Version française
Deutsche Version
Full List and Descriptions of AMPLIFi FX100 Amps, Cabs, and Effects
8 simultaneous effects
Over 200 amps, effects, and speaker cabinets
Access 100 onboard presets - and unlimited presets via AMPLIFi app
Change presets and switch banks using 4 pro-quality, backlit footswitches
Blootooth steaming audio for playing along with your music library (compatible with iOS, Android, Mac and PC)
Rugged construction with bent metal chasis
Weight: 7 lbs 6 oz
Dimensions: H: 3" W: 17 3/4" D: 9 1/4"
1/4" Guitar input
1/4" Headphone output, 1/4" stereo full-range balanced outputs and 1/4" Amp output
Tap tempo/tuner
Compatible with iOS 7.0+
70+ amps, 100+ effects and 20+ speaker cabinets
Remotely control amp parameters to dial in your sound
Automatic tone matching instantly provides the perfect tones for jamming with songs in your music library
Access thousands of tones online
Share and rate tones in the cloud
Backup and store unlimited presets in the cloud
Q: What type of devices can AMPLIFi FX100 stream Bluetooth audio from?
A: AMPLIFi's high performance 5 speaker stereo design can stream Bluetooth audio from any Androidâ⢠device, iOS device, and Macî or PC equipped with Bluetooth.
Q: How do I pair my Bluetooth device with AMPLIFi FX100?
A: To pair the AMPLIFi FX100 with your Bluetooth device:
Enable Bluetooth on the device you would like to stream audio from.
Put the AMPLIFi FX100 into 'Pairing Mode' by pressing and holding the Bluetooth button located to the left of the AMPLIFi FX100 logo- it will begin to flash to indicate it is in 'Pairing Mode'.
Within the Bluetooth options of your device an entry for 'AMPLIFi FX100' will appear.
Select the 'AMPLIFi FX100' entry and pair with it - the Bluetooth LED will stop flashing and become solidly lit blue.
Your AMPLIFi FX100 is now ready stream audio from your device wirelessly.
Q: What Apple® iOS devices is AMPLIFi Remote compatible with?
A: AMPLIFi Remote requires iOS 7.0 and is compatible with the following iOS devices:
iPhone 5S
iPhone 5C
iPhone 5
iPhone 4S
iPhone 4
iPad 4
iPad 3
iPad 2
iPad mini
iPod 5
Q: Which specific Android devices are supported by AMPLIFi Remote?
A: After updating the AMPLIFi FX100 firmware to 2.0 or better, AMPLIFi Remote is compatible with the following Androidâ⢠devices:
Samsung Galaxy S5
Samsung Galaxy S4
Samsung Galaxy S III
Samsung Galaxy Note Pro
Samsung Galaxy Note II
HTC One M8
HTC One M7
Motorola Moto X
Google Nexus 7
Amazon Kindle Fire HDX
ASUS MeMo Pad ME176CX
Asus Fonepad
ASUS PadFone
LG G2
LG Optimus
LG F7
LG Nexus 4
Generally speaking, although not qualified, any Android phone, tablet or phablet will work, provided it is able to run the required Android OS version.
Q: How do I update the AMPLIFi FX100's firmware?
A: We always recommend that you run the latest firmware on your AMPLIFi FX100. Your AMPLIFi Remote application will inform you whenever a firmware update is available, so you'll always know you have the latest version! Follow the instructions HERE to update the firmware of your AMPLIFi FX100.
Q: What Bluetooth version is used in AMPLIFi FX100? What Bluetooth codecs are supported?
A: We use a Bluetooth solution that supports Bluetooth 2.1. We only support the SBC codec at this time.
Q: How can I reset the AMPLIFi FX100 to its default settings?
A: To perform a factory reset and restore the AMPLIFi FX100 to factory settings press and hold the Master Volume knob and the TAP button as you power up the unit.
Q: What can I do if I am experiencing Bluetooth connectivity issues between my Bluetooth device and the AMPLIFi FX100?
A: For troubleshooting steps about Bluetooth connectivity and usage check out our Bluetooth Connectivity FAQ HERE.
Q:What should I do If I am experiencing connection issues with the AMPLIFi Remote app when I switch back and forth between apps on my iOS device?
