Q: What are the amp models on the Spider V?
A: There are 78 total amp models on the Spider V. Check out this link for the complete model listing.
The tone settings list numerous songs can be used to dial sounds in as well. If you would like to return your unit to the original presets, please perform a factory reset (see below).
Q: How do I use the tuner on the Spider V?
A: Press the Tap button, and notice the volume is muted during tuning. You'll see the LCD screen change to the tuner.
Q: How do I perform a factory reset on the Spider V series?
A: Hold down the Home button to access the settings menu. Scroll down with the encoder to where it says Factory Reset. Scroll to the right and press the encoder knob to hit Yes.
Q: How do I perform a factory reset on the Spider V20 version?
A: Hold all three FX, then press and release save while the amp is running.
Spider Remote
Q: I can't find Spider Remote in the Google Play store?
A: If your Android does not support USB Host Mode (which is required for the usage of Spider Remote), the remote app will not show up in the search. Your device is not compatible with Spider V.
You can read more about Spider V and Android compatibility here.
Setup/Connections
Q: What are the inputs and outputs on the Spider V?
A: Instrument in and headphone out on the front, and all this on the back.
Q: Can the Spider V guitar input and the AUX input be used at the same time? Will I hear both of these devices through the headphones?
A: Yes, you can use both and you'd hear them both in your headphones.
Q: Can I use an FBV controller with the Spider V?
A: Yes, the FBV3 and FBV Express/Shortboard MKII are recommended for use with the Spider V. The FBV Mark 1 series may work, but is not supported.
Q: Does the Spider V have an effects loop?
A: There is no effects loop on the Spider V amplifier.
Q: Can I turn off the Tap Tempo Light on the Spider V?
A: Yes, hold down the Home button to access the settings menu. Scroll down with the encoder to where it says Tap Light. Scroll to the right and press the encoder knob to hit Off.
Q: Can I use other Line 6 wireless transmitters with my Spider V?
A: Yes, you can use any other Line 6 wireless transmitters that support RF 2. That includes Relay G30, G50/55, G90, and XDV 70/75 that are on their latest firmware releases. To use them you'll need to manually set the wireless channel on the Spider V in the Global Settings menu. Press and hold the HOME BUTTON to enter the settings menu.
Q: How do I connect my Android device to my Spider V
A: You will need a male Micro USB to Female USB-B or "OTG" adapter to connect to the amp and allow your Android device to work with Host Mode. More can be read and that here.
Specifications
Spider V Series Features and Specs
USB streaming audio (compatible with Android, iOS and Mac or PC)
128 onboard presets
78 amp models
23 cabinet models
101 effect models
Tap tempo/tuner
Compatible with Line 6 FBV 3 and FBV MkII Foot Controllers
Looper (60 sec) *Not featured w/ Spider V 30 or 20*
USB connection
20 watts
1x8" custom speaker and tweeter
Weight: 11 lbs.
Dimensions: H: 13"" W: 12.2" D: 8.3"
1/4" Guitar input and 1/8" Stereo Aux input
1/4" Headphone output
USB Micro-B
30 watts
Weight: 16 lbs 4 oz
Dimensions: H: 14.5"" W: 15.5" D: 8"
USB
FBV foot controller port
60 watts
1x10 custom speaker and tweeter
Weight: 20 lbs 12 oz
Dimensions: H: 16.5" W: 17.5" D: 9"
USB
120 watts
1x12 custom speaker and tweeter
Weight: 29 lbs 4 oz
Dimensions: H: 17.5" W: 20.25" D: 11"
Stereo XLR output
USB
240 watts
2x12 custom speaker and dual tweeters
Weight: 42 lbs 12 oz
Dimensions: H: 21.25" W: 27" D: 11"
Stereo XLR output
True stereo amp
USB
240 watts (speaker outs)
Two 4" speakers and two tweeters for stand-alone practicing (50-watts)
Weight: 28 lbs 2 oz
Dimensions: H: 11" W: 27.5" D: 11"
Stereo XLR output
4ohm mono or 8ohm stereo speaker output
True stereo amp
USB
Registration/Warranty
Q: What is the warranty on the Spider V?
A: The warranty on the Spider V is twelve months from the date of purchase. For more details please see this article: Line 6 Warranty Information
Q: How can I register my Spider V?
A: See this article: product registration F.A.Q.
Troubleshooting/Service
Q: My Spider V seems to be malfunctioning. What can I do as an end user?
A: See this article: Line 6 Amp Troubleshooting
