Beweguen Sie das Pedal in die Zehstellung und drücken Sie.
  1. Auf dem Bildschirm wird nun 02 angezeigt und Fußschalter D leuchtet.
[*]Beweguen Sie das Pedal in die Fersenstellung und drücken Sie Fußschalter D.
  1. Auf dem Bildschirm wird nun 03 angezeigt.
[*]Bewegen Sie das Pedal nun in die Zehstellung aber ohne zu drücken. [*]Drücken Sie Fußschalter D.
  1. Auf dem Bildschirm wird nun 04 angezeigt.
[*]Bewegen Sie das Pedal und achten Sie auf den Wert auf dem Bildschirm.
  1. Der Wert sollte sich zwischen 0 (Fersenstellung) bis zu 99 (Zehenstellung) bewegen.
[*]Drücken Sie Fußschalter D um die Kalibrierung abzuspeichern.
  1. Auf dem Bildschirm wird nun 05 angezeigt.
[*]Starten Sie das AMPLIFi FX100 neu. [*]Koppeln Sie die Geräte neu. [*]Schließen Sie die AMPLIFi Remote App, starten Sie diese dann neu.
Suivez ces instructions après vous avez faites une mise à jour du firmware AMPLIFi FX100 jusqu’Ã la version 1.1.
1 : Réinitialisez l’AMPLIFi FX100
Attention, la réinitialisation remplace tous les presets, inclus sont vos propre presets avec les presets par défaut.
  1. Éteignez l’AMPLIFi FX100.
  2. Tout en maintenant le bouton du volume principal et le commutateur TAP, allumez L’AMPLIFi.
Le processus est terminé quand vous voyez 01 dans l'affichage de la banque et le commutateur au pied A est allumé.
2 : Calibrez la pédale de volume/wah
  2. Tout en maintenant le commutateur au pied, allumez l’appareil.
    [*]Poussez le commutateur au pied D.
    1. Vous pouvez lire « 01 ».
    [*]Déplacez la pédale à la position des orteils et poussez-la.
    1. Vous pouvez voir « 02 » sur l’écran et le LED du commutateur au pied D est allumé.
    [*]Déplacez la pédale à la position de talon et poussez le commutateur au pied D.
    1. Vous pouvez lire « 03 ».
    [*]Déplacez la pédale à la position des orteils mais sans cliquer. [*]Poussez le commutateur au pied D.
    1. Vous pouvez lire « 04 ».
    [*]Bougez la pédale, les nombres sur l’écran changent.
    1. De 0 (talon) Ã 99 (orteils).
    [*]Poussez le commutatuer au pied D pour enregistrer la calibration.
    1. Vous pouvez lire « 05 ».
    [*]Redémarrez l’AMPLIFi FX100. [*]Recloupez votre appareil iOS avec le FX100. [*]Quittez AMPLIFi Remote et redémarrez l’application.
    C’est tous !
Vous pouvez voir « 00 » sur l’écran et le LED du commutateur au pied D est allumé.