A: An important thing to note about the AMPLIFi Remote app functionality is that in addition to the iOS Bluetooth connection between your AMPLIFi FX100 and your iOS device, there is a secondary 'sync' connection between the amp and the app. Each time you minimize/close the app, the connection between the AMPLIFi Remote app and the AMPLIFi FX100 will need to be re-established, even if your iOS device is reporting that the AMPLIFi FX100 is connected via 'Bluetooth'. In this case, re-opening the AMPLIFi Remote app, will automatically re-establish the connection within a few seconds.
Make sure to look at the main menu of the AMPLIFi Remote app and wait for it to indicate that your AMPLIFi FX100 is 'connected' before moving forward using the app. If it does not automatically re-connect, close the AMPLIFi Remote app by double-tapping your iOS home key and then sliding the AMPLIFi Remote app window up and off the screen to fully close the app. Then relaunch the AMPLIFi Remote app and it should re-sync itself with the AMPLIFi FX100. Android devices usually have a button that lists all open programs where you can slide the app left or right to close it. Then relaunch the AMPLIFi Remote app and it should re-sync itself with the amp.
Q:Can the AMPLIFi Remote App stream songs that are stored in iCloud and not on my iOS device?
A:The AMPLIFi Remote App can only play back songs that are stored on your iOS device. Within the AMPLIFi Remote App settings, you can enable 'Hide Songs Not On Device' so that you only see songs that are stored on your iOS device when playing music from your Library. The Android app does not have this setting, but still only plays back songs stored on the device.
Q:How can I search for a specific tone if I don't have the song or artist in my Library?
A: To search for a specific tone, go to your Library within AMPLIFi Remote and pick any artist, then one of their albums, and then any song. This will begin to play the song and present you with a list of tones that match the song that is playing. You can then swipe down from the top of the tone list to unveil a ââ¬ËSearch Tone Cloud’ field where you can search for an artist or song name to find tones without having the song or artist in your library.
Q: Can I use the AMPLIFi Remote app to load or edit tone files from my other existing Line 6 products?
A: The AMPLIFi Remote app is only compatible with tone files created from the AMPLIFi FX100, AMPLIFi 75 or 150 amplifiers.
Q: Can I use the AMPLIFi Remote app with a Line 6 Mobile In or Sonic Port?
A: The AMPLIFi Remote app is only compatible with the AMPLIFi FX100, AMPLIFi 75 and AMPLIFi 150 amplifiers.
Q: What is the USB input on the back panel of AMPLIFi FX100 for?
A: At the moment, it has no function. It’s been put there for future use.
Q: Where can I register my AMPLIFi FX100?
A: After logging into or creating a Line 6 user account HERE, you can go HERE and enter in your serial number that is found on the bottom of your AMPLIFi FX100, it begins with '(21)PTM', simply fill in the remaining digits.
Q: Is there a forum where I can discuss AMPLIFi FX100 with other AMPLIFi FX100 users?
A:We have a forum dedicated specifically to AMPLIFi FX100 available HERE.
Q: Where can I find information on the warranty that is included with the AMPLIFi FX100?
A: You can find all of the available information on the AMPLIFi FX100's warranty HERE.
Q: What do I if my AMPLIFi FX100 is in need of repair?
A: You can find all of the available information on how to arrange a repair HERE.
AMPLIFi FX100 Benutzerhandbuch
Vollständige Liste aller AMPLIFi FX100 Verstärker, Boxen und Effekte
AMPLIFi FX100 Angaben:
8 Effekte simultan.
ÃÅber 200 Verstärker, Effekte und Boxen.
Zugriff auf 100 Presets, welche schon enthalten sind. Zusätzlicher Zugriff auf unendlich Presets via AMPLIFi App.
Presets und Banken können anhand der 4 professionellen, beleuchteten Fußschalter gewechselt werden.
Bluetooth Audio Stream damit Sie mit Ihrer eigenen Musik mitspielen können. (Kompatibel mit iOS, Android, Mac und PC)
Robuste Konstruktion mit gebogenem Metallchassis.
Gewicht: 3.3kg
Abmessungen: 7.6cm x 45.1cm x 23.5cm
6.35mm Gitarreneingang.
6.35mm Kopfhörerausgang, 6.35mm symmetrische stereo Ausgänge und ein 6.35mm Verstärker Ausgang.
Tap Tempo/Tuner
AMPLIFi Remote Angaben:
Kompatibel mit iOS 7.0+
70+ Verstärker, 100+ Effekte, 20+ Boxen
8 Effekte gleichzeitig.
Ferngesteuerte AMPLIFi Geräte um so den Sound zu modifizieren.
Automatische Klanganpassung versorgt Sie sofort mit dem perfekten Ton.
Zugriff auf tausende Töne aus der Cloud.
Teilen und bewerten Sie selbst Töne in der Cloud.
Sichern Sie unendlich viele Presets in der Cloud.
Von welcher Art Gerät kann das AMPLIFi FX100 Bluetooth Audio empfangen?
Ihr AMPLIFi FX100 kann Bluetooth Audio von allen Android, iOS, Mac oder PC, die Bluetooth haben empfangen.
Wie kopple ich mein AMPLIFi mit meinem Bluetooth Gerät?
Schalten Sie Bluetooth auf dem Gerät an von welchem Sie Musik auf Ihr AMPLIFi übertragen wollen.
Drücken und halten Sie nun den Bluetooth Knopf oben auf dem AMPLIFi, dieser sollte dann anfangen zu blinken.
Jetzt sollte Ihr AMPLIFi als Gerät auftauchen.
Wählen Sie nun hier das AMPILIFi aus um die Geräte zu koppeln. Der Bluetooth Knopf auf dem AMPLIFi leuchtet nun durchgehend blau.
Ihr AMPLIFi kann nun Bluetooth Audio empfangen.
Mit welchen Apple Produkten ist Remote kompatibel?
iPhone 5S iPhone 5S
iPhone 5C
iPhone 5
iPhone 4S
iPhone 4
iPad 4
iPad 3
iPad 2
iPad mini
iPod 5
Wie kann ich die AMPLIFi FX100 Firmware aktualisieren?
Wir empfehlen, die Firmware ihres AMPLIFi Verstärkers immer auf dem neuesten Stand zu haben. Ihre AMPLIFi Remote App wird Sie immer davon informieren wenn ein neues Firmware Update zur Verfügung steht. So können Sie immer sicher sein, dass Sie die neueste Firmware auf Ihrem AMPLIFi läuft. Folgen Sie dieser Anleitung zur Aktualisierung Ihres FX100.
Welche Bluetooth Version verwendet das AMPLIFi FX100? Welche Bluetooth codecs werden unterstützt?
Das FX100 verwendet Bluetooth 2.1 und unterstützt ausschließlich den SBC Codec.
Wie kann ich das AMPLIFi FX100 auf Werkseinstellungen zurücksetzen?
Um das FX100 aus Werkseinstellungen zurück zu setzen brauchen Sie nur den Master Volume Knopf und den TAP Knopf während des Startens gedrückt halten.
Was kann ich tun wenn ich Bluetooth Verbingsprobleme habe?
Hier geht’s zur Bluetooth Fehlerbehebung.
Was kann ich tun wenn ich Verbindungsprobleme mit der AMPLIFi Remote App habe sobqld ich die App mehrmals öffne und wieder schließe?
Es ist wichtig zu verstehen wie die App funktioniert in diesem Falle. Die App baut zwar eine Bluetooth Verbindung zwischen den beiden Geräten auf, hat aber auch noch eine Sync Funktion, die jedes Mal wenn Sie die App neu öffnen wieder von Neuem synchronisiert. Die Verbindung wird also auch jedes Mal wenn Sie die App minimieren und neu öffnen die BluetoothVerbindung neu aufbauen auch dann, wenn Ihr iOS Gerät anzeigt, dass es gekoppelt und verbunden ist. Im Hauptmenu der App können Sie sehen wann die Synchronisation vollständig ist.“Connected“. Sollte die App sich nicht automatisch neu verbinden sollten Sie dei App einmal volsltändig schließen, starten Sie diese dann neu und verbinden Sie erneut.
Kann die AMPLIFi Remote App auch Musik aus der iCloud abspielen?
Nein, die App kann nur Töne abspielen, die sich auf dem Gerät selbst befinden. In den AMPLIFi App Einstellungen können Sie die Option “¾Hide Songs Not On Device“ anschalten um ausschließlich Musik anzuzeigen, die sich auf dem Gerät befindet.
Wie kann ich nach bestimmten Tönen suchen wenn ich den Artisten oder Song nicht in meiner Musiksammlung habe?
Gehen Sie zur Library innerhalb der Remote App, wählen Sie irgend einen Artisten, Album und Song aus. Dies wird den gewählten Song abspielen und Ihnen eine Liste von Tönen anzeigen, die zum Lied passen. Gehen Sie ans Ende der Liste. Dort können Sie “¾Search Tone Cloud“ antippen. Hier können Sie nun nach Tönen suchen ohne Artist oder Song in der Sammlung zu haben.
Kann ich mit der AMPLIFi Remote App auch andere Töne von anderen Line 6 Produkten laden und abändern?
Die AMPLIFi Remote App ist ausschließlich kompatibel mit Dateien des AMPLIFi FX100, AMPLIFi 150 und AMPLIFi 75.
Kann ich die AMPLIFi Remote App auch mit dem Sonic Port oder Mobile In verwenden?
Nein, die AMPLIFi Remote App ist ausschließlich kompatibel mit Dateien des AMPLIFi FX100, AMPLIFi 150 und AMPLIFi 75.
Wofür ist der USB Anschluss auf der Rückseite des FX100?
Dieser hat momentan keine Funktion. In der Zukunft soll dieser jedoch eine Funktion zugewiesen bekommen.
Wo kann ich mein FX100 registrieren?
Nachdem Sie sich bei Line 6 angemeldet haben. (Benutzerkontoerstellung.) können Sie auf diese Seite klicken: Registrierung. Und dort die Seriennummer des FX100 eingeben. Die Seriennummer fängt mit (21)PTM an. Geben Sie hier einfach die fehlenden Zahlen ein.
Gibt es ein Forum auf dem ich mich mit anderen AMPLIFi Nutzern unterhalten kann?
Wir haben ein Forum speziell für das AMPLIFi FX100.
Wo kann ich Informationen über die Garantie meines Produktes finden?
Alle Informationen über Garantien können Sie HIER finden.
Was kann ich tun wenn mein FX100 repariert werden muss?
Alle Informationen über Raparturen können Sie HIER finden.
Unknown Attachment
Liste complète des amplificateurs, baffles et effets de l’AMPLIFi
AMPLIFi FX100 : Spécifications :
8 effets simultanément
Plus que 200 amplificateurs, effets et baffles
100 presets à bord et presets illimités avec l’application AMPLIFi
Changez les Presets et changez les banques avec 4 commutateurs au pied de qualité professionnelle.
Diffusion Bluetooth pour jouer en même temps que votre musique. (Compatible avec iOS, Android, Mac et PC)
Construction robuste avec châssis métallique pliée.
Poids : 3.3 kg
Dimensions : 7.6cm x 45.1cm x 23.5cm
Entrée 6.35mm (1/4 pouces)
Sortie 6.35mm pour les écouteurs, des sorties symétriques stéréos et une 6.35mm sortie d’amplificateur.
Tap tempo/tuner
Application AMPLIFi Remote : Spécifications :
Compatible avec iOS 7.0+
Plus que 70 Amplificateurs, 100 effets et 20 baffles.
8 effets simultanément.
Contrôlez l’AMPLIFi à distance.
La tonalité s’adapte automatiquement pour les sons parfaits pour jouer en même temps avec votre musique.
Accédez milliers de tons en ligne.
Partagez des tons dans le cloud.
Sauvegardez et enregistrez des tons illimités dans le cloud.
De quels appareils est-ce que l’AMPLIFi peut diffuser du audio Bluetooth ?
AMPLIFi peut diffuser de l’audio Bluetooth de tous les appareils Android, IOS, Mac et PC qui ont des connexions Bluetooth.
Comment est-ce que je peux coupler mon AMPLIFi FX100 avec un autre appareil Bluetooth ?
Mettez l’AMPLIFi en mode “¾Pairingââ¬Ë en appuyant sur le bouton Bluetooth sur le dessus de l’AMPLIFi. Le bouton commence de clignoter que veut dire que l’AMPLIFi est en mode de couplage.
Dans les options de Bluetooth de votre appareil, une entrée ë AMPLIFi FX100 û s’affichera.
Sélectez l’entrée ë AMPLIFi FX100 û et couplez les appareils. Le LED s’arrête de clignoter et s’allume continué.
Quels sont les appareils Apple iOS compatibles avec l’AMPLIFi Remote ?
iPhone 5S
iPhone 5C
iPhone 5
iPhone 4S
iPhone 4
iPad 4
iPad 3
iPad 2
iPad mini
iPod 5
Comment est-ce que je peux faire une mise à jour pour le firmware de l’AMPLIFi ?
Nous recommandons toujours que vous avez la version dernière du firmware de votre amplificateur AMPLIFi. Notre application AMPLIFi Remote vous informe chaque fois qu’une mise à jour de firmware est disponible. Comme ça vous savez toujours si vous avez la dernière version. Suivez les instructions ICI.
Quelle version Bluetooth est-ce que l’AMPLIFi utilise ? Quels codecs sont soutenus ?
L’AMPLIFi soutien Bluetooth 2.1 et uniquement le codec SBC.
Comment est-ce que je peux réinitialiser l’AMPLIFi FX100 ?
Maintenez le bouton Master Volume et le commutateur TAP pendant vous mettez l’appareil sous tension.
Qu’est-ce que je peux faire si j’ai des problèmes de connexion Bluetooth avec mon AMPLIFi FX100?
Vous pouvez trouver le dépannage Bluetooth ICI.
Qu’est-ce que je peux faire si j’ai des problèmes de de connexion avec l’application AMPLIFi Remote si je bascule beaucoup entre des applications sur mon appareil iOS ?
C’est important de savoir que l’application AMPLIFi Remote en plus d’établir une connexion Bluetooth avec l’AMPLIFi, il a une fonction ë Sync û secondaire. Ã⬠chaque fois vous minimisez ou fermez l’application, l’application doit rétablir la connexion avec l’AMPLIFi même si l’appareil rapporte que l’AMPLIFi est connecté via Bluetooth. Rouvrir l’application rétablira la connexion. Regardez à l’application AMPLIFi Remote si l’application rapporte que l’AMPLIFi FX100 est ë connected û, vous pouvez utiliser l’application. Si l’application ne reconnecte pas automatiquement, vous devez la fermer et rouvrir.
Est-ce que l’application peut diffuser de la musique d’iCloud ?
Non, l’application peut seulement jouer de la musique enregistrée sur votre appareil iOS. Dans les réglages de l’application vous pouvez activer la fonction ë Hide Songs Not On Device û, comme ça vous pouvez voir seulement la musique enregistré sur l’appareil iOS.
Comment est-ce que je peux chercher pour on ton si je n’ai pas la chanson ou l’artiste dans ma bibliothèque ?
Pour chercher un ton spécifique, cliquez la bibliothèque dans l’application Remote, choisissez un n’importe quel artiste, album et chanson. Cliquez la chanson. L’application joue la chanson et vous offre une liste de tons qui correspondent avec cette chanson. Ã⬠la fin de la liste vous pouvez trouver ë Search Tone Cloud û pour chercher des tons sans avoir la chanson ou l'artiste dans votre bibliothèque.
Est-ce que je peux utiliser AMPLIFi Remote pour charger ou modifier des fichiers des autres produits Line6 ?
L’application est uniquement compatible avec les ficher de sons créé avec l’AMPLIFi FX100, AMPLIFi 150 et AMPLIFi 75.
Est-ce que ce peux utiliser l’AMPLIFi Remote avec Line 6 Mobile In ou Sonic Port ?
Pourquoi est-ce que mon FX100 a une connexion USB ?
Au moment, la connexion n’est pas utilisée. Il a été mis là pour une utilisation future.
Ou est-ce que je peux registrer mon AMPLIFi FX100 ?
Après vous aves créez un compte Line 6 ICI, vous pouvez cliquez ICI pour registrer votre FX100. Entrez le numéro de série que vous pouvez trouver sur le fond. La numéro commence par (21)PTM, remplissez les nombres absents.
Est-ce qu’il-y en a un forum ou je peux discuter l’AMPLIFi FX100 avec autres utilisateurs de l’AMPLIFi FX100 ?
Nous avons on forum en particulier pour l’AMPLIFi FX100 ICI.
Où puis-je trouver des informations sur la garantie qui est inclus avec l’AMPLIFi FX100 ?
Vous pouvez trouver tous les informations sur les garanties ICI.
Qu’est-ce que je peux faire si mon FX100 a besoin d’une réparation ?
Vous pouvez trouver tous les informations sur les réparations ICI.
